2H4
Very Strange PT-6 Exhaust
Tue Apr 24, 2007 8:52 am
So I ran across these photos of a Caravan:
Photo © Michael Durning
Photo © Peter Stuhlmann - CYOW Airport Watch
...and I can't figure out why the exhaust has been extended. Here's a shot of the same aircraft with the standard exhaust:
Photo © Jean-Luc Poliquin
If anyone knows the purpose of this mod, I'd love to hear it.
2H4
Intentionally Left Blank
zanl188
RE: Very Strange PT-6 Exhaust
Tue Apr 24, 2007 8:58 am
I'll hazard a guess and say the exhaust was interfering with a sensor or was being recirculated into the cabin thru what appears to be a large opening in the fuselage bottom.
KELPkid
Tue Apr 24, 2007 9:07 am
Quoting ZANL188 (Reply 1):
 checkmark
I'll second that vote...I wonder why the Mounties need a large trap door in the floor? Did they get the plane from the department of fish & wildlife, who used it for re-stocking lakes and streams?  confused
lowrider
Tue Apr 24, 2007 9:14 am
Since this is the case in other aircraft, I assume it is here, too. All that hot exhaust could screw up an IR picture.
Proud OOTSK member
KELPkid
Tue Apr 24, 2007 9:22 am
Quoting Lowrider (Reply 3):
However, most law enforcement aircraft that I've seen equipped with a FLIR (Forward-looking Infrared) system use a pod with a dome that houses a camera that swivels on a gimbal...sure it knocks a few knots off the top cruise, but it works. I wonder if that's what's behind trapdoor #1  Smile
2H4
Tue Apr 24, 2007 9:29 am
Thanks for the input, guys. Good stuff.
Quoting KELPkid (Reply 2):
Actually, I think it was originally used for tactical flannel drops and Molson replenishment in remote locations.  Wink
2H4
KELPkid
Tue Apr 24, 2007 9:33 am
Quoting 2H4 (Reply 5):
2H4
Or maybe it was the aircraft used to drop Dudley Dooright into the backwards-facing position on his faithful horse, Faithful Horse  duck
N231YE
Tue Apr 24, 2007 9:34 am
Could be for an aerial photography company (exhaust gasses produce that "heat blur," a no-no in professional photographs of the ground).
There is an aerial-photography company based at my university's airport, and all of their C172's have a weird looking exhaust stack extension that empties at the pilot's side of the a/c, further than the rear window.
Tomorrow, when I am out at the flight line, I will try to get a photo of one of these aircraft.
KELPkid
Tue Apr 24, 2007 9:37 am
Quoting N231YE (Reply 7):
Do the Mounties (Royal Canadian Mounted Police) regularly engage in aerial photography?
N231YE
Tue Apr 24, 2007 9:43 am
Quoting KELPkid (Reply 8):
Maybe to make sure that the United States military isn't secretly mobilizing to invade Canada?  mischievous
zanl188
Tue Apr 24, 2007 9:53 am
Maybe...
A large format camera..
Lidar
Mysterious WMD sensor
KELPkid
Tue Apr 24, 2007 10:06 am
Quoting ZANL188 (Reply 10):
Or the deployment thereof...  Wink Maybe it's for the planned Canadian invasion of the USA (and we're not talking Celene Dion or Rick Moranis here...)  Smile
zanl188
Tue Apr 24, 2007 10:38 am
Quoting KELPkid (Reply 11):
planned
"planned"? Alex Trebek, Paul Shafer, and William Shatner are already here...  Smile
USCGC130
Tue Apr 24, 2007 10:45 am
Is the Caravan the only PT6-powered aircraft that uses an under-fuselage exhaust instead of those lateral "horns," as on King Airs and T-34Cs?
I read an article in one of the avgeek magazines a year or so ago about the owner of a gorgeous Caravan on amphibious floats, and how he uses the plane for both business and pleasure. The Caravan's exhaust is mounted at a slight angle, and he takes advantage of this when taxiing up to a dock. He'll place the prop in flat pitch and wind up the engine; the thrust from the exhaust will provide enough of a lateral vector to move the plane sideways to the left. Nifty.
lowrider
Tue Apr 24, 2007 12:06 pm
Quoting KELPkid (Reply 4):
That works great for tactical "live" situations, but developing a large scale IR map of an area has its uses. For example it is one method to locate drug operations.
You know, if we went up there and got cases of the good Molson, then drop it after we cross the border, before we clear customs, and use a GPS to go back to it later...
Proud OOTSK member
2H4
Tue Apr 24, 2007 12:11 pm
Quoting Uscgc130 (Reply 13):
With the obvious exception of helicopters, I think that's correct. The Dash-7 and Basler BT-67 have exhaust mounted on top of the nacelles. The Piper Cheyenne 400 and Casa C-212 have rear-mounted exhaust. The Caravan, however, appears to be the only one that utilizes a single under-fuselage exhaust.
That's great.  biggrin
2H4
L-188
Tue Apr 24, 2007 12:20 pm
Quoting 2H4 (Reply 15):
Both those aircraft are also powered by TPE-331's not PT-6's.
As far as the pipe, don't know but I bet it works great for keeping soot stains off the airplane.
2H4
Tue Apr 24, 2007 12:41 pm
Quoting L-188 (Reply 16):
Blast. You're right. I was thinking of the -300P variant of the 212, which has the PT6A-65s, and I think I got the Cheyenne III and 400 mixed up. Clearly, it's time for bed.
2H4
Tue Apr 24, 2007 8:48 pm
Quoting Lowrider (Reply 14):
Exactly what is would be for, IR photos are good for finding drugs in a forest or for taking high altitude photos of a fire.
KELPkid
Wed Apr 25, 2007 9:51 am
Yeah, then we could call you D. "Beer" Cooper Big grin
Beaut, eh?  Wink My apologies to the forum members from the Great White North...
lowrider
Wed Apr 25, 2007 1:08 pm
Quoting KELPkid (Reply 19):
Beaut, eh?
Careful, the punishment for such offenses is death, by Celine Dion.
Proud OOTSK member
LJ35
Wed Apr 25, 2007 5:46 pm
To answer 2H4's question,the extended exhaust pipe is only mounted on this plane when the FLIR is in place.If you look at the first photo attached(select the large format)the FLIR is mounted underneath the port wing directly on the "U" in the aircraft registration(it is black in colour).In case your wondering why I know this,I fuel this aircraft on a daily basis given that it is based at CYOW(Ottawa,Ontario).The other cool thing about this Caravan and the other 2 that the RCMP operate is that they are configured for single point refuelling in addition to the standard overwing method.The single point hook-up is located port side right behind the main gear.Interesting fact about the single point fuelling system on this aircraft is that it won't completely fill the tanks(about an hour's less flying time when fully fuelled via the single point method).This system has been a godsend when they show up with their amphib caravan once in a while.
KELPkid
Thu Apr 26, 2007 12:13 am
Quoting LJ35 (Reply 21):
Do you know anything about the mysterious trap door on the bottom of the fuselage, and why that's there?  Smile
airfoilsguy
Thu Apr 26, 2007 4:10 am
Would the extension cut down on some of the noise inside the cabin? Also, what kind of performance penaltys does this aircraft experience when the extension is mounted.
It's not a near miss it's a near hit!!
Fly2HMO
Thu Apr 26, 2007 11:16 am
OK guys seriously you're all thinking WAY too deep into this.  sarcastic
That's the test plane Flowmaster just started using for inflight tests for their new aircraft sport exhaust line. Big grin
 duck
2H4
Thu Apr 26, 2007 12:24 pm
Quoting FLY2HMO (Reply 24):
Not shown are the "Trucknutz" hanging between the gear legs:
2H4
Users browsing this forum: meecrob, Starlionblue and 1 guest
