Scooter01
B-52 Front Wheel Steering
Wed May 02, 2007 6:45 am
After studying all the head on pictures in the database of the B-52 making a turn while taxiing, something seems wrong with the wheel alignment. Normally on a vehicle with 2 front wheels, the inner one in a turn will be turned sharper than the outer one since the outer one will have a slightly larger turn-radius or covering a larger circumference (what is called toe-out in cars)
Most of the pics of the B-52s seem to show that the outer front wheelset is turned sharper than the inner one, (toe-in) therefore creating quite a bit of tire-scrubbing and the wheelsets working against each other.
Photo © Gerhard Plomitzer
Photo © Stuart Haigh - topjetpix
Photo © Mark McEwan
Photo © Rez Manzoori - FlightLineImages
Photo © John Powell
Any comments?
Scooter
boeingfixer
RE: B-52 Front Wheel Steering
Wed May 02, 2007 7:33 am
EDIT: I just re-read your post and you were commenting on the appearance of toe-in on the outside gear. I believe the steering angles are the same between both gear so this is most likely an optical illusion.
John
[Edited 2007-05-02 00:38:29]
Cheers, John YYC
Scooter01
Wed May 02, 2007 8:02 am
To BoeingFixer.
I read your reply before the edit and I agree 100% with the "no toe-out on the front wheel sets during a cross-wind crab-landing", but I find it hard to believe that in the 50+ years since the design was conceived they haven't come up with some kind of computerised wheel control to rectify this problem.
Photo © Justin Cederholm
Then again, why spend any money on a plane that will de retired in the next 25-30 years.  duck
Scooter
Wed May 02, 2007 10:39 am
Quoting Scooter01 (Reply 2):
Well, every ten years or so they say the BUFFs will be retired "real soon now". And yet here they still are. So maybe that's the reason. And maybe scrubbing the tires is just less money that fixing the problem with a computer.
2H4
Wed May 02, 2007 1:15 pm
Why did they mount brand-new tires on a museum aircraft?
Signed,
The Russians
Intentionally Left Blank
DH106
Wed May 02, 2007 10:24 pm
Yes - just to clarify, there's 2 different modes for wheel pivoting on the B-52:- conventional steering for taxiing etc. which presumably just turns the fronts and thus should logically be designed to have each front turn at a slightly different angle - a la car setup, - and secondly, the 'crabbed crosswind' landing capability in which both fronts and rears pivot - all to the same angle so that they're aligned to approximately the ground track direction with the fus. at a crab angle at touchdown.
...I watched c-beams glitter in the dark by the Tanhauser Gate....
Scooter01
Thu May 03, 2007 9:38 am
Quoting 2H4 (Reply 4):
Or should we say: Why would they re-tire a retired aircraft?
Big version: Width: 1024 Height: 1536 File size: 1106kb
MIG-25 in Riga
Scooter
rwy04lga
Sat May 05, 2007 1:35 pm
Quoting DH106 (Reply 5):
The cross-wind crabbed landing gear was a military secret for many years. My Dad flew BUFFs and never told me about them until after that information was declassified.
Just accept that some days, you're the pigeon, and other days the statue
Users browsing this forum: Noris and 1 guest
