comorin
How Do Rockets Maintain Stability At Liftoff?
Sat Apr 07, 2007 9:00 am
Just returned from a wonderful and awe-inspiring visit to NASA at Kennedy Space Center, and I have a question regarding stability at liftoff. Given that the propulsive force is happening below Center of Mass, aren't rockets inherently unstable - a slight deflection resulting in a larger deflection? Do they restrain the rocket until it 'shoots' off the pad? Any illumination on the topic is most welcome...
3DPlanes
RE: How Do Rockets Maintain Stability At Liftoff?
Sat Apr 07, 2007 10:33 am
The rocket nozzles are gimbaled so they can vector the thrust to direct the rocket.
If you watch a shuttle launch, in the last few minutes before launch (or less), they'll usually show a shot of them moving the three main engine nozzles around through their range of motion.
"Simplicate and add lightness." - Ed Heinemann
comorin
Sat Apr 07, 2007 12:51 pm
Quoting 3DPlanes (Reply 1):
Thanks! I presume then that they use gyros to control the servomechanisms that position the motors. Must have been tricky in the old, pre-solid state days of Dr Von Braun...
KELPkid
Sat Apr 07, 2007 1:06 pm
IIRC, a properly-designed rocket (one with a fixed exhaust nozzle) always has the Center of Pressure behind the Center of Gravity (I may have that relationship backwards...). I was one of those kids that designed my own Estes rockets from the parts bags  Wink Good thing for large fields...
jetmech
Sat Apr 07, 2007 3:36 pm
Quoting Comorin (Thread starter):
G'day Comorin  ,
This is what happens when things go wrong, and the back of the rocket tries to overtake the front;
http://www.youtube.com/watch?v=kYUrqdUyEpI&mode=related&search=
http://www.youtube.com/watch?v=IONcgYzVFlg
Apparently, a computer glitch caused a malfunction in the guidance control system. The subsequent explosion was an automatic self-destruct mechanism.
Regards, JetMech
[Edited 2007-04-07 08:38:47]
Stealthz
Sat Apr 07, 2007 4:02 pm
An example is the Saturn V that launched Apollo to the moon,
After ignition the hold down arms would release then the acceleration of the rocket was further impeded by steel pins that were drawn through dies, effectively making steel wire! This stabilised the vehicle for the initial moments of flight.
Of the 5 rocket engines the outer 4 were steerable and the centre one was fixed, the 4 outer engines were steered outward so if one failed the others were still thrusting towards the centre of gravity.
Much more detailed information here....
http://en.allexperts.com/e/s/sa/saturn_v.htm
comorin
Sat Apr 07, 2007 11:32 pm
Quoting KELPkid (Reply 3):
I think you would need a 'righting' moment of either a fin or an aerodynamic surface to keep it on its path? Must have been a lot of fun growing up with those Estes rockets!
Quoting JetMech (Reply 4):
Who is that pleasant looking girl in your profile? Can I Bloody Hell move to Oz?  Wink
Quoting StealthZ (Reply 5):
Thanks, that was interesting reading.
I've gotten to a point where I understand finned rockets and positive stability, but still trying to wrap my head around intrinsically unstable rockets. Does the shape of the surfaces on the Shuttle enhance stability or is it irrelevant? It's also interesting to note that that the CG changes rapidly as the fuel is being used up.
KELPkid
Sun Apr 08, 2007 2:15 am
Quoting Comorin (Reply 6):
Fins actually induce stability in many rockets by causing them to spin (!). Yes, spinning about the vertical (flight) axis does stabilize a rocket...this was probably Dr. Von Braun's biggest contribution to the US Space program, for this was something that Goddard had not stumbled across.
Of course, most modern rockets no longer spin for stability, the rockets like the Space shuttle and the Delta aren't even symmetrical around the vertical axis.
comorin
Sun Apr 08, 2007 4:24 am
KELPkid, thanks for the post.
I believe most modern fighters are aerodynamically unstable, and are kept stable by flight control systems. I can see how servos can actuate surfaces quickly enough to do this. However, in a Launch Vehicle (picking up the jargon!), it must be difficult to gimbal the motors quickly enough to respond (and also not cause oscillations). Perhaps it's just the nozzle that's gimballed, or do they vector the thrust some other way?
Any added explanations or links welcome - thanks.
chksix
Sun Apr 08, 2007 4:34 am
The Main engines of the shuttles are gimballed around a thrust plate just above the nozzle. The engine is in this way following the gimbal motion on the other side of the plate.
Big version: Width: 519 Height: 389 File size: 62kb
The conveyor belt plane will fly
Jerald01
Sun Apr 08, 2007 1:40 pm
The solid rocket boosters used on the Space Shuttle have a flexible bearing in front of the steerable exhaust nozzle. Each nozzle is vectored by two hydraulic actuators, placed 90 degrees from each other around the nozzle and each pushing/pulling longitudinaly along the rocket motor's axis. The actuators are powered by hydrazene-pressurized units which, in turn, are controlled by computers located in the nose of the booster rocket. Those computers are fed information from several sources and keep the Shuttle on the planned flight path.
The fact that these rockets are powered by solid fuel make them just a little different from those that are liquid-fueled. Liquid-fueled rockets lose weight and have tremendous changes of center-of-gravity and center-of-moment taking place very rapidly because of the burn-off of fuel. Solid rockets, on the other hand, have much less of a change of center-of-gravity and center-of-moment because the fuel is burned evenly along the full length of the rocket. This is because, during the pouring of the solid fuel into the rocket casing, a piece of tooling (called a "core") is inserted into the rocket casing and the fuel is poured around that core, leaving a hollow hole in the fuel the entire length of the rocket.
When the rocket's igniter (located at the front end of the rocket) fires, the entire face of fuel along that center hole ignites, sending hot, burning solid fuel out the nozzle. As the fuel burns, the diameter of the hole inside the fuel gets bigger, making the burning face of fuel larger, giving more power to the rocket, but keeping the CG fairly close to the original location.
When the Shuttle rises off the pad you will notice that it makes a 90-degree roll just as the wingtips clear the launch tower. This entire roll motion is the result of the booster rockets' nozzles being vectored, allowing the Shuttle to be turned toward it's intended flight path. Even though the Shuttle is travelling just over 100 MPH when it clears the launch tower, all steering is done with the booster rockets.
I hold my breath for 2 minutes and 12 seconds on each Shuttle launch, and give a sigh of relief when I see those beauties separate from the Shuttle. I know that in about three weeks I will be seeing sections of those rockets back at our plant, where we will begin their refurbishment for another launch.
"There may be old pilots, and there may be bold pilots, but there are darn few green cows"
OldAeroGuy
Sun Apr 08, 2007 10:42 pm
There was another reason for the controlled release of the Saturn V. The total vehicle weighed 6 million plus pounds while the main engines produced a total of 7.5 million pounds of thrust. Since the F-1 engines were not throttleable to the same degree as the SSME's, instantaneous release of all that thrust against the inertia of the full liftoff weight could have resulted in permanent deformation of the vehicle's structure, given the lightness of its construction.
A controlled release of the vehicle thrust ring allowed a uniform, "gradual" build up of the thrust force without inducing a sudden point load.
comorin
Sun Apr 08, 2007 10:43 pm
Quoting Jerald01 (Reply 10):
 thumbsup  Thanks for taking the time for such a thorough explanation! It struck me while reading your post that the control systems would also need to compensate for any small differences in thrust from each of the motors.
787atPAE
Mon Apr 09, 2007 3:24 am
To make things a little realistic, try balancing a pencil or a baseball bat on your finger as your finger pushes the object upwards against gravity. Just don't hurt yourself!!
Your finger is the propulsion that moves the vehicle upwards into the heavens and the blackness of space. You will find that no matter what, the pencil/bat will always lose control. Computers must be used to control the vehicle on its launch trajectory. Human reaction times are just not fast enough to deal with the dynamics of such an unstable vehicle.
KELPkid
Mon Apr 09, 2007 11:03 am
An Estes rocket, of course, uses the launch rod for stability  Smile Certain models of rockets have minimum launch rod length requirements, and the rocket has a small tube on the side of it's body (sometimes through the middle of the body and the nose cone for multi-engined and nonsymmetric models) that you slip the launch rod through when you put the rocket on the pad. By the time the rocket clears the launch rod, it is travelling fast enough to be aerodynamically stabilized.
Jerald01
Mon Apr 09, 2007 11:57 am
Quoting Comorin (Reply 12):
Yes, the avionics packages in the nose of the Solid Rocket Boosters (SRBs) receive input from various sensors and determine what minor corrections are needed. An electronic signal is sent to the actuator packs via hardwired circuits located on the outside of the SRB, and the actuator packs "steer" the nozzle through hydraulic rams that are connected to a compliance ring that surrounds the aft exit cone. These are HUGE rams, but they have to be, considering they are vectoring a stream of hot gases/solid fuel that is producing 3.5 million pounds of thrust.
The Solid Rocket Boosers (SRB's) are composed of four sections (the Forward, Center Forward, Center Aft, and Aft), each of which is indvidually filled with a slurry mix with the rocket section standing on end in a deep pit. The individual sections for each flight are manufactured at the same time. That is, the Forward sections of a specific flight are manufactured at the same time. The Cetner Forwards, Center Afts, and Afts are also manufactured with their counterparts from the other SRB.
The propellant mix comes from the mixer building and half of it is poured into one of the Forward sections and the other half into the other Forward section. When the pouring of the sections is complete, the sections are then cured at exactly the same time, using the same temperatures, etc. That way there is little variation between the two rocket motors.
Every process in the manufacturing sequence is tightly controlled and nothing is left to chance. Once those SRBs are started there is no way to throttle them back or shut them off. The solid fuel provides it's own combustible material and it's own oxygen, so there is no way to put the fire out once it starts. so there is no room for error OR large variations between the two SRBs.
kalvado
Mon Apr 09, 2007 9:03 pm
Quoting 787atPAE (Reply 13):
That's an excellent example... but it has nothing to do with rocket lift-off, though.
Mon Apr 09, 2007 9:50 pm
Quoting Comorin (Reply 8):
Actually quite few are even today. It's still cutting edge technology, as evidenced by the two early Gripen crashes.
By my count:
- F-16, mildly.
- Gripen.
- F-22.
- F-35?
- Typhoon.
- F-117.
FredT
Tue Apr 10, 2007 4:26 am
Yes, you must have an aerodynamic righting moment to keep the rocket pointed in the direction of flight, which you get if you design the vehicle as suggested by KELPkid.
Then you have static stability. With controlled nozzles, you get controllability through an active guidance system.
More interesting is the question of how simple rockets without active guidance actually maintain a more or less straight path. We're talking FFARs to fireworks here. There's nothing to keep them flying in one direction, so any imbalance or manufacturing defect would cause them to follow a curved path? A misrigged free-flying model aircraft will, at best, fly circles with a rather small radius, right? So why do new years fireworks rockets, manufactured with very large tolerances, go off on a straight path?
The basic static stability keeps them more or less aligned with the direction of flight. This keeps the thrust pointed in the general direction of flight. And the thrust is orders of magnitude larger than any aerodynamical forces which could act to change the direction of flight. Thus, the rocket may well accelerate laterally but it will be completely insignificant compared to the acceleration in the direction of flight, and more or less straight flight is maintained even though the pin of the rocket may be all crooked.
If you have the thrust misaligned with the stability axis, things get more interesting of course. However, this tends to induce rotation as well, giving a straight spiralling path rather than a curved path.
I'm really no rocket scientist, just a simple aero engineer, so this is strictly speaking outside of my aeroea (har har har) of expertise, but I consider it interesting enough and enough frequently overlooked to be worthy of mentioning anyway. Consider the above an attempt to get you thinking about something which you may, or may not, have overlooked rather than an attempt to describe it all absolutely accurately and down to every detail.
Cheers!
/Fred
comorin
Tue Apr 10, 2007 8:08 am
Good points, all, and many thanks to the a.net Brains Trust!
rwessel
Tue Apr 10, 2007 9:04 am
While that's true of core burning solids (which the SRBs most certainly are), end burning solids often have worse CG changes than liquids. On liquids the fuel tanks are commonly stacked, and the fuel CG change is closer to the average of the two tank lengths, rather than the whole chamber as on an end burning solid.
A considerable range of tradeoffs between thrust and burn time is possible on solids by controlling the size of the burning surface. Core burners being at the maximum thrust/minimum duration end of the spectrum, (flat) end burners being at the minimum thrust/maximum duration end.
There are two aspects to the roll after liftoff. First, since the Shuttle is rather asymmetrical, they want it pointed in the correct direction for the orbit they're trying to hit. That would be possible either right side up or upside down. The reasons for rolling inverted are for aerodynamic load management (apparently it's lower upside down), and for visibility in case an emergency separation is needed. So the total amount of roll is dependent on which way they want to go plus the need to roll inverted. The pads are oriented somewhat oddly given that requirement - you'd expect them to be aligned to have the Shuttle in the "correct" orientation for an "average" launch, instead they're aligned for a launch due north. I suspect that's left-over from Apollo.
Tue Apr 10, 2007 9:08 am
Quoting Rwessel (Reply 20):
As usual, the Russians are much more into the KISS principle. The Soyuz pads are simply oriented in the correct direction for launch. No need for any fancy high tech roll crap. Big grin
Jetlagged
Tue Apr 10, 2007 9:19 am
Quoting Starlionblue (Reply 21):
Soyuz, like Apollo/Saturn V, wouldn't needed to roll for orientation due to its symmetry.
787atPAE
Tue Apr 10, 2007 9:28 am
Try again. The only reason why the vehicle is "heads down" is because of communication between air and ground at Bermuda and similar sites. This is the same reason why the first shuttle launch was at an inclination of about 41 deg off the equator. NASA has been doing it this way ever since STS-1, it is certified, and it makes no sense to do it otherwise. Nowadays, we have the TDRS satellite system for comm, therefore, late in the shuttle's ascent, NASA takes advantage by having the shuttle's computers command a 180 deg roll about 350 sec into flight.
In a way, the US system is similar in that principle. The shuttle's tail is pointed due south so the Range Safety folks know how it is lifting off. This has been the convention since STS-1. I hope I never hear of a story where the RSO says during a liftoff "is it supposed to be pointed that way?" and then made their decision to pop the switch That will a bad day....
Quoting Kalvado (Reply 16):
This has everything to do with a rocket liftoff. Do a free body diagram of both and compare the figures. You will find they are very similar. The propulsive force will be in exactly the same as the "finger force", just about 10000000 orders of magnitude different.   The main difference will be in the aero of each. For a quick example to demonstrate stability, that doesn't matter.
[Edited 2007-04-10 02:35:23]
kalvado
Tue Apr 10, 2007 10:35 am
Quoting 787atPAE (Reply 23):
for an excellent example of how not to do it - maybe...
rockets are generally stable at the time of launch; how it's achieved is a very different story..
3MilesToWRO
Tue Apr 10, 2007 10:22 pm
You are not quite right. Human reactions are too slow for a pencil or 1m long stick, but they are OTOH too FAST for a stick of 3m. What you are describing happens because human brain is tuned to keep vertical an object of length, say, 2m. I mean - human body. As you have probably seen many times - human body being highly unstable in upright position, does not fall. Try balancing a broom, a rake (good word? I mean this comb on a stick for grass) or any tool that has a 1,5m long handle. Not a big problem.
I don't also think that human brain would be unable to control a rocket launch. It's a different mechanism and you'd simply need to keep the required heading like you keep in 747. You can, can't you? The problems are with g-force, lack of target to point at to keep the direction, and availability of computers that, after all, can do it easily.
Being a SF fan, I can also point to Stanislaw Lem's "Ananke" story, where stability of landing rocket plays a crucial role  Smile
FredT
Wed Apr 11, 2007 3:26 am
I'm afraid the thrust of the rocket will stay aligned with the rocket rather than remain acting straight up if the rocket tilts, as the lifting force applied to the tip of the pen would. That's why the example has very little to do with the launching of a rocket.
Rgds,
/Fred
rwessel
Wed Apr 11, 2007 6:58 am
Quoting FredT (Reply 26):
That would be great if the thrust axis was exactly aligned with the CG and nothing ever disturbed the vehicle. Otherwise that sucker is tipping over. When you move your finger to the side to compensate for the tilting stick you're balancing, that's exactly the same effect as when the rocket motor gimbals to keep the pointy end up.
Of course non-aerodynamic attitude control does not have to happen by gimbaling the main engine(s). Gyroscopes and thrusters (at either end), not to mention thrust paddles, have been used. Not to mention putting the CG behind the engine instead (although an S-IC on top of a giant stick would be quite a sight).
KELPkid
Wed Apr 11, 2007 7:20 am
Quoting Rwessel (Reply 27):
One of the simplest, least expensive Estes kits used to be like this...the engine, on the pad, hung down below the rocket body (with the top of the engine stuck into the body). The fins on this particular rocket were long enough to touch the pad, and induced rotation (they were canted about 3 deg. off of vertical, and had a rough airfoil shape). There was a small hole just below the nose cone-the ejection charge on the Estes engine did not blow a chute (and the nosecone off) on this model of rocket  Smile The nose cone was solid balsa wood, too...A standard Estes single-stage, size A to C engine was used (depending on how high you wanted to go...). A metal clip limited the engine's downward motion (due to gravity) while sitting on the pad, and also played an important role at the top of the flight. Stay tuned...
Well, when you pulled the trigger for launch, the engine would shove itself full forward, and all the way into the body (I believe it was stopped by a spacer, so that it wouldn't actually touch the nosecone). The metal clip and extra-long fins kept the CG aft of the engine, otherwise this thing would fly like a shuttlecock.
When the engine burned out, and burned the smoke-only descent charge (3-5 sec.), the rocket would start arcing towards horizontal, and then the ejection charge would shove the engine back against the clip, and the sudden change in CG would cause the rocket to descend nose first. Well, the 3 deg. cant in the fins would cause the rocket to spin again (going downwards), and create a slight amount of lift (and it doesn't take much in a rocket that weighs a couple of ounces  Wink ), effectively becoming a helicopter in autorotation mode. This arrested the descent rate just enough that, as long as it didn't hit anything solid, the rocket was recovered intact. It was a very cool rocket-wish I could remember the name of it...
rwessel
Wed Apr 11, 2007 7:49 am
Quoting KELPkid (Reply 28):
I remember several spin recovery rockets, and several gliders, although I don't remember one with a moving engine. There were several that actually ejected the engine (sometimes even with a streamer!), or the entire boost stage, though.
In any event, I assume you meant when the engine blew back it pitched up, not down?
KELPkid
Wed Apr 11, 2007 1:34 pm
Quoting Rwessel (Reply 29):
I want to say it was the "Alpha", but I can't remember...(this was when I was 12 years old...). It was the smallest rocket kit Estes made at the time, and only cost like $7
Nah, it landed nose first, with the spent engine casing still onboard...the balsa wood fins were a bit fragile to handle a tail-first landing  Wink Remember, too, that a spent engine asing is much lighter than the original engine.
Users browsing this forum: Max Q, MrBretz, zzaewon and 2 guests
