boswashsprstar
Runway Naming Question Re: ATL, LAX, Others
Sun Apr 01, 2007 9:35 pm
Are the 4 runways at LAX and the 4 older runways at ATL parallel, or not quite? The names--at LAX, the runways are 7L/25R, 7R/25L, 6R/24L, 6L/24R--suggest that the two pairs are slightly skewed from each other, but on maps they appear to be parallel. So are the runways actually all parallel but named different things to avoid confusion? Or are they actually slightly skewed, and if so, is this done for any reason other than avoiding confusing/conflicting runway names?
jetmech
RE: Runway Naming Question Re: ATL, LAX, Others
Sun Apr 01, 2007 10:08 pm
Quoting BosWashSprStar (Thread starter):
I have looked at ATL on Google maps, and the runways do indeed appear to all be parallel! From my understanding of the situation, it is only possible to give a set of three parallel runways the same headings, with the suffix "L", "C", and "R" used to differentiate them. Obviously this is not possible with four or more parallel runways, so I presume that the runways are deliberately given different headings to get around this, even though they are parallel.
Regards, JetMech
vikkyvik
Sun Apr 01, 2007 11:26 pm
Quoting JetMech (Reply 1):
They are most definitely parallel (all 5 at ATL, and the 4 at LAX).
Theoretically, at LAX for example, they could have named then 7R/25L, 7C/25C. 7L/25L, and 6/24. But it makes it easier if you divide them into two pairs (the 7/25's and the 6/24's), especially since physically, the runways are in two pairs anyway (the 7/25's being on the south side, and the 6/24's being on the north side).
ANITIX87
Mon Apr 02, 2007 12:44 am
Not necessarily true. The master plan for ORD calls for 6 runways in the 9/27 direction and two in the 4/22 direction. The 9/27 runways will be numbered, from North to South, as follows:
9N/27N
9L/27R (Arrival)
9L/27R (Departure)
9R/27L (Departure)
9R/27L (Arrival)
9S/27S
Seems awfully confusing to me, but that's what the plan calls for.
TIS
[Edited 2007-04-01 17:44:29]
vikkyvik
Mon Apr 02, 2007 3:50 am
Quoting ANITIX87 (Reply 3):
9N/27N
9L/27R (Arrival)
9L/27R (Departure)
9R/27L (Departure)
9R/27L (Arrival)
9S/27S
Am I the only one who sees absolutely no sense to that runway naming scheme?
They could use 9/27(R/C/L) and 8/26(R/C/L) (or 10/28, depending). Can you really have two runways with the exact same designation, even if one is purely an arrival runway, and one's a departure runway? Seems....odd.
InnocuousFox
Mon Apr 02, 2007 6:10 am
With the recent design scheme of having arrival and departure pairs, you may as well share numbers. Everyone knows that you land on the outside one and depart on the inside one.
Dave Mark - Intrinsic Algorithm - Reducing the world to mathematical equations!
Mir
Mon Apr 02, 2007 6:28 am
9N/27N
9L/27R (Arrival)
9L/27R (Departure)
9R/27L (Departure)
9R/27L (Arrival)
9S/27S
I don't think the FAA's going to be too happy with that one. They may be referred to as that in the development plan, but they'll be numbered, and referred to in practice by ATC, as 9/27 and either 8/26 or 10/28.
-Mir
EDIT: typo and clarity
[Edited 2007-04-01 23:29:54]
timz
Mon Apr 02, 2007 8:32 am
http://www.worldaerodata.com gives the true azimuth for each runway at each airport it lists, to a tenth of a degree, if you want to check how parallel they are. As I recall the 4/22 runways at ORD are a degree or two out of parallel.
bond007
Mon Apr 02, 2007 9:33 am
Correct. More than 3 parallel runways the number is changed to differentiate them. No pilot is using this number for navigation (except very roughly for visual purposes), so it's of no consequence.
Quoting Vikkyvik (Reply 4):
No, it won't happen. With runway incursions being the hot-topic, this just doesn't make any sense. Think about airport runway signs etc. etc.
Quoting InnocuousFox (Reply 5):
LOL... they do? Like I said, not a chance. Perhaps you are forgetting that apart from the obvious safety issues, a runway must be numbered uniquely if only for the FMS and approach documentation etc. etc.
BTW, the chance of a runway ALWAYS being used for departures only and the other for arrivals only is almost zero.
Jimbo
Jetlagged
Mon Apr 02, 2007 10:14 am
When they added the third parallel runway at Miami it could have been numbered 08/26, leaving the existing 09/27L and 09/27R unchanged. However it was decided that as the new runway was so close to an existing one, the two runways had to become a pair with shared numbers, leaving 08/26L, 08/26R and 09/27. So all three runways changed designation.
vikkyvik
Mon Apr 02, 2007 10:26 am
I've seen more than a few airplanes land on the inner runways at LAX, when there were no departures waiting.
Quoting Bond007 (Reply 8):
Yeah, that makes sense to me. Thanks.
3DPlanes
Mon Apr 02, 2007 11:11 am
LOL, I can see it now...
"United 243, cleared to cross 27L."
"No, no, no! Not THAT 27L! The other one!"
Or, maybe...
"Delta 155, taxi to 27L, hold short of the other 27L."
"Simplicate and add lightness." - Ed Heinemann
InnocuousFox
Mon Apr 02, 2007 1:54 pm
I thought that when I read the ORD proposal, they said that it was because they were so close together they were designed to have the shared functionality. *shrug*
ATCme
Tue Apr 03, 2007 12:37 pm
The four North/South runways at DEN are all the same exact heading, but are numbered in pairs of 16/34 and 17/35. I think this is the way to go because it is differentiated yet still easily remembered. Plus, Arrivals are usually on one pair and departures usually on the other.
Yeah, I could also see 9CL/27CR or 9CR/27CL
ATCme spin
I'm from the FAA, and I'm here to help. Really. Yes I'm serious, I'm here to help you.
SEPilot
Tue Apr 03, 2007 8:47 pm
I do find it handy to know the runway heading to plan an approach, but 10 or 20 degrees variation is of little consequence. If you are doing an instrument approach it is unneccessary, as you will be heading for an initial approach fix anyway and it is all charted from there. I agree that it is essential to have unique identifiers for every runway.
Quoting 3DPlanes (Reply 11):
Exactly.  crazy
apodino
Fri Apr 20, 2007 12:38 pm
Here is an interesting tidbit that I learned in ATC class. When you have four parallel runways, and you have to come up with a number scheme, here is the way its usually done. Which ever configuration is the more common configuration has to do with it a lot.
Its easier to illustrate this with an example. At MCO, which is an airport that has four parallel, the more common configuration is the south configuration. Before the 17's were built, you had the 18's. Because you want the numbers to illustrate diverging runways in the primary direction, the new runways were labeled 17-35's. If the primary configuration was northerly, they would have likely been labeled 1-19s, which shows divergence in the northerly direction.
In ATL, the primary direction is east, so the numbers reflect 10 and 8's which would diverge from 9's.
In LAX, its primarily a west config, hence the south runways are 25's and the north's are 24's.
In DTW, the primary config is the southwest, hence 21 on the east and 22 on the west.
At DFW, its the south config thats the more common one, which means the east runways are 17's and west are 18's.
And in DEN, its set up as primarily a north config, hence 34 and 35's, and west, so 25 and 26.
There are a few more examples of this. My guess is that ORD would consider an east config primary, much like plan x, so you will have one of two scenarios.
The north 2 runways are a pair of 8-26's, the middle 2 9-27's exactly as they are now, and the new 2 south runways 10-28's.
The other scenario would be for the 3 north runways to be 8-26's LCR and for the south to be 9-27's in a similar manner.
timz
Sat Apr 21, 2007 12:48 am
Quoting Apodino (Reply 15):
Should be the other way round, according to your pattern.
srbmod
Sun Apr 22, 2007 1:00 am
The new runway @ ATL is numbered 10/28, as it's far enough away from the 9/27s to be given its' own separate headings (much like the 8/26s.) Had it been built closer in to the 9/27s, perhaps they would have renumbered 9R/27L to 9C/27C. And had the fifth runway been built on the north side of the airport (this was one of the areas considered for the fifth runway, and is probably out of play for the sixth runway if one is ever built [Quite a bit of infrastructure would have to be relocated, as there are several hangars, the fuel farm, the FBO, a hotel, the North Cargo complex and the EV G.O. that are sited near where a runway could potentially be put]), depending on the exact location, it could have been the new 8L/26R (with the current runway renumbered to 8C/26C) or 7L/25R.
AAR90
Sun Apr 22, 2007 10:34 am
Three excerpts from the Sprint '07 AA pilots e-newsletter:
When completed, the “new” O’Hare will look a lot like Atlanta Hartsfield, featuring six parallel east-west runways and access to a central terminal facility from both directions. Unfortunately, the runway expansion will require razing surrounding development, and the southern half of the expansion will also require relocation of major roadways - a project that will take many years. In the short-term, though, we are doing runway improvements as well as adding a new runway and tower to the north side.
Finally, to the flying part of the new O’Hare airport. Contractors are doing site work to make way for the new north runway, and, since the runway will not be fully visible from the current tower, a new tower will soon rise near our maintenance hangar. The current 9R-27L runway will be redesignated 10-28 sometime this summer (eventually 10L-28R), and it will be lengthened to the west. The current 9L-27R will become 9R-27L and the new north runway will be 9L-27R.
Runway 14L-32R will continue to be shortened due to excavation work off the northwest end, and taxiway fillets will be added at various intersections to expand routes for the A-340-600 and allow regular operation of the A-380. ASDE-X radar will be added to allow “position and hold” operations, so you will leave the transponder on after landing as you do now in DFW.
larspl
Tue Apr 24, 2007 6:35 am
there is no 'its usually done this or that way'..
icao has rules about it!
facebook.com/ddaclassicairlines
PGNCS
Tue Apr 24, 2007 6:41 am
Quoting Timz (Reply 16):
Apodino is correct. The south pair are 25/7 L/R, and the north complex are 24/6 L/R. I'm just grateful that 25L is open again; looking forward to the parallel taxiway to be finished.
timz
Tue Apr 24, 2007 9:10 am
Quoting PGNCS (Reply 20):
Apodino is correct.
Take another look at his post.
Quoting LarSPL (Reply 19):
About runway numbering? What are their rules, and does LAX comply with them?
bond007
Tue Apr 24, 2007 9:59 am
Very informative .... and they are ....???
Actually as is usual, the FAA does not stick exactly to ICAO recommendations, so there is some flexibility here. If we're talking ICAO rules, we wouldn't be talking about runways 8L and 9R ... it would be 08L and 09R!
Quoting Timz (Reply 21):
Yes. Four parallels should be numbered L,R,L,R and there is no requirement for "diverging runways in the primary direction" ... although the FAA may well do this. One set must be to the nearest one tenth magnetic azimuth, and the other set to the next nearest one tenth azimuth. It does not specify which set, L or R, should be given the first number.
5 parallel runways should be either: L,R,L,C,R or L,C,R,L,R.
6 parallel runways: L,C,R,L,C,R.
No doubt exceptions for existing runway numbers when building new parallels alongside.
Jimbo
PGNCS
Tue Apr 24, 2007 11:07 am
Apodino is correct.
In LAX the south pair are 25/7 L/R, and the north complex are 24/6 L/R, which is what I was assenting to (at least I am pretty sure that when I landed on the southernmost runway at LAX on Sunday, it was 25L.)
If you are saying that his post is incorrect because the southern runways (25) aren't given directional numbers diverging from the northern pair (24) than I totally agree with that. I thought you were saying the north complex was the 7/25s.
I think we were talking about two different things, and I appreciate you bringing up my faux pas for clarification!  Smile
Users browsing this forum: nwray, OMP777X and 9 guests
