MANisnumber1
What Is A Green Field Airport?
Sun Apr 22, 2007 2:41 am
what exactly is a green field airport?
U2 MAN-ALC-MAN, BA MAN-LHR-SFO, BA SEA-LHR-MAN...Summer 2010!
bravogolf
RE: What Is A Green Field Airport?
Sun Apr 22, 2007 2:56 am
It is an airport built on undeveloped land usually outside of a city.
DFWEagle
Sun Apr 22, 2007 2:58 am
Quoting MANisnumber1 (Thread starter):
A Greenfield airport is one which is built from scratch on a new (undeveloped) site. Therefore, it has no constraints due prior work/existing infrastructure etc.
Ryan / HKG
RDUDDJI
Sun Apr 22, 2007 11:20 am
Green Field = or != Grass Strip?
Sometimes we don't realize the good times when we're in them
sammyk
Sun Apr 22, 2007 11:23 am
Quoting RDUDDJI (Reply 3):
Nothing to do with a grass strip, just where it is built. I suppose you could build a small airport with a grass strip on undeveloped land and call it a green field airport but that is not what "green field" airport typically means.
If you build an airport on previously developed land it could be called a brown field airport.
MANisnumber1
Sun Apr 22, 2007 7:06 pm
thankyou very much. i was just reading about Islamabad having a new green field airport.
blrBird
Mon Apr 23, 2007 6:21 am
Check out these two airports both are green field airports..
www.bialairport.com
www.newhyderabadairport.com
from star dust....
NoWorries
Wed May 09, 2007 12:33 am
Just as an aside, in a similar vein, greenfield is sometimes used to describe new technology projects that aren't constrained by what has come before it, or an operating mode that isn't constrained by compatibility with previous versions ( for example, in order to offer maximum performance, a WiFi network might operate in 802.11n "greenfield" mode where it doesn't attempt to detect or coexist with earlier versions of the network)
Users browsing this forum: gloom and 1 guest
