mirrodie
Helicopter Flight Question-see Video
Sat May 19, 2007 9:09 am
http://www.filecabi.net/video/ufochopper.html
Is this an optical illusion on the part of the video camera or am I seeing what I think I am seeing? If its not an illusion and the rotors are going, what is keeping this chopper afloat?
Forum moderator 2001-2010; He's a pedantic, pontificating, pretentious bastard, a belligerent old fart, a worthless st
meister808
RE: Helicopter Flight Question-see Video
Sat May 19, 2007 9:23 am
That would be what happens when the frame rate of the camera matches the rpm of the rotor blades. Fairly spectacular effect, though.
-Meister
copter808
Sat May 19, 2007 3:09 pm
Wow! That's some really cool photography--and careful monitoring of the rotor rpm.
As said above, the frame rate matches the rpm, or a harmonic of it.
If the rotor was not turning, you would notice more coning, (blades bent upward) and a much higher (vertical) rate of descent!!!
...followed by a "Splat!"
bio15
Sat May 19, 2007 5:18 pm
Every time the camera snaps a video frame the blades have turned an angle equal to the angular separation of the blades amongst themselves, or twice that angle, or three times,... It depends on the camera framerate and rotor RPM. What seems as one stationary blade is actually blades 1, 2, 3, 4 & 5 caught in the same position by the camera in fractions of a second. It is also noticeable on the tail rotor which seems to turn very slowly when it really isn't.
Wonderful video, that's a nice effect!  thumbsup
heliflyerPDC
Wed Jun 13, 2007 7:35 am
WOW, thats all I can say
Are there any other video's like this one ?
grtz PDC
grtz PDC
Scooter01
Wed Jun 13, 2007 9:01 pm
Quoting HeliflyerPDC (Reply 4):
Check out the video in reply #6 by TRVYYZ in the "AC777-300 Engines" topic in the Civ.Av forum.
The white spiral on the black spinner seems to be moving a lot slower than it actually does during take-off and watch it change again when climb-power is increased.
Scooter
[Edited 2007-06-13 14:08:10]
ikramerica
Mon Jun 25, 2007 8:17 am
It's not just framerate but also shutter speed. This must be a high shutter speed or the rotors would be blurred anyway. The rotor is going at 6-7 Hz, or 0.14 sec per rotation. So, I'd imagine a shutter speed of 1/1000 second or so could give this effect, matched with a multiple of the fps to keep it from moving too much.
408 rpm would do it, which is a viable rotation speed for a rotor. Or 400 rpm if the footage is from 25fps video or film and not 24 fps film. Both are viable.
N231YE
Mon Jun 25, 2007 10:43 am
I think there is (or was) a thread going in Civ Av about this. The illusion is created by the shutter speed of the camera, and/or the framerate mirroring that of the speed of the rotors. Great illusion!
[Edited 2007-06-25 03:49:50]
sprout5199
Mon Jun 25, 2007 10:53 am
Quoting N231YE (Reply 7):
NOPE, there was a lot of birds in there flapping their wings just after it took off from a conveyor belt.
Dan in Jupiter
