jeffry747
DC-8 Landing Gear Doors Open On Ground. Why?
Tue Apr 17, 2007 8:50 am
I have always noticed that when after a DC-8 (UPS DC-8s in particular) blocks in and shuts down after a flight, the first thing Mx on the ground will do is walk under the aircraft and pop open the main landing gear doors. It is occasionally done on 727s but ALWAYS on the DC-8. The doors will then be left open until the aircraft is started up for its next flight. Why is this done?
C'mon Big B, FLY!
fr8mech
RE: DC-8 Landing Gear Doors Open On Ground. Why?
Tue Apr 17, 2007 9:15 am
Because there is no way to look in the wheel well with the doors closed. The B727 & the DC8 maintenance program (as UPS operates the aircraft) require that maintenance check certain items in the wheel well after each flight where ground time is in excess of 2 hours. You can easily see into the wheel wells of B727 aircraft. Some will open the doors to check and service the APU oil (on a B727).
Tue Apr 17, 2007 5:07 pm
To Facilitate Maintenance Inspections as per Schedule.
regds
MEL
Steve332
Tue Apr 17, 2007 11:16 pm
I done my school work experiance programme at DUB with EI's 330's. We done the same thing and also opened the main gear doors for a daily inspection.
SFOMB67
Wed Apr 18, 2007 2:34 pm
[quote=Jeffry747,reply=0]The doors will then be left open until the aircraft is started up for its next flight.
Been awhile since I've shut these doors. They can really have a nasty snap if you release the (door release/closure) handle too fast!
747400sp
Thu Apr 19, 2007 12:51 pm
Quoting Fr8mech (Reply 1):
Do have to do these maintenance check inj the wheel well of 707s?
Thu Apr 19, 2007 3:27 pm
Quoting 747400sp (Reply 5):
It depends on the Scheduled check due.
regds
MEL
fr8mech
Thu Apr 19, 2007 6:14 pm
Don't know. The only thing I ever did was service engine oils on B707 aircraft.
Unless something needs servicing, the only thing being done on a DC8 is visual inspection of the various hydraulic components installed in the wheel wells.
MD11Engineer
Thu Apr 19, 2007 7:38 pm
Quoting Fr8Mech (Reply 7):
On the 727 on turnarounds we just lookeed into the wheel well with closed doors, but on weekend checks we had to check the precharge pressure on the brake accumulator and APU oil. For this you'll have to open the L/H main wheel well door.
The 707 has a higher landing gear than the 727. I would need to open the wheel well door on this plane to have a good look. The mechanism for opening and closing the main wheel well doors is the same as on the 727.
Jan
113312
Fri Apr 20, 2007 5:18 pm
On the DC8, you inspect hydraulic reservoir and accumulators. On the727, unless maintenance or inspection is required, nearly everything that needs to be seen for preflight can be viewed with the doors closed. However, APU cooling during warm weather can be improved with the right main gear door opened.
Users browsing this forum: BobbyPSP and 1 guest
