Rail Launching Of Aircraft
Tue Apr 10, 2007 1:53 am
Slow day today. Time to start a new topic.
I was reading about "aircraft on rails" such as Schienenzeppelin and Aérotrain (both very cool pieces of kit), so I started thinking about rail take offs of aircraft. This is of course nothing new. Military rockets and even aircraft (V-1) have been launched on rails for decades. However, I was thinking in terms of propelling the vehicle with an exterior fuel source. That is, the rail system would provide initial propulsion, reducing the weight of the vehicle by imparting enough momentum for initial flight. This kind of system has also been in use for decades on aircraft carriers, but mainly for the purpose of allowing short take off rolls, not directly for saving fuel.
This external propulsion can be achieved by steam, electromagnetism, etc. The point being that the vehicle can be made lighter, and thus total fuel savings be achieved.
In this age of rising fuel prices, could rail take offs be an option for the future? I understand there are huge disadvantages, but it's a neat concept.
Let the ritual flaming commence!
[Edited 2007-04-09 18:53:46]
KELPkid
RE: Rail Launching Of Aircraft
Tue Apr 10, 2007 2:32 am
Well, this was the Wright Flyer's method of launch...  old
kalvado
Tue Apr 10, 2007 3:54 am
most apparent objections:
You cannot really land on rails, so it has to be some procedure to put the plane on rails. Extra cost - people and equipment on the ramp; possibly loss of flexibility in motion ( can you enter runway at intermediate point if needed?), and flexibility of switching the runways (is it possible to land on rails, if properly setup?)
Next, you'll have to setup a hard point for attachment to launch trolley - something similar to landing hook for carrier landing - I bet it's not going to be light structure. Weight increase - more fuel (probably most important point here)
Rails themselves - I don't think it's reasonable to use same track width for ERJ and B747/A380, so there will be multiple tracks, adding more varieties of launch equipment, and launch trolleys themselves would tend to accumulate at one end of runway (and they're not free either)..
Some of these can definitely be worked out, but hardpoint issue is probably the worst one.
Tue Apr 10, 2007 5:27 am
Quoting KELPkid (Reply 1):
So it was. Counterweight as I recall.
Quoting Kalvado (Reply 2):
Well, I wasn't really envisioning landing on rails. I saw it more as a launch from a rail like from an aircraft carrier for example, thereby saving some amount of fuel needed for acceleration. After that, it's just a normal ERJ or whatever that can land wherever.
Also, for airport without rail launch the aircraft could just take off normally.
I don't know if it needs to be that beefy. Aircraft do get towed every day and I bet if you could attach to the main gear you could put quite a bit of load there. That's how the French Navy used to launch aircraft.
I am also curious how much fuel is used during the take-off run. Say that the aircraft can be accelerated up to just under the max tire speed. As Captain Click would say, that energy is still being produced somewhere, but by using energy off vehicle weight is saved if nothing else.
[Edited 2007-04-09 22:33:42]
FredT
Tue Apr 10, 2007 5:55 am
A) Very little fuel is used for the acceleration, compared to what is used for climbout or flight. The fuel savings possible are miniscule.
B) You do not want to come off the rail, push the throttles forward only to find that uh-oh, the power isn't coming as expected for whatever reason. Engine failures in flight are worse than engine failures on the runway. The solution is to get the engines up to power prior to actuating the launching system. However, this means there's no real saving of anything but runway length for a given MTOW. Basically a carrier takeoff. The structural reinforcements required to get the launcher force into the aircraft structure would probably eat up any benefits - and more. Carrier capable aircraft are very beefed up, from a structural point of view, to cope with the stresses of cat shots and no-flare arrested landings.
All in all, you are much better off just adding those extra few pounds of fuel required for the take-off roll.
Now, if you consider putting the aircraft on a giant conveyor belt, which is accelerating as the aircraft accelerates. Then you fill the cabin with chickens (or penguins, for polar routes) and have them all take off at the moment of rotation...  Wink
/Fred
kalvado
Tue Apr 10, 2007 6:18 am
Quoting Starlionblue (Reply 3):
I'm afraid it _needs_ to be that beefy - when the plane is towed, acceleration (and force) is quite small - here we're talking about full takeoff power. I would say something upward of 100 klb for 777. MLG takes plenty of load from brakes action, but load would be higher, something like the load during aborted takeoff without spoilers or reversers. Besides, it's the load in opposite direction - which probably adds some extra metal needed.
Regarding take-off fuel, as far as I understand take off thrust is about 5 times that in cruise; assuming thrust is proportional to fuel burn - 1 minute of take-off roll is equal to 5 minutes in cruise. But then - what limits the MTOW? If it is weight (wing lift/engine power) limited, that MTOW would go down by exactly the weight of fuel burned on takeoff.
kalvado
Tue Apr 10, 2007 6:30 am
Quoting FredT (Reply 4):
Actually I wrote, but didn't post a similar comment. IMHO you can save some gas here (not in a global setup - just during takeoff) - either you takeoff roll is shorter time-wise (less gas), or you can spool up engine little bit later, so that you get full engine power while there is still enough room to stop, or before you separate from the trolley. SOP for that would be a nightmare, though.
Jetlagged
Quoting Starlionblue (Thread starter):
Rare, Medium or Well Done?  flamed
Rail launching might not work too well in the UK. We're not very good at things which run on rails. Flight cancellations due to "leaves on the line" could cause a riot! Big grin
KELPkid
Tue Apr 10, 2007 6:49 am
Quoting Jetlagged (Reply 7):
And definitely don't make it electrically powered with overhead catenary as the power source, as the Brits will figure out how to make it regularly pull down the catenary cable (like the Eurostar...)  duck
N231YE
Tue Apr 10, 2007 7:40 am
What if the rails were moving like a conveyor belt; moving in the opposite direction of the aircraft's thrust?  wink
Tue Apr 10, 2007 9:13 am
Somehow I knew it would come to this.  rotfl
Anyway thanks for brightening an otherwise slow Monday!
3DPlanes
Wed Apr 11, 2007 11:33 am
Late to see this and chime in...
I agree that the fuel savings would likely be smallish given that (like a carrier shot) you'd want to be at full juice before they launched you...
However, I think folks are thinking too much along the lines of cat shots or zero length rails. If the acceleration was gradual enough, you wouldn't need _any_ additional strengthening. And I'm not talking zero to Vr in 4 minutes, either. Just nothing like a push-your-eyeballs-through-your-brain cat shot.
To continue the discussion (although, I'm not sure that Starlion wants that,) what about a combination system. Low-force cats embedded in the runway? Hook up would still be interesting on an active runway, but if the Navy can do it...
Still though, aside from a shorter takeoff run (meaning shorter runways,) would there be any real benefit? Even halving the takeoff roll would only reduce the TO thrust duration by what? 20 seconds or so?
"Simplicate and add lightness." - Ed Heinemann
scrubbsywg
Wed Apr 11, 2007 1:55 pm
dont forget that the energy accelerating a plane would still have to come from somewhere. Electromagnets, steam, all require energy, and propelling the same plane by a different means still requires the same amount of energy from whatever the source is.
kalvado
Wed Apr 11, 2007 9:07 pm
Quoting 3DPlanes (Reply 11):
Wrong. Either you're talking about small forces - which makes very little sense for the problem, or you're confusing jerk (which is another thing to keep an eye on) with force (which has nothing to do with how gradual acceleration is)
Jetlagged
Wed Apr 11, 2007 9:35 pm
Quoting Kalvado (Reply 13):
What you call jerk is the sudden application of a force. It's still a force though. Never heard of the term jerk as a technical term in this context before.
Force has nothing to do with how gradual acceleration? What about
F = m * a ?
In words, acceleration is proportional to force.
Whether strengthening is required depends on how and where the force is applied.
kalvado
Wed Apr 11, 2007 10:48 pm
Quoting Jetlagged (Reply 14):
I've seen few reliability specs with jerk defined as change in acceleration, d2F/dt2.. Not a very common term, but it is being used.
Regarding force - you need something comparable with engine thrust for entire thing to be meaningful. Engine attachment points are probably strong enough, but I'm unsure if increasing force on those points is possible - just look up any re-engine discussion here.
Landing gear is not designed to transfer strong forward acceleration (OK for strong negative acceleration, aka stopping though - but that doesn't guarantee anything for forward acceleration). In general, attaching any external device (with high external force being applied) to any point of structure without reinforcement means that either structure is designed for that, or the structure was excessively strong (aka heavy) in that point, since it can handle much more than required in normal operation..
Wed Apr 11, 2007 10:52 pm
Not necessarily. The reason carrier aircraft are balls to the wall before the cat releases is that they need to ensure they are balls to the wall when they reach the end of the run all of 2 seconds later. With a long runway, there's much more time for run-up during the shot. But then we get into decision speeds.
Quoting ScrubbsYWG (Reply 12):
Indeed. But by saving fuel on the aircraft, the aircraft is lighter overall, so you save fuel overall.
Well, planes get towed all the time. That proves the gear legs can drag the whole plane after them. So the weight of the plane. It's a question of how fast the aircraft is accelerated. By hooking onto the mains, you can apply at least twice as much force as a current tug. Probably more.
Just to be clear, I intended this thread to be an intellectual exercise. I don't really think this kind of system is feasible any day soon.
Thx for the great replies and keep them coming.
kalvado
Wed Apr 11, 2007 11:04 pm
Quoting Starlionblue (Reply 16):
OK, so you would probably be able to accelerate the plane to 10 mph instead of 5.
You need a shitload of power to accelerate the plane - and to transfer that to the frame. Just as a simple examle - you can probably roll your car by pushing the bumper (breaks released, transmission neutral). Just imaging same thing being done by another car all the way to 60 mph (100 km/hr)..
Or, just looking at it power-wise, I've never seen a tug powered with anything remotely as strong as GE90..
Sometimes such crazy discussions generate really cool ideas. I didn't get anything patentable on this page yet - but I'll keep an eye on it  Wink
Wed Apr 11, 2007 11:11 pm
Quoting Kalvado (Reply 17):
There is no need to subject the gear legs to large forces. Slow, gradual acceleration will work, unless it's too slow to get up to speed.  Wink
Power requirements for towing up to a nice speed are something else, and of course vastly exceed those of current tugs. Then again, "direct drive" is probably more efficient than a jet engine while rolling along on the ground. Otherwise high speed trains would be powered by jet engines like Aérotrain.
KELPkid
Wed Apr 11, 2007 11:56 pm
Quoting Starlionblue (Reply 18):
Don't know which Aerotrain you are referring to, but if it's the American one:
Big version: Width: 720 Height: 542 File size: 83kb
This one was powered by a 1200 HP diesel-electric powering the front truck only...
There was one jet-powered train in the US that I'm aware of:
Big version: Width: 500 Height: 421 File size: 119kb
Which currently holds the North American rail speed record at 184 MPH...and, by the way, that's an engine pod from a Convair B-36 Peacekeeper up on the roof  Wink AFAIK, this is the only rail vehicle to ever be directly powered by a jet engine...(direct propulsion instead of turbine-electric or turbine-hydraulic).
Thu Apr 12, 2007 12:10 am
Quoting KELPkid (Reply 19):
It's the French one. Was not aware of an American one. Cool! That American one really has that brute force US railroad look. Just a big steel plate in the front. Wow. I wonder how much noise it made.
Actually, the French Aérotrain was also jet powered directly. http://en.wikipedia.org/wiki/A%C3%A9rotrain.
http://upload.wikimedia.org/wikipedia/commons/2/29/Aerotrain.jpg
Aérotrain was one of the early TGV options. The next was a turbine powered wheel drive variant called TGV001, which looked pretty similar to the early in service TGVs. TGV001 still holds the record for a turbine powered rail vehicle. After the 70s oil crisis conventional electric drive with a catenary was selected.
Schienenzeppelin was also non wheel powered, using a propeller. http://en.wikipedia.org/wiki/Schienenzeppelin. One of main issues there was how to make the train longer. The prop gets in the way. Schienenzeppelin held the rail speed record for 23 years, and still holds the speed record for a gasoline (petrol) powered rail vehicle, at 230kn/h.
[Edited 2007-04-11 17:11:01]
vikkyvik
Thu Apr 12, 2007 1:19 am
Just to throw some theoretical numbers in here (cause I'm currently too distracted to do any real work):
Say you have a 100,000 kg airplane accelerating on takeoff to 175 mph (78.4 m/s). Assume it takes 25 seconds to reach this velocity.
So, you have:
v = 78.4 m/s
m = 100,000 kg
t = 25 s
a = v/t = (78.4)/(25) = 3.13 m/s^2
So your average force over the acceleration is:
F = m*a = 100,000 * 3.13 = 313,000 N ( = 70,370 lbs)
And your takeoff distance is:
d = 0.5*a*t^2 = 0.5 * 3.13 * (25)^2) = 978 m (3208 ft)
That force is the average thrust minus the average drag over the takeoff run - and it's a significant amount of excess thrust, which is obviously needed to keep the takeoff distance down to something reasonable.
So if you can only provide, say, 10,000 lbs of excess thrust (assuming this is what the rail launch can provide), then your takeoff stats become:
a = 0.445 m/s^2
t = 176 s
d = 6892 m (22,606 ft)
and the dry lakebed runways at EDW are suddenly looking quite nice  Smile
Thu Apr 12, 2007 1:47 am
Quoting Vikkyvik (Reply 21):
Lol. Thanks for the calculation. I was envisaging the catapult to be somewhat more powerful. Something like the combined power of both engines on a twin.
I love when topics generate some fun back of the envelope calculations.
vikkyvik
Thu Apr 12, 2007 2:25 am
Quoting Starlionblue (Reply 22):
I figured, but I was just playing around with the idea that was suggested that the gear may not be strong enough to support such forces.
Thu Apr 12, 2007 2:50 am
Quoting Vikkyvik (Reply 23):
Ah.
I have my doubts about the gear struts not being strong enough though. Does anyone really know how strong the gear is that way? Surely tugs occasionally give a good yank to the gear. Also, while braking is pulling "the other way" some of that strength must translate to tugging as well.
FredT
Thu Apr 12, 2007 4:36 am
But not using forces large enough to get any significant acceleration. Besides, the magnitude is not the only thing you have to consider. There's also how often and for what duration. A recent example is when Ryanair thought about towing the aircraft to the runways to save on taxi fuel. They found out that the aircraft simply weren't certified for that amount and that kind of towing, so they'd need recertification and quite likely structural modification first...
Thu Apr 12, 2007 5:19 am
Quoting FredT (Reply 25):
See, even O'Leary thinks I'm not nuts! Big grin
FredT
Thu Apr 12, 2007 6:13 am
Quoting Starlionblue (Reply 26):
Tomorrows debate: Is that good or bad? Big grin
Users browsing this forum: Yahoo [Bot] and 1 guest
