LASoctoberB6
Finding A VORs Course And HDG.....?
Sat Apr 14, 2007 2:02 pm
how can i use VORs? the only way i know to use them is for DME purposes, i want to stop using the gps and start doing it the old fashioned NAV way....i need a small description (big long black and white pages scare me away.....)
[NOT IN SERVICE] {WEStJet}
RE: Finding A VORs Course And HDG.....?
Sat Apr 14, 2007 2:07 pm
Google VOR produced http://www.navfltsm.addr.com/vor-nav.htm
Would suggest any flight school could teach you in a ground based sim, which I would strongly recommend.
LASoctoberB6
Sat Apr 14, 2007 2:27 pm
ugh....black and white and long!! but danke shen  Smile
Mir
Sat Apr 14, 2007 4:28 pm
Mir's Extremely Basic VOR Tutorial:
1) Tune station
2) Listen for proper morse code
3) Turn OBS to desired radial
4) Choose an intercept heading (if ATC doesn't assign one)
5) Wait for needle to center, then turn airplane to the heading that the OBS is set to
6) Make appropriate wind corrections so that the needle remains centered.
If looking to go direct, perform steps 1 and 2, then turn the OBS until the needle is centered with a TO flag, then continue with step 5.
It looks like you're looking for something to use in flight simulator, which is fine, but I would get a lot more information and instruction on this before you try to do the same thing in an actual airplane.
-Mir
LASoctoberB6
Sun Apr 15, 2007 8:11 am
Quoting Mir (Reply 3):
do you choose any radial? how do you find the radial?
Jetlagged
Sun Apr 15, 2007 9:13 am
Quoting LASOctoberB6 (Reply 4):
Mir had that one covered already.  Smile
If you don't want to fly direct to the VOR, but to the VOR on a particular course (e.g. along the airway the VOR is on), then select that course and fly the aircraft on an intercept heading until the needle starts to move to the centre, then turn onto the selected course and fly with the needle centered.
If your using a reasonably modern airliner in flightsim you won't find an OBI or OBS anywhere. Instead there will be an HSI (with a course pointer and course deviation bar) and also an RMI with pointers which show the bearing to the VOR on a compass card. There will be a CRS (course) selector which will move the course pointer on the HSI around. As with an OBI, the deviation bar will be centered when the course pointer is aligned with the VOR.
G4LASRamper
Sun Apr 15, 2007 1:13 pm
One can also play with Tim's Air Navigation Simulator to get the hang of of both VOR and NDB navigation. I used to use this java app when I taught navigation at the local community college aviation program. The simulator provides various displays including an HSI and RMI. Pretty slick app I thought! The link:
http://www.visi.com/~mim/nav/
"A pig that doesn't fly is just a pig." - Porco Rosso
ThirtyEcho
Sun Apr 15, 2007 3:56 pm
G4LASRamper :
RMI? RMI?? RMI???
If you don't fly fixed-card and do the math in your head, you are a big cheater.
Neener, neener, neener.
G4LASRamper
Mon Apr 16, 2007 1:50 am
Yes, RMI. And slaved ADF cards too when I could afford it. None of that crank the card to match the heading stuff for me. Heck, it was hard enough for me to hold a heading long enough to set the card. Math was always my worstest subject. Anything that reduced the need for cypherin' on the flight deck was greatly appreciated.
KELPkid
Mon Apr 16, 2007 6:06 am
Quoting ThirtyEcho (Reply 7):
G4LASRamper :
RMI? RMI?? RMI???
I was taught to mentally superimpose the ADF needle onto the DG...works for me  Wink However, I fear in a couple of years, this will be obsolete knowledge anyways...too bad  Sad I'll take an NDB approach over a localizer back course anyday...
Mir
Mon Apr 16, 2007 7:10 am
Quoting KELPkid (Reply 9):
Same here. Only problem is that it works great in the plane but is absolutely useless for figuring out word problems in ground school. Then I have to dust off the math.  crazy
Surely you can't be serious!  confused
-Mir
KELPkid
Tue Apr 17, 2007 2:28 am
Quoting Mir (Reply 10):
-Mir
For me, the mental gymnastics needed to successfully execute an NDB approach are far less taxing than those needed to deal with a reverse sensing needle  Wink I got plenty of practice with that, too, as the missed approach procedure for the ILS I shot the most of while getting my instrument ticket had you fly the localizer (now reverse-sensing because you're going the "wrong" way) back to the LOM and enter a hold there...and my instructor wouldn't let me flip the "B/C" switch on the OBS head that reverses reverse sensing  Smile
IAHFLYR
Tue Apr 17, 2007 3:53 am
Quoting KELPkid (Reply 11):
What was that instructor thinking??  Big grin
I'd much rather deal with the reverse sensing of a back course than the floating wandering needle known as an NDB approach.
atct
Tue Apr 17, 2007 3:55 am
Quoting LASOctoberB6 (Thread starter):
Wow I feel old and im only 21. All my training was all VOR (heck when I started in the J3, it was take the PA Turnpike map and look for the road on the map hehe).
NDB's, now THATS Old  Smile
ATCT
Trikes are for kids!
ThirtyEcho
Tue Apr 17, 2007 4:03 pm
"NDB's, now THATS Old"
You're making me feel REALLY old. In 1960, I filed and flew what was, possibly, the last 4-course range airway left in the US, Red 10. It was a very interesting experience but I wouldn't want to fly an approach using a range station unless I had Ernie Gann in the right seat.
Fly2HMO
Wed Apr 18, 2007 3:14 pm
I'd avoid both and just do a GPS overlay, or:
Quoting IAHFLYR (Reply 12):
With an HSI it wouldnt even matter....
Quoting ThirtyEcho (Reply 14):
Wasn't the 4 course range first developed around the Paleolithic era? Big grin  duck
In all honesty, considering the simplicity of the system and the technology back then, it was quite a leap.
Yea yea, I know what you old school pilots are thinking. Us noobies are spoiled with all the sweet new gadgets
Speaking of which, I have my multi instrument check coming up soon.
[Edited 2007-04-18 08:21:04]
ThirtyEcho
Wed Apr 18, 2007 4:05 pm
"Wasn't the 4 course range first developed around the Paleolithic era?
In all honesty, considering the simplicity of the system and the technology back then, it was quite a leap"
Fly an Average Bisector Orientation for me before you say "simplicity," pilgrim.
Mir
Wed Apr 18, 2007 10:54 pm
Quoting ThirtyEcho (Reply 16):
Fly a what now?
-Mir
KELPkid
Thu Apr 19, 2007 2:24 am
Quoting FLY2HMO (Reply 15):
Good luck on that!
G4LASRamper
Thu Apr 19, 2007 5:28 am
It's an A... No, it's a N... No, it's a Z... No it's a... Repeat until oriented or declaring minimum fuel.
Fly2HMO
Thu Apr 19, 2007 2:12 pm
Quoting KELPkid (Reply 18):
Good luck on that!
Thanks. Just had the oral part tonight and I passed  Smile
I have the flight for friday, which I'm not as worried about as for the oral.
KELPkid
Fri Apr 20, 2007 2:35 am
Quoting FLY2HMO (Reply 20):
Congrats on passing the oral...
What does the flight test entail? A single-engined instrument approach?
I'm guessing your test will be in the Seminole...IIRC, the Seminole doesn't lose any systems (it's fully redundant electrically and vacuum-wise) when an engine goes kaput.
IAHFLYR
Fri Apr 20, 2007 4:31 am
When I was flying NDB's the plane was lucky to have seats much less an HSI!  Smile
Yeah congrats on the passing of the exam! Best on the checkride.
futurecaptain
Fri Apr 20, 2007 7:06 am
Who using what? You might as well be speaking French.  Smile
Quoting KELPkid (Reply 21):
It always seemed wierd to me. For the multi-engine instrument checkride you end up shooting an approach with one engine inop. I keep on thinking "If I already have my single engine rating, why am I shooting approaches on one engine to get my multi rating?"  confused
Fly2HMO
Fri Apr 20, 2007 7:09 am
Precision apps, non-prec (GPS or VOR out here, no actual NDB thank god!) Single engine approaches and partial panel approaches, holds, and arcs, yeah, the whole deal Big grin
And you're guessing correctly, but the examiner will probably pull the breaker for the HSI to simulate a failure. Upon which I shall begin swearing hehe. We got dual Garmin 430s on them and an MX20, gotta love those things.  yes
Quoting IAHFLYR (Reply 22):
ROFL  rotfl
Thanks! Got the flight scheduled for tomorrow 4/20 in the afternoon. Git r' dun! Big grin
G4LASRamper
Fri Apr 20, 2007 11:33 am
Yes, good luck to you on that! I'm sure you'll do well, since you've already got the oral out of the way.
When I took mine I didn't have a multi rating yet, so took it in a Warrior. At that time I didn't have to demonstrate any instrument ride items when I took the multi the following year. Of course I did have to do it all again when I took the ATP rides, multi and single.
Have a good ride!
