CoolGuy
Various Questions In One Post
Sat May 05, 2007 4:06 am
I have a few questions that I thought would be best bundled together in a single post:
There is a single piece of metal sticking out of the wing of a 737-500, and isn't one of the vortex generators. It has a little hole in it. What is that?
At CLE, runway 11/29 is often used as a taxiway when taking off from 24L (at least on the flights that I am on). How common is it to use inactive runways as taxiways?
Also, at CLE, do planes sometimes use the outer runway of 6L/24R and 6R/24L to takeoff? Maybe they did before the newest runway was built?
One more at CLE, why is there an X on 6C/24C? It makes sense that it's not used anymore but I guess it's now completely closed.
Are two flights ever in the air with the same callsign? What if, for example, DL1 SFO-IAD is still in the air but DL1 IAD-CDG is ready to go?
Why is ETOPS written on the front wheel panel? (I know what ETOPS is but why is it written on aircraft?)
KELPkid
RE: Various Questions In One Post
Sat May 05, 2007 8:18 am
Quoting CoolGuy (Thread starter):
That's officially what the "X" means...it's no longer a usable runway.
star_world
Sat May 05, 2007 9:17 am
I believe this is for securing a harness to somebody for when they are working on the wing during maintenance.
Pretty common, they do the same in LGW all the time for example on the smaller (rarely used) runway. There's no good reason not to use an inactive runway as long as it's safe.
They will assign a different callsign to one of the flights, or append a letter or number to it. You often hear this if you're listening to ATC or Ch9 on UA.
This is so the ground crew can easily see that it's an ETOPS a/c. There are some different maintenance procedures that need to be followed for these aircraft.
KELPkid
Sat May 05, 2007 9:38 am
Quoting Star_world (Reply 2):
Some airlines who operate overwater have something very similar looking, usually with two holes and painted yellow, that are there as a tie-off point for a liferaft in the event of a water ditching.
roseflyer
Sat May 05, 2007 10:22 am
It can be common. A good number of airports do it. For one reason, for an inexperienced crew, it is very easy to identify a runway so that planes don't end up on the wrong taxiway. I've seen crosswind runways used as regular taxiways when they are not in service. IND's crosswind runway is more often serves as a taxiway than an actual runway even though pilots prefer it since it is close to the terminal.
They could add a letter or completely change the call sign. Often you'll hear flight numbers that are larger than typical for cases such as this.
It is for crews to identify which planes are ETOPS. ETOPS planes require special maintenance procedures, so rather than having to know which plane is which based on tail numbers, it makes crews aware. It is not required and only some airlines on some planes paint the words on the gear.
Sat May 05, 2007 4:10 pm
The Tie point for the Escape rope used as hand hold/holding hook point for the Life Raft.depeding on type..
If its Inactive its commonly used.If the path is suitable.
The probability is rare.
ETOPS Aircraft undergo more stringint checks & has crtain added equipment.Its a reminder.
regds
MEL
Scooter01
Sat May 05, 2007 7:15 pm
Quoting KELPkid (Reply 3):
Quoting HAWK21M (Reply 5):
How long do you think it would take before the aircraft or the wing would sink? I would be wery careful to tie a liferaft to something that might pull it down with it.
My guess would be that it functions as a "lift-ring"
Scooter
Sat May 05, 2007 9:00 pm
Quoting Scooter01 (Reply 6):
The Raft has a shear section that will break with load.Its to prevent the rank floating away during evacuation on water.But it depends on the type of Aircraft too.
regds
MEL
Tristarsteve
Sat May 05, 2007 9:34 pm
When you remove the emergency exit on a B735, there is a rope coiled up inside the window frame cut out. The idea is that the first person out takes the rope and clips it to the ring to provide a handhold for the following pax. I wonder if it has ever been used!
Sun May 06, 2007 12:05 am
Quoting TristarSteve (Reply 8):
Practically in an Emergency evacuation only a staff member would do that.The rest will want to get on safe terrain asap.
regds
MEL
xjramper
Sun May 06, 2007 12:37 am
Quoting KELPkid (Reply 1):
Where is/are the X('s)? If there are only two X's on the whole runway...then its just temporarily closed. But if there are X's every 1000 feet, then its permanently closed. DTW has a runway temp (for an indefinite amount of time) closed that is solely used for taxi.
Good example of this is UAL 902. Its routing is DEN-IAD; IAD-MUC. Its callsign from IAD to MUC is UAL 902. However, the callsign from DEN-IAD is UAL 8132.
XJR
Look ma' no hands!
CoolGuy
Sun May 06, 2007 12:40 am
Thanks everyone! I can always count on everyone here to discuss my favorite hobby!
Users browsing this forum: beefstew25, SQfan1, trav110 and 1 guest
