WestJetForLife
737 Type-rating Question
Tue Apr 10, 2007 5:53 am
Hi, all.
I have a question about type-ratings in the 737 series.
Is it possible for 737-rated pilots to fly all types of the 737 (eg. a pilot can fly both a 737-200 and a 737-700), or are you just strictly considered a 737-200 or 737-700 pilot.
Much thanks in advance,
Nik
I need a drink.
highflyer9790
RE: 737 Type-rating Question
Tue Apr 10, 2007 6:24 am
There are some aircraft that have a "common" type rating, meaning you are "certified" for both types. In the case of the 737, the NG series are considered a common type, i.e. the 600/700/800/900. The "classic 737s are a separate type rating to the NG series, but are the 100/200 are common and the 300/400/500 are common, if im not mistaken. i am not positive about the classics, but i do know the NG series is one.
other common type ratings:
A318/319/320/321
A330/340 (although training is required to move to the A340)
757/767
highflyer
121
WestJetForLife
Tue Apr 10, 2007 6:51 am
Oh, so if WS still had their 737-200s around (pity they retired them last year), then they couldn't use the 737NG pilots to fly the 737-200s?
I read somewhere that a WN 737 pilot flew legs in the 737-300, along with the 737-500 and -700. Is this because the 737-700 cockpit can be designed to have a layout like a 737-300/500 cockpit?
Thanks again,
Nik
I need a drink.
Jetlagged
Tue Apr 10, 2007 7:36 am
AFAIK, there is only one 737 type rating. Differences training is all that is required to switch from one version to another.
highflyer9790
Tue Apr 10, 2007 8:13 am
o of course! how could i have mislead myself!  banghead
the 737 is only ONE type rating, but there is training to transfer to the NG series....
121
WestJetForLife
Tue Apr 10, 2007 11:41 am
Quoting Jetlagged (Reply 3):
Thanks, Jetlagged! That really answered my question.
Nik
I need a drink.
movingtin
Tue Apr 10, 2007 7:00 pm
Quoting WestJetForLife (Reply 2):
The the Primary Flight Display (PFD) can be programed to any configuration an airline wants, so SWA has their displays showing individual instrument displays instead of a combined display.
Jetlagged
Tue Apr 10, 2007 7:19 pm
Quoting Movingtin (Reply 6):
To paraphrase Henry Ford, any configuration you want as long as it's on Boeing's list.  Wink
Southwest opted for this to reduce the differences training required when converting from the Classic to the NG. I personally think the better information display in the PFD format provides is worth the extra training, but then again Southwest has a lot of pilots to be trained and the bean counters rule.
pilotaydin
Wed Apr 11, 2007 2:01 am
there are a certain number of differences that need to be covered, such as pack operation on ground, APU inflight bus powerage, and also a couple of new systems onboard the 737NG such as the EEC and the GPS, although we do not use the GPS it is onboard and enables VNAV and LNAV approaches into tricky airports....
aside from that nothing much is different, the engines have autorelight and also have certain protections during startup....difference training is just 8 hours with one checkride at the end...
The only time there is too much fuel onboard, is when you're on fire!
SansVGs
Wed Apr 11, 2007 2:06 am
The FAA type just says "737." But is it different in Europe? In the back of Flight International there are many job postings for pilots with specific model designations.
Quoting Jetlagged (Reply 7):
Supposedly (because the human brain is an analog instrument) we see trends on the dials better. A needle sweep is said to be easier to comprehend. Do you agree?
Winglets on a Falcon are "over-painting" a great work of art.
Jetlagged
Wed Apr 11, 2007 7:00 am
Quoting SansVGs (Reply 9):
Certainly, especially for engine indications. Pointer rate is the cue that is useful, but the ASI and altitude pointers don't actually move that fast (unless things are going very badly). However the PFD speed tape has a trend vector which makes it better than the old style fast/slow doughnut. The PFD/ND format is extremely informative and becomes second nature to read. The "poor relation" on the PFD is the VSI scale, that should be improved somehow.
amtrosie
Thu Apr 12, 2007 12:51 am
They are typed to fly all models of 737's. Many times their pilots would fly a NG in and take out a classic(300 or 500), or a Jurasic (200). It all was in the cockpit displays, so no cross-training was involved.
LASoctoberB6
Thu Apr 12, 2007 6:22 am
Quoting Amtrosie (Reply 11):
or a Jurasic
i like that....
[NOT IN SERVICE] {WEStJet}
WestJetForLife
Thu Apr 12, 2007 8:19 am
Now, same question, different airplane.
Can you be cross-typed in the 747-200 and 747-400, or do you need separate type-ratings for each?
Nik
I need a drink.
ShyFlyer
Fri Apr 13, 2007 1:55 am
Quoting WestJetForLife (Reply 13):
I believe they are separate type ratings.
BAE146QT
Fri Apr 13, 2007 8:35 am
I absolutely agree with this.
I hope no-one minds if I go off-forum for a minute, but I have inlet temp, transmission oil temp and manifold depression guages on one of my cars. Under the conditions it is driven, it is important that I have that infomation *quickly*. A needle is far better at conveying it than an LCD number.
Geting back on topic, wasn't the engine vibration meter on the 737 redesigned after Kegworth for exactly this reason? I seem to remember that among other things, its visibility at a glance was a causatory factor in that crash.
Todos mis dominós son totalmente pegajosos
Jetlagged
Fri Apr 13, 2007 9:42 am
Quoting BAe146QT (Reply 15):
No, it remains as poor as ever. The report criticised the lack of prominence of the vibration indication, but nothing was done. The report also drew attention to the fact that vibration monitoring was now much more accurate than it used to be when high indications were often ignored if everything else looked OK. It stressed that crews should pay much more attention to high vibration indications.
Users browsing this forum: No registered users and 21 guests
