don81603
Responsibility In A Pushback Incident
Wed May 09, 2007 11:13 pm
In a situation like this, where the incident occurs during pushback, who would ultimately be responsible? Logic says the tug operator, but with the limited visibility her/she has, wouldn't there be a spotter watching the tail to alert the tug operator of any obstacles?
Photo © Weimeng
Eagles may soar, but weasels don't get sucked into jet engines.
brettbrett21
RE: Responsibility In A Pushback Incident
Wed May 09, 2007 11:25 pm
There are many people in the chain.
Did ATC give a bad push back clearance while the 777 was taxiing behind?
Did the tug driver push back without ATC clearance? or after a mistaken clearance
Was there no wing walker, how often a wing walker is used I don't know?
Did the 777 fail to hold for the A320 pushing back?
It's very hard to place blame without knowing more.
i'm so excited i wish i could wet my pants!
charlienorth
Wed May 09, 2007 11:26 pm
At UAL it was the driver of the tug,if they could not see their spotter they were supposed to stop the push until visual contact was regained,I'm quite sure that is the policy at most companys.
Work hard fly right..don't understand it
boeingfixer
Wed May 09, 2007 11:41 pm
Quoting Charlienorth (Reply 2):
One has to add to your comment that if the tug driver is given an all-clear by the wing walkers, it's the fault of the wing walker and not the tug driver if something is hit.
John
Cheers, John YYC
FredT
Thu May 10, 2007 12:51 am
Ah, yes, the first question should always be "who do we pin this on"... or perhaps it shouldn't?
Wingwalker, tug driver, ATC, captain of the aircraft... did either of them wish for the accident to happen? Will saying that the wing walker was responsible and giving the poor sod a reprimand make it less likely to happen once more?
The first question to ask is, IMO, 'why' and 'how' did this happen, not 'because of whom'.
If one guy was out drinking the night before and had a hangover, then by all means... he should be driven out of aviation for good. That's bordering on criminal negligence. But if they were all just doing the job just as the job is always done, then there's likely a 'why' to explain it all - and that's where you should start looking, as that can prevent a repeat.
fr8mech
Thu May 10, 2007 2:26 am
Quoting FredT (Reply 4):
But, most times, IMO, the 1st question's answer is based on the 2nd question's answer.
FredT
Thu May 10, 2007 4:14 am
...and then there's another 'why', as the 'who' certainly didn't intend for that to happen. Unfortunately, that's often where the investigation stops.
nonfirm
Thu May 10, 2007 7:39 am
I agree with you.In the training I teach and have received the ultimate responsibility lies with the tug driver.
 airplane
G4LASRamper
Thu May 10, 2007 1:43 pm
With us, it's the ramp lead for that gate. Most of the time the lead is the pushback driver, but not always. The lead can allow anyone to push as long as they're company qualified. But the lead is responsible for everything that happens below the wing on that gate until final towbar disconnect and the captain acknowledges the marshaller's salute indicating release of the aircraft.
"A pig that doesn't fly is just a pig." - Porco Rosso
musapapaya
Fri May 11, 2007 6:59 am
Bear in mind it is China and guess those people could communicate well or to follow precise instructions?
Lufthansa Group of Airlines
EMBQA
Fri May 11, 2007 7:43 am
Quoting Brettbrett21 (Reply 1):
Few airports require ATC permission to push back. Many ramp areas are uncontrolled.
See above
The aircraft taxing always has the right away... aircraft being pushed are secondary.
Not really... the tug operator is the one in control of the aircraft.
oly720man
Fri May 11, 2007 7:49 am
Anyone speak mandarin?
Sun May 13, 2007 2:23 am
It depends on the situation & the cause of the problem.
If there is a wing walker.Its the responsibility of that person to confirm to the Tug driver that the clearences are ok.
regds
MEL
TheCol
Sun May 13, 2007 5:17 am
Quoting G4LASRamper (Reply 8):
Agreed. Ultimately, it is the responsibility of the ramp lead to oversee the safety conditions for ground ops at his/her assigned gate. If Maintenance is present, they might be singled out as well. That doesn't necessarily mean that the tug driver or wing walkers will get off, but fingers will definitely be pointed at the ramp lead and the maintenance person (if there's one assigned to that flight).
[Edited 2007-05-12 22:25:46]
No matter how random things may appear, there's always a plan.
S12PPL
Tue May 15, 2007 5:27 am
Quoting EMBQA (Reply 10):
....What??? What are you basing this one on? Even at a small airport like EUG, the pilots are required to get clearence to push from the tower if the tower is operating...EUG is an un-controlled airport between like 0000 and 0600 I believe.
Again...Based on what???
Once more...What are you basing this statement on??? Knowlage of the industry?
Next Flights: 12/31 AS804 PDX-MCO 2/3 AS19 MCO-SEA QX2545 SEA-PDX
bond007
Tue May 15, 2007 5:53 am
Quoting S12PPL (Reply 14):
Ramp areas are almost always non-movement areas. If not, it would mean by definition, that every vehicle/person moving on the ramp would need an ATC clearance. In most cases also, the ramp areas are not all visible from the control tower.
At many airports, there is a "Ramp Control" frequency, and this is to coordinate those movements within the ramp area - but not an ATC function. This is sometimes staffed by the airlines or a third-party company.
Yes, you need clearance before taxying, but only because you need your departure clearance in advance, AND you need taxi clearance before moving ONTO the movement area ... not to move in the non-movement (ramp) part ... unless there is ramp control of course. Any ATC instructions for non-movement areas, are advisory only.
Jimbo
[Edited 2007-05-14 22:57:16]
S12PPL
Tue May 15, 2007 5:57 am
Quoting Bond007 (Reply 15):
And you need clearance to push....That's all there is to it. At almost every single airport I've been to, the pilot needs permission to push from ground....
Not only that, but ground has to monitor the ramp to make sure that planes don't run into eachother. While listening to channel 9 many many times, ground will cut in and tell plane A to yeild to plane B before turning onto taxiway ___.
bond007
Tue May 15, 2007 6:09 am
Quoting S12PPL (Reply 16):
Well, read what I said ... that's all there is to it. Yes, the ramp might be ATC controlled ... it often isn't. It might be under a ramp control. It is often a non-movement area. It is agreed upon in an LOA between the airport/airlines and ATC.
Yes, because the taxiway IS controlled ... therefore ATC has authority to instruct all aircraft about to move onto it.
I'm sitting at GRR right now .... non-movement area ... I can do what I want until I'm about to enter the movment area.
Jimbo
charlienorth
Tue May 15, 2007 6:43 am
Most airports I've worked it was up to the individual airlines ops tower to handle,ATC has nothing to do with ramp opps.
Quoting TheCol (Reply 13):
EMBQA (Reply 10):
Check your 'right of way rules in the FAR's"
Check his profile..BTW he is correct
bond007
Tue May 15, 2007 6:55 am
I'm surprized that nobody mentioned that the Captain might/does have responsiblity  Wink
To answer the question, it is often (perhaps has to be) detailed in the airlines ops manual, who has overall responsibility for the pushback. It is usually the tug operator (or lead) and the Captain.
Jimbo
S12PPL
Tue May 15, 2007 7:07 am
Quoting Charlienorth (Reply 18):
No...He might be correct. Every situation is different!
charlienorth
Tue May 15, 2007 7:23 am
Quoting Bond007 (Reply 19):
At UAL it was up to the driver of the tug,after the disconnect and salute,then it was the captain's baby after that
charlienorth
Tue May 15, 2007 7:49 am
Quoting S12PPL (Reply 20):
No one else is steering the aircraft..and the occupant of the pilot's seat has no knowledge of what is happening behind him,everywhere I've worked,if there has been an incident,the driver of the tug ends up in the hot seat..so to speak.
acefreighter
Tue May 15, 2007 10:02 pm
In Europe, ATC do have responsibility for the ramp areas. It is not like the US over here.
G4LASRamper
Wed May 16, 2007 12:14 am
Just to be clear, at LAS the ramps are designated non-movement areas with separate county-operated east and west ramp control towers and frequencies. The ramp controllers are FAA-certified ATCSs (usually former FAA employees holding CTO certificates) but they work for the Clark County Department of Aviation. Yes, a push clearance from ramp control is required prior to push. Once the aircraft is ready to move under its own power, ramp control will clear it to taxi to one of the ramp hold spots (marked by large blue numbered squares painted next to the taxi centerline). The aircraft then contacts FAA ground control (split into east and west when it's busy) for clearance to enter the designated movement area.
bond007
Wed May 16, 2007 1:17 am
Quoting G4LASRamper (Reply 24):
Right, which is common practice for the most busy airports in the US ...such as JFK, LAX etc. It's usually those smaller commercial airports, with less gates, that have or require any ramp or ATC clearance to push-back. In these cases the ramp areas are non-movement AND not controlled.
It's important that you did specify that even though the ramp is 'controlled' by the ramp controllers, it is still a FAA ATC non-movement area, otherwise as I mentioned earlier, almost every vehicle/person would need a clearance to move in it.
Jimbo
n710ps
Sun May 27, 2007 9:16 am
You taxci into any ramp at LGA and park yourself at the gate and see how fast you end up with a breach and a phone call after setting parking brakes. At LGA you do not move on the ramp without calling ramp control and the same for BOS, DCA, CLT, PHL, ATL, ORD and a few others I get in and out of. Have fun with that philosophy.
There is plenty of room for Gods animals, right next to the mashed potatoes!
Sun May 27, 2007 6:00 pm
Quoting N710PS (Reply 26):
Won't Tower advise Landing Aircraft to ctc Grd that allots Parking bays.Where does Ramp Control fit here.
regds
MEL
bond007
Sun May 27, 2007 11:10 pm
Quoting Bond007 (Reply 25):
Yep, which is what we were saying. Out of interest though, that would be a breach of local airport regulations, not FAA rules, since they are no doubt non-movement areas.
Jimbo
n710ps
Mon May 28, 2007 2:03 am
Correct, it is an airport breach but there are hefty fines attributed to these breaches. I was in the terminal once at DCA when one was handed out to a Republic 170 crew at DCA while I was commuting home to LGA from SRQ. And to answer MEL's question. The sequince is to land contact ground, advise of the ramp your headded for than call your local company operations frequency for the on ground call, they assign the gate than you call ramp control and they bring you on in from there. Some ramp controls actually have there own active taxiways that they control beleive it or not at certain airports.
Users browsing this forum: pikachu and 2 guests
