meister808
A320 Nose Gear Retraction
Wed Apr 25, 2007 6:08 am
Ok folks, I guarantee this has been discussed before, but I can't find it - does the A320 family nosewheel turn 90° on retraction into the nose wheel well, or does it go straight forward? I can't seem to find anything that would suggest that it turns, but the topic came up in discussion and there's more than a few people I know that insist such a design was the reason for the well-publicized Jetblue incident at LAX last year.
Am I missing something?
-Meister
[Edited 2007-04-24 23:19:05]
b78710
RE: A320 Nose Gear Retraction
Wed Apr 25, 2007 6:15 am
most nose gear have whats called a centering cam which ensures the nose gear is straight before retraction, if it isn't it will not retract! the gear probably wouldnt even fit into the bay if it was at 90 degree's.....but dont quite me on that!
wasn't the jet blue incident something to do with some kind of nose wheel steering failure causeing it to go full one way?
Tristarsteve
Well wrong twice.
It doesn't turn 90deg, and it goes straight forward, not back.
The only gear I know that turns 90deg is the HS Trident MLG. This MLG had 4 wheels on a single axle, and rotated 90 deg on retraction to fit into the wing.
meister808
Wed Apr 25, 2007 6:20 am
Thanks - fixed the forward/back thing, brain fart on my part
Good to know I wasn't crazy.
-Meister
Viscount724
Wed Apr 25, 2007 11:35 am
Quoting TristarSteve (Reply 2):
That wasn't the Trident's only unusual landing gear feature. It also had the strange off-center nosegear that retracted sideways. As I recall that was to facilitate the location of the Trident's then state-of-the-art autoland equipment.
Photo © Ray Pettit
Photo © Steve Petch
rwy04lga
Wed Apr 25, 2007 12:19 pm
The USAF XB-70 MLG also rotated 90 degrees before retracting rearward.
Check THIS out! http://www5a.biglobe.ne.jp/~t_miyama/b70leg01.html
Just accept that some days, you're the pigeon, and other days the statue
Wed Apr 25, 2007 4:28 pm
The centering cams will locate the NLG wheel in a Straight line along the Longitutional axis when the strut extends.
regds
MEL
Tristarsteve
Wed Apr 25, 2007 5:10 pm
Quoting Viscount724 (Reply 4):
There was a myth around that the NLG retracted sideways so that the nose wheels did not hit the centre line landing lights when doing Cat 3 autoland.
PGNCS
Fri Apr 27, 2007 10:04 am
It centers. In my A-320 AOM under the topic of Brake and Steering Control Unit (BSCU) it says "An internal cam mechanism returns the nose wheel to the centered position after take-off."
Hope this helps!
Mir
Fri Apr 27, 2007 3:35 pm
Don't the main gear of the Tu-144 do some kind of funky retraction?
-Mir
Fri Apr 27, 2007 3:56 pm
Quoting Mir (Reply 9):
Watch the Bounce.
regds
MEL
Tristarsteve
Fri Apr 27, 2007 6:05 pm
Also the Trident mainwheels were single wheels with two tyres on each wheel. I remember the trouble we had getting them off. They seemed to be an interference fit over the brakes, and more than once we had to remove the whole wheel/brake assy because the wheel would not come off!
Also strange was the emergency lowering of the gear. This used a compressed air bottle which blew high pressure air into the normal retraction jacks. You then had to use a turner adaptor to let the pressure out on the ground.
There was a lot of engineering on the Trident.
memphis
Thu May 17, 2007 7:24 pm
hey, isn't that the airwolf soundtrack???
nocturnal
Mir
Fri May 18, 2007 1:25 am
I heard it was because the autoland system was too good, and was putting the nose gear down right on the runway lights, which created a lot of vibration, so they chose of offset it.
-Mir
Fri May 18, 2007 2:45 am
Quoting Memphis (Reply 12):
Hehe. Certainly is.
Man that was loud inside!
baw2198
Fri May 18, 2007 7:59 am
Quoting Meister808 (Thread starter):
some aircraft that do are
The Beechcraft Sierra the nose wheel turns 90 and then retracts backward and the Piper Malibu (the older ones without the gear doors) which retracts in the same manner as the Sierra.
"And remember, Keep your stick on the ice"--->Red Green
Fri May 18, 2007 3:12 pm
Quoting BAW2198 (Reply 15):
I don't think the A320 Nose Wheel turns 90deg on before retraction.The centering cam ensures its Straight.
regds
MEL
DH106
Fri May 18, 2007 6:49 pm
Quoting HAWK21M (Reply 16):
Exactly - what would be the point?
Twin wheels are pretty much as wide as long so no real space saving.
Usually when they turn on retraction it's so a single wheel can lie flat and save space.
...I watched c-beams glitter in the dark by the Tanhauser Gate....
baw2198
Fri May 18, 2007 10:24 pm
regds
HAWK, I wasn't saying that the 320 did. Everybody above already answered that, I was just giving examples of planes that did use that retraction method.
moo
Fri May 18, 2007 11:35 pm
Quoting B78710 (Reply 1):
There was a very good reason for the Jet Blue incident last year, and infact the actions of the nose gear on that occasion was by design.
When the A320 series leaves the ground, a mechanical cam system centres the gear (as Hawk21M said). If this mechanism fails, the gear system does not infact know where the wheel is pointing with any certainty.
In order to provide for a safe landing in this case, the gear is rotated until it locks at the 90 degree point - its safer to land in this way and destroy the front gear and strut than it is to land with the gear facing an unknown direction with the potential for an uncontrolled forward motion off the central axis at speed.
Thats the reason for the 90 degree rotation.
Sun May 20, 2007 12:06 am
Quoting BAW2198 (Reply 18):
My Apoligies.Guess I read the sentence Differently.
regds
MEL
320tech
Sun May 20, 2007 6:29 am
Quoting Moo (Reply 19):
As far as I can tell, this isn't true. This incident had nothing to do with a failure in the centring cam, and there's hardly anything in there to fail, anyway.
It was actually a failure in the nosewheel steering system. An oring failed, causing hydraulic pressure to turn the wheels over to the mechanical stop, which is at the (approx, I forget) 86 degree position. This has happened several times.
You can read the article on Jet Blue flight 292. http://en.wikipedia.org/wiki/JetBlue_Airways_Flight_292
The primary function of the design engineer is to make things difficult for the manufacturer and impossible for the AME.
Sun May 20, 2007 10:05 am
Quoting 320tech (Reply 21):
If we ignore for a second the cause, didn't the gear go to the mechanical stop at about 90 degrees? That would seem to be the objective right?
320tech
Sun May 20, 2007 12:57 pm
Quoting Starlionblue (Reply 22):
Well, my point is that having the gear rotate isn't a design feature, it's just the way it happens in that particular failure. I think the A320 is a well-designed airplane, but let's not give Airbus more credit than they deserve.  Smile
Sun May 20, 2007 6:04 pm
What was the ADs Instructions like.
regds
MEL
troubleshooter
Wed May 23, 2007 1:23 am
Quoting HAWK21M (Reply 24):
FAA AD 99-23-09
This is the only one I could find in a minute...
This job sucks!!! I love this job!!!
Wed May 23, 2007 2:41 am
Quoting 320tech (Reply 23):
From what I have heard it is in fact a design feature. I may be wrong of course.
320tech
Wed May 23, 2007 5:05 am
Quoting Starlionblue (Reply 26):
I may be wrong, too. I'll see what I can find next time I'm at work.
Wed May 23, 2007 6:34 pm
Quoting Troubleshooter (Reply 25):
requires modification of the electro-distributor for the nose wheel steering servo-control
Thanks.
regds
MEL
David L
Thu May 24, 2007 4:44 am
I seem to recall from previous discussions that it was considered safer to land with the nose gear stuck 90o off-centre, producing no tendency to veer to either side, than with it stuck at, say, 15o off-centre, which may result in a severe tendency to steer off-centre at landing speeds.
But I may be even wronger.
Users browsing this forum: GalaxyFlyer, iuwnaa, pikachu, WesternDC6B and 20 guests
