Fly2HMO
A Supersonic Propeller Driven Aircraft, Possible?
Thu Apr 26, 2007 1:04 pm
I just had this random thought about prop planes and speed records, and I was wondering if it was feasible, with current techonlogy, to have a propeller driven aircraft (would have to be a turboprop obviously) flying at the speed of sound, if not more. The current record holder for fastest Turboprop according to the FAI is the Tu-114 at 871.38 km/h (about 545 mph). This record was set way back in 1960 by the Russians (or should I say Soviets? Big grin ), back when the cold war was getting pretty warm.
Photo © Mel Lawrence
Photo © Pereslavtsev Dmitry
The one major problem is of course, the props would be going supersonic before the plane ever left the ground, and eventually there will be a speed where the incoming air on the prop would be so fast that the prop would have an effective AoA of 0, among many other things.
Now what could be done to reach supersonic flight with a prop? How about extremely swept scimitar blades? Would you want 2 blades or 8? And while we're at it, are counterroating props faster than normal props?
Every and any insight welcome, specially those of you who know plenty about fluid dynamics and other hocus pocus stuff like that. Big grin
I mean, there's got to be a way to do it right?  eyebrow
Thnaks in advance  wave
SCAT15F
RE: A Supersonic Propeller Driven Aircraft, Possible?
Thu Apr 26, 2007 2:24 pm
The Tu-114 was significantly slower than the Tu-95 primarily because of the much wider fuselage and heavier weight. The "normal" top speed published for the Tu-95 was about 920 km/h or 575 mph, and it holds the official record for Tuboprop aircraft at that speed (575 mph) over a closed circuit.
I read that the Tu-95 prototype hit 992 km/h or 620 mph in level flight and that was only with the 12,000 shp version of the NK-12 turboprops that would eventually be uprated to 15,000 shp. But production versions of the Tu-95 were also a lot heavier)
The XF-88 tested supersonic propeller designs in the 1950's that showed very good efficiency numbers at .95 mach (ultra thin airfoil sections) They used 4 blade designs.
The infamous Republic XF-84H "Thunderscreech" had a 3-blade prop that operated at supersonic tip speed throughout the flight range. Problems with the troublesome Allison T-40 engine prevented top speed exploration, but the design speed was 670 mph or mach 1.0. It was to be fitted with an afterburner as well in order to exceed the speed of sound (the world's only turboprop with an afterburner!) I heard that in testing it hit only 530 mph because of the engine issues. In theory, with a better engine, it could have worked, or at least got real darn close!
Counterrotating props offer higher speed potential for a given power output because they convert torque to power, eliminate torque steer, and give twice the blade area (that's my guess, so don't quote me on that)
flipdewaf
Fri Apr 27, 2007 5:45 am
I have often wondered this as well, il ask my aerodynamics lecturer about it tomorrow. I know that soome funny things have to happen to a jet nozzle and the air slowed to subsonic speeds before entering. I think it could be done with an impellar if the air was slowed before entering and then it was to exit through a convergent-divergant nozzle.
Fred
N231YE
Fri Apr 27, 2007 6:49 am
I thought I read somewhere that propellers loose their efficiency dramatically after 450 mph (could be wrong on the numbers)...
I guess I will have to do some research and look around for where I found this.
Blackbird
Fri Apr 27, 2007 11:09 am
How does that work (thunderscreech), doesn't the blade have to have a subsonic top-side in order to have suction (as in to suck the air through and accelerate it out the back)? Because if the flow is supersonic the curve over the top would produce a positive pressure rather than a lower.
Am I missing something?
FredT
Fri Apr 27, 2007 2:00 pm
A prop blade is an airfoil, just like a wing. In order to have a propeller work at supersonic blade speeds, you have to make a propeller blade with an aerofoil section which works at supersonic speeds. If you can make a supersonic aircraft fly, you can make a propeller produce thrust even though the propeller blades (and possibly the entire aircraft) is supersonic.
Probably won't be the most effective propeller in the world at those speeds though.
As for the AoA thing, you might want to draw that situation on a piece of paper.  Smile
ThirtyEcho
Fri Apr 27, 2007 4:46 pm
You could make a cheeseburger go supersonic if you reintered it from near-earth orbit.
As for prop-driven airplanes, rumors abound concerning the supersonic adventures of the Lockheed P-38 during WWII. These were, basically, full power dives from very high altitudes in which the airplane encountered, and passed, what was known as "compressibility." The aircraft were, most certainly, somewhere in the transonic range and may have been supersonic for a short time. The same thing is said of the P-51.
These would have been out-of-control maneuvers, with a frozen stick, that were recovered only by reaching more dense air at lower altitudes.
FredT
Sat Apr 28, 2007 12:34 am
Not to mention the first nibbles at the transonic region in P38s... and the discovery of Mach tuck. Ouch.  Sad
Rumors has it a certain bucket of nuts, whose name currently escapes me, pushed a Mossie past M1 during WW2. As with most such rumors, it's not confirmed.
It would surprise me a lot if there wasn't someone, somewhere in some aircraft who went supersonic and lived during the war years. However, if it ain't on record it didn't happen. That's the bitter truth of it.
Blackbird
Sat Apr 28, 2007 2:33 am
The part that makes me think a truly supersonic prop is not possible is because the blade depends on it's ability to suck air towards the blade, and then accelerate it to a higher velocity.
If the blade is supersonic (totally) the convex-curved portion on the front of the blades (which produce the suction which pulls the air towards itself) would be producing negative lift as the curve would cause a pressure increase. Maybe I'm having a problem conceptually understanding, but a prop at supersonic speeds would blow air forward rather than suck it back.
I'm not sure if a reverse pitch would work either since the leading edge of the blade would produce a shockwave which would cover both the front side and the rear side increasing the pressure on both, although admittedly more on the rear side. I'm not sure if the shear spinning of the blade (with inverse camber or reverse pitch) would be able to force air through from front to back especially with positive pressure on the front.
Am I right or wrong?
Andrea Kent
FredT
Sat Apr 28, 2007 2:47 am
Can a wing generate lift when supersonic?
Yes, it can.
How does it do it?
Action/reaction. It creates a downward force on the air, thus pushing the air down while the equal and opposed force pushes the wing up.
Can a propeller blade generate thrust when supersonic?
Yes, it can.
How does it do it?
Action/reaction. It creates a rearward force on the air, thus pushing the air aft while the equal and opposed force pushes the propeller blade forward.
Have another look at supersonic airfoils?
Blackbird
Sat Apr 28, 2007 2:55 am
I'm no aerodynamic expert!
Andrea Kent
avt007
Sat Apr 28, 2007 3:49 am
Quoting ThirtyEcho (Reply 6):
 Silly
Between this and the STOL SST thread, why not ask for a sub-orbital helicopter?  Big grin
Blackbird
Sat Apr 28, 2007 5:39 am
You know what I'm wondering? How come someone in the US during the time turboprops came around think of using a shrouded turboprop?
They would have reduced a lot of vibration, and that was one of the biggest problems with propeller planes. And if they used counter-rotating props, the torque, and prop-wash issue would be neutralized.
Andrea Kent
Jerald01
Sat Apr 28, 2007 6:29 am
When a propeller blade goes supersonic, it produces a supersonic compression zone (shockwave) just in front of it. That shockwave then travels over the propeller airfoil (from leading edge to trailing edge at any point along the chord of the propeller) when the propeller is moving (rotationally) faster than the shockwave. Additionally, if the aircraft continues to accelerate to the point that the wings go supersonic, the propeller is subjected to a second shockwave - that of the air rushing at it from IN FRONT of the aircraft. This "longitidunal-aspect" shockwave is separate from the "rotational-aspect" shockwave that is created by the rotation of the propeller blade through the plane of the propeller disk.
A designer can overcome the drag from the rotational-aspect shockwave simply by increasing the propeller RPM at the moment the leading edge goes supersonic. What is extremely hard to overcome is the longitidunal aspect shockwave that is hitting the "top" surface of the propeller airfoil (i.e., that air which is coming directly at the front of the engine, 90-degrees to the plane of the propeller blade rotation.) When THAT shockwave encounters the rotational-aspect shockwave somewhere along the "top" of the propeller airfoil, the resultant interaction creates some very tricky, if possibly unmanageable, forces on the air the propeller is trying to push aft.
This interaction of two shockwaves colliding with each other along the "top" of the propeller airfoil produces many different effects, one of them being a sudden "overpressure zone". That zone spreads from it's initial start point along the airfoil chord all the way to the trailing edge of the propeller, where it meets the high-pressure zone from the "bottom" side of the airfoil. Extreme turbulence at this juncture then creates high-low-high pressure zones at the aft edge of the propeller, which then propogate somewhat forward onto the "top" of the propeller airfoil.
These high-low-high pressure zones then set up harmonic vibrations along the propeller airfoil chord that can be so great as to totally destroy the propeller in seconds. This is not exactly the same as what was happening when all the Lockheed Electras were crashing during the late '50's and early '60's, but it is close. The propellers on those aircraft actually "went supersonic" in two separate axis (longitudinal to the aircraft fuselage, and rotational to the plane of the propeller disk). The props / engines / engine mounts / wings were not designed to handle the ensuing harmonic vibrations, so things flew apart.
"There may be old pilots, and there may be bold pilots, but there are darn few green cows"
Fly2HMO
Sat Apr 28, 2007 7:27 am
Quoting Blackbird (Reply 12):
Wouldn't that make it a turbofan then?  eyebrow
Quoting SCAT15F (Reply 1):
I reasearched a bit and couldn't find an answer. Do you know if it was a constant speed prop? From pics of it, it looks like it at least has variable pitch blades.
Quoting Jerald01 (Reply 13):
So is that why the prop was always spinning at supersonic rates in the XF-84H?
Thx for the insight  Smile
lehpron
Mon Apr 30, 2007 11:43 am
Quoting Avt007 (Reply 11):
It's been done, well, as a research proposal I think, I don't recall if it has been tested. The idea was to use wind-milling blades (like helo blades) to slow a supersonic vehicle from reentry as opposed to parachutes, therefore they could be reuseable and easier to stow away. Note: these blades are not meant to deploy hypersonically. I remember my first year in college, a senior design team proposed a deisgn that involved two sets of blades, forward and back, counter-rotating, for stability I suppose.
Quoting Blackbird (Reply 10):
As long as you are learning.
747400sp
Tue May 01, 2007 7:46 am
Was this the aircraft that was so loud it made people sick?
SCAT15F
Wed May 02, 2007 1:01 am
Quoting FLY2HMO (Reply 14):
According to Wikipedia the prop was constant speed variable pitch, turning at 3000 rpm and the tip speed was mach 1.18. The XF-84H hit a (unofficial) speed of 623 mph in testing, making it (unofficially) the fastest propeller driven aircraft ever flown. That speed was reached without using the installed afterburner, so theoretically, it might have actually gone mach one, but I think it would have been more successful if they had used a counterrotating setup.
ContnlEliteCMH
Wed May 02, 2007 4:16 am
They did. What you have described is, to a lesser extent, the modern day turbofan. The fan is driven by enthalpy taken out of the exhaust stream, but unlike a turboprop, there is no geared reduction (though P&W is trying to build a geared turbofan.)
There are other dissimilarities. The fan blade pitch is constant and the fan velocity generally only changes as a function of power setting. And of course, there are far more blades on the fan disk than you'll find on a propeller.
Christianity. Islam. Hinduism. Anthropogenic Global Warming. All are matters of faith!
timz
Wed May 02, 2007 9:23 am
When, and how far?
Quoting FLY2HMO (Thread starter):
Didn't they hope to go supersonic with the (piston-engined) Pond Racer?
SCAT15F
Thu May 03, 2007 1:11 am
Quoting Timz (Reply 19):
When, and how far?
Honestly, I can't find the source anymore- it was in a book.
I remember the goal for the Pond Racer being to break 600 mph.
