sprout5199
Birds On An Airplane
Thu Apr 19, 2007 9:46 am
Tonight on Mythbusters(9pm on Discovery), they test the "birds on an airplane" myth.  bigthumbsup  But they will use a truck.  Sad
Now I wonder if the truck will be moving on a huge conveyor belt at the same time.
So now we will know the truth about this hotly discussed topic.
Dan in Jupiter
2H4
RE: Birds On An Airplane
Thu Apr 19, 2007 9:52 am
It seems silly to use a truck. Why not just put the birds in a large cylinder supported on scales in controlled conditions?
2H4
Intentionally Left Blank
sprout5199
Thu Apr 19, 2007 10:11 am
Thats the "small scale" test.
I say just jump to the A380 with about a million birds.
Dan in Jupiter
2H4
Thu Apr 19, 2007 10:15 am
Quoting Sprout5199 (Reply 2):
Too dangerous. When the birds take flight, the airplane will exceed Mach 1 and rocket up to the edge of space, even with the engines at idle and speed brakes deployed.
2H4
MDorBust
Thu Apr 19, 2007 10:24 am
Quoting Sprout5199 (Thread starter):
... But they will use a truck.
Is it made out of chicken wire?
"I KICKED BURNING TERRORIST SO HARD IN BALLS THAT I TORE A TENDON" - Alex McIlveen
sprout5199
Thu Apr 19, 2007 11:08 am
Quoting 2H4 (Reply 3):
And when in space, if the birds poop, do they get shot forward at lightspeed?
The show was ok. The best part was using the model helicopter, and dropping the boat from the crane by the hottie Kari.She can bust my myth anytime.
Dan in Jupiter
nirmalmakadia
Tue Apr 24, 2007 9:28 pm
Quoting MDorBust (Reply 4):
 rotfl   rotfl   rotfl   rotfl
[Edited 2007-04-24 14:29:59]
[Edited 2007-04-24 14:31:22]
airfoilsguy
Tue Apr 24, 2007 10:39 pm
If a bird with a truck on its back was running on a conveyor with a plane chasing it in the rain, would the rice taste funny in the southern part of China on a Monday afternoon?
It's not a near miss it's a near hit!!
Ralgha
Wed Apr 25, 2007 2:28 am
Why are they testing this? The weight of the airplane wouldn't change regardless of what the birds are doing. They must be scraping the bottom of the barrel for their show.
cftoa
Wed Apr 25, 2007 2:13 pm
Quoting 2H4 (Reply 1):
I agree with 2H4, the use of the truck is somewhat stupid in my opinion.. Mythbusters is an interesting show, but they always seem to deviate from their original intended myth slightly due to insurance reasons, and other factors. I remember watching one episode where they wanted to see if a 737-200 could blow over a mid size sedan.. unfortunatly, instead of using a 737, or a JT8D-7 turbofan for that matter, they used a much smaller 'jet engine' because of insurance reasons.. Needless to say, the car didn't blow over  Yeah sure insurance companies ruin it for all of us  Wink
Cheers.
Tyson McAuley
darkblue
Wed Apr 25, 2007 11:25 pm
Quoting CFTOA (Reply 9):
Not sure if I follow your post. You criticize them for using a truck, but then criticize them again for deviating from the original myth for insurance purposes. In this case, they tested the myth exactly as it came to them, no deviation. The myth was not birds inside a plane, but rather when transporting birds inside a truck, does the truck get lighter if you stir up the the birds (for going over weight-limited bridges).
Quoting Ralgha (Reply 8):
I guess I disagree with you here, I actually thought it was pretty interesting to see, although maybe it's just because I'm engineer. We tend to enjoy seeing experiments that confirm analytically calculated projections. I only wish that they would have made a container out of chicken wire to show the difference.
cftoa
Thu Apr 26, 2007 7:19 am
Quoting DarkBlue (Reply 10):
Alright, well, I'm not too sure if I follow this thread then, seeing as it is called 'Birds On An Airplane' not 'Birds On A Truck'  Yeah sure
Cheers.
MDorBust
Thu Apr 26, 2007 8:13 am
Quoting CFTOA (Reply 11):
"Birds on an Airplane" is an infamous subject in Tech Ops.
RE: Hypothetical Question... (by David L Feb 26 2006 in Tech Ops)
Not nearly as infamous as, Planes on Treadmills.
RE: If A Plane Took Off A Conveyor Belt... (by GRZ-AIR Dec 29 2005 in Tech Ops)
Thu Apr 26, 2007 9:23 am
That's basically what they do.
I know this. You know this. But some people need to see experimental results.
Also, Mythbusters has always had some "out there" stuff. It's not the myths themselves, it's how they do them that is the appeal.
BTW, there was no change in weight. But Jamie and Adam are certain this will not calm the raging debate on the Mythbusters forums. Big grin
Users browsing this forum: WPvsMW and 3 guests
