Stitch
Boeing May Not Test 787 Wing To Destruction
Wed May 30, 2007 2:22 am
...Boeing may decide not to stress the Dreamliner's plastic wings until they break.
"A decision has not yet been made to fully break the wing," said Scott Strode, vice president of 787 production. "We are still working on that."
There is no requirement that the wing actually be broken as part of the stress testing, Strode pointed out.
...Boeing and its 787 partners -- including Mitsubishi Heavy Industries, which manufacturers the 787 wing in Nagoya, Japan -- have been doing structural testing of a 787 wing for more than a year...Strode disclosed that Boeing already has stressed that wing to the required 1.5 times the limit load -- and it did not break.
http://seattlepi.nwsource.com/business/317186_wingbreak25.html
n710ps
RE: Boeing May Not Test 787 Wing To Destruction
Wed May 30, 2007 2:27 am
I would do it if I were them. Granted they can use other numbers to get the critical stresss point numbers but why not be certain? I say break the thing. Besides I want to see it in video lol.
There is plenty of room for Gods animals, right next to the mashed potatoes!
ShyFlyer
Wed May 30, 2007 2:30 am
Quoting N710PS (Reply 1):
 checkmark
Besides, wouldn't it be destroyed/scrapped after certification anyway?
norcal
Wed May 30, 2007 3:40 am
Let's say they do break it, but it breaks at 1.6 or 1.7 or something. Does that mean they can increase the MTOW (assuming the other parts of the aircraft like the gear can handle it) with out an increase in OEW?
OldAeroGuy
Wed May 30, 2007 4:26 am
Quoting NorCal (Reply 3):
Yes, depending, as you say, on the loads capability of the rest of the airplane.
redflyer
Wed May 30, 2007 5:57 am
I see a couple of issues with this development. The first and most obvious is, as long as the wing reaches the required 150% load without breaking, who cares if it ultimately breaks or not? We're talking certification here so if it meets the certification requirement then why break the wing, especially if it could be used for other testing purposes in the future? I'm assuming these wings, even sections of them, are not cheap and to be able to use the wing for other future (and occasionally unrelated) tests saves Boeing a lot of money.
The flip side of that argument could also be the reason that Boeing broke wings in the past. And my understanding there is that they did so to validate their engineering models. That is, they wanted to see at what point and where precisely on the wing the wing actually ruptured to prove that their engineering models were spot-on accurate. So is Boeing confident that they have their engineering model down pat, even if it is a new material they're working with?
My other home is in the sky inside my Piper Cherokee 180.
N231YE
Wed May 30, 2007 6:11 am
This is probably a side effect due to me putting 777 Wing Ultimate Load test from the 21st Century Jet documentary on the internet  smile
Don't believe me? Check my profile and the "uploader" of the original YouTube video, also found in the article which was provided above...
2H4
Wed May 30, 2007 6:17 am
I wonder how the composite wing would fail....whether it would shatter and splinter, launching deadly shards of carbon into the air, or whether it would simply rupture in a contained manner....
2H4
Intentionally Left Blank
KELPkid
Wed May 30, 2007 6:58 am
Quoting 2H4 (Reply 7):
2H4
I would hazard a guess that, given the kind of "stretchy" nature of composites, it would merely remain deformed due to being stretched beyond it's elasticity point  Smile You might end up with a little more dihedral than you started the flight with Big grin
2H4
Wed May 30, 2007 7:15 am
Are airframe manufacturers required to perform similar tests downward....ie: proving that the wing can withstand 150% of the negative load limit?
Quoting KELPkid (Reply 8):
It would certainly be interesting to see....
2H4
Boeing7E7
Wed May 30, 2007 8:52 am
Quoting RedFlyer (Reply 5):
Just a hunch, maybe they don't do it before certification, but they do it afterward to validate the engineering.
Boston92
Wed May 30, 2007 12:31 pm
Did anyone else watch Boeing show how they "test" the wings a couple weeks back on the "Today" show? I found it pretty interesting.
"Why does a slight tax increase cost you $200 and a substantial tax cut save you 30 cents?"
Wed May 30, 2007 6:34 pm
Quoting Boston92 (Reply 11):
Is there a Youtube video on this,like the B777 one.
regds
MEL
Sinlock
Wed May 30, 2007 9:43 pm
Not really, MTOW is more directly related to the wings ability to generate lift efficiently during takeoff. As the weight go's up, higher takeoff speeds are needed to provide the needed lift due to the new higher MTOW.
In order to make use of a wing that could handle massive 7%-14% extra load you hint at 1.6 or 1.7 or something the only thing to really be done is change the flap/slat deployment layout to add more wing area, like whats been done with the 737-700ER, -900ER and 777-300ER
But if the wing was to make it to 1.6 or 1.7 it could open the possibility for Boeing to reduce the number of plys in the buildup of the wing and get a slight reduction of weight.
OldAeroGuy
Wed May 30, 2007 11:49 pm
Quoting Sinlock (Reply 13):
This is not correct. MTOW is rarely controlled by takeoff speeds. A 7% to 14% increase in takeoff weight only requires a 3.5% to 7% increase in takeoff speed. These increases in speed are normally handled by thrust increases to maintain takeoff field length or letting the takeoff field length increase. Changing wing area or revising the high lift system is rarely done to accommodate this level of weight increase.
As a case in point, consider the 772A vs the 772ER. MTOW went from 247.2t to 297.6t, an increase of 20% with no increase in wing area and no high lift system revision. There are many other examples of this type on other airplanes.
[Edited 2007-05-30 16:52:01]
Starglider
Thu May 31, 2007 5:12 am
If the wing would fail in that manner, i wonder how much carbon dust would be released from such a failure. Carbon fibers are good conductors of electricity. Carbon fiber dust can cause arcing and shorts in electrical equipment. Perhaps one of the less obvious reasons they may not want to test the wing to destruction?
Starglider
2H4
Thu May 31, 2007 5:26 am
Quoting Starglider (Reply 15):
I would think a primary concern...as the original article suggests...would be the likelihood of an abrupt, violent, catastrophic failure damaging expensive test equipment.
2H4
Fly2HMO
Thu May 31, 2007 6:06 am
Quoting Stitch (Thread starter):
Where's the fun in that?
Quoting 2H4 (Reply 16):
Aren't they all very catastrophic anyways?  eyebrow
2H4
Thu May 31, 2007 6:31 am
Quoting FLY2HMO (Reply 17):
Heh heh...poor choice of words on my part. I was thinking more along the lines of a totally uncontained failure that would send large sections of the structure flying through the air and into equipment.
2H4
iwok
Thu May 31, 2007 2:43 pm
I believe it basically turns into a fine mist of carbon & epoxy dust which essentially acts like "soot." It kind of gets everywhere.
-iwok
Sinlock
Thu May 31, 2007 10:02 pm
Quoting OldAeroGuy (Reply 14):
My post did not state anything about a 7% to 14% increase in take off weight.
Any chance thats because Boeing designed the -200A, -200B(ER) and future -300A on a common wing?
OldAeroGuy
Thu May 31, 2007 11:38 pm
Quoting Sinlock (Reply 20):
Aren't these your words below? If you weren't referring to takeoff weight, what did you mean?
Any reason why you think the same won't apply to variants of the 787?
redflyer
Tue Jun 05, 2007 8:10 am
Quoting Boeing7E7 (Reply 10):
Good hunch, and probably accurate.
I found this link to FI from another thread on the Civil forum. It seems the carbon fiber dust is the main reason why Boeing is hestant about breaking the wing:
"We're asking what will we gain, if anything, by taking the wing all the way to breaking point," he says, adding that one consideration is the large cost associated with cleaning up the fibrous contaminents that will result. [emphasis added]
http://www.flightglobal.com/articles...-as-first-test-airframe-comes.html
Starglider
Tue Jun 05, 2007 8:05 pm
Quoting RedFlyer (Reply 22):
Thanks for the link, i had not read that particular article yet.  thumbsup
Starglider
SEPilot
Tue Jun 05, 2007 8:33 pm
Actually, I don't believe composites are "stretchy" at all. I have never done much with carbon fiber, but I have worked quite a bit with fiberglass. My experience is that it will bend but always come back to its original shape unless it breaks, which it usually does fairly violently, with the plastic matrix basically disintegrating into powder. I have never seen it take a permanent bend from externally applied load. This is probably related to the different fatigue characteristics of composites to metals; as unhardened steel and aluminum will plastically deform under sufficient applied load, and under repeated load less than the deformation point but above the non-fatigue point will fatigue.
GZIP: Off
