timz
How Do You Aim A Localizer Antenna?
Thu Jun 07, 2007 2:34 am
You're installing a new localizer antenna off the end of a runway ... I assume it's midpoint is on the runway centerline and the antenna is supposed to be perpendicular, but probably it does take some slight adjustment? So does someone stand on the centerline at the other end of the runway, with a receiver showing when he's centered in the beam? How precise would such a receiver be at that distance-- how accurately can it pin down the center of the beam?
How do you adjust the antenna-- physically rotate it, or electronically?
boeingfixer
RE: How Do You Aim A Localizer Antenna?
Thu Jun 07, 2007 3:15 am
Localizer antennas are located at the far end of the approach runway. Precise surveying of the site prior to antenna installation is done. Also a magnetic survey of the area is carried out to ensure accuracy of the system. The system can be adjusted in small increments (mechanically) as required to obtain accuracy. All ILS systems, at least in Canada, are subject to verification by suitably equipped aircraft that can measure the accuracy of the system and this is done periodically to ensure the ILS is operating within limits.
John
Cheers, John YYC
bond007
Thu Jun 07, 2007 12:18 pm
Quoting BoeingFixer (Reply 1):
In the USA this is performed by the FAA 'Flightcheck' aircraft, that do multiple ILS approaches and analyze the data.
Jimbo
corey07850
Thu Jun 07, 2007 8:05 pm
To be honest, unless you've got a degree in physics and radiowaves you wouldn't understand how it's done (don't worry I don't know either)... I can tell you a little bit from my experience though. As you said, the localizer array is usually centered on the midpoint of the runway (most of the time, there are exceptions) and is made up of multiple towers. The cables are fed undergrond and into a small shack (usually referred to as the ILS Shack). Inside the shack you'll find a few large units that resemble something like a computer mainframe. This is where the adjustments take place. To see how much a localizer or glideslipe need adjusting a couple surveys are done. The one that most people see are the flight-check aircraft (usually registered as N1-N99 and are usually King-Air's or Lears). The aircraft will make several approaches to the runway with different on board computers measuring the signal and recording the results. The other survey you see is ground based where the FAA will survey points on the airfield that are at 10, 20, and 30 degrees off centerline from the localizer. These points are surveying using traditional survey methods, and when the FAA comes they basically place their instrument at these points of where the localizer 'should' be and compare the difference.
If the localizer or GS needs adjusting a tech will make the adjustments on the towers inside the ILS shack and is basically altering the frequency eminated from each tower to balance everything and bring it into tolerance. Like I said, unless you have a background in physics it's hard to understand the details of everything (the FAA-AF inspector I deal with has been with the agency for something like 10 years and they were just letting him get into ILS systems).
But to answer your question simply: the localizer is physically mounted exactly how it should, then any adjustments are made electronically by altering the radiowaves.
MD11Engineer
Fri Jun 08, 2007 1:13 am
The way the German aviation authorities check ILS systems is by using a converted Beech King Air, which has a precisely calibrated ILS receiver on board. The pilot flies an ILS approach to almost touch down. On the bottom of the aircraft there is a laser reflector. Prior to the flights, a specialist with a laser transit will take position either on the centerline (for localiser) or just beside the touch down zone (for glidepath). The automatic laser trtansit will show any deviations from the theoretical track and the ILD system will be adjusted accordingly.
Jan
Boeing7E7
Tue Jun 12, 2007 10:12 am
Quoting Corey07850 (Reply 3):
No kidding. In a nutshell, they measure the propagation error and alter the gain to ensure lateral tolerance. Outside of that it's FM (F'ing Magic).
Tornado82
Tue Jun 12, 2007 11:05 am
Last week at CKB I landed behind Flightcheck 88, a Challenger. It's all this rather unique shade of teal or so. From what I heard on the approach frequency they were testing a VOR. Seems like alot of jet for that job.
Photo © Anton van Ruiten
[Edited 2007-06-12 04:07:19]
corey07850
Tue Jun 12, 2007 1:17 pm
Quoting Tornado82 (Reply 6):
Their Global Express is even worse, although I'm not sure if they use it for flightchecks or just transport for their big-wigs  Smile
jetmech
Tue Jun 12, 2007 3:12 pm
I think that Air-services Australia ( CAA / Dept. of Aviation) used to use a Fokker F-28 for the job. I remember seeing it many times doing several approach and go-arounds along the main runway (16R-34L) at SYD. I'm not too sure what they use these days.
Photo © Brian Wilkes
Photo © Phil Vabre
Photo © George Canciani
Photo © David Eyre
Regards, JetMech
UAXDXer
Tue Jun 12, 2007 5:01 pm
The FAA's Flight Checks has 4 Challengers, most of which are used for overseas operations at US military bases.
N85
Photo © Andreas Fuerst
N86
Photo © Gary Stedman
N87
Photo © Gerhard Plomitzer
N88
It takes a bug to hit a windsheild but it takes guts to stick
FredT
Sun Oct 26, 2008 7:09 am
Found an old thread, it seems, but decided to fill in a bit anyway.
If you want a basic conceptual understanding, it's not all that tricky. A localizer antenna array consists of a number of transmitting elements installed on a straight line perpendicular to the approach direction.
If you are on the left side of the approach, you will be slightly closer to the transmitting element on the left side of the runway than you are to the transmitting element on the right side. This means the signal from the right side element will take slightly longer to reach the aircraft than the signal from the left side element. The phase difference thus generated creates the signal telling the aircraft receiver where it is, relative to the centerline of the approach.
To change the alignment of the localizer electronically you basically need to introduce artificial delays in the signal paths from the signal generator to the antenna elements, corresponding to the desired change in direction of the localizer beam. Through an artifical delay, you simulate an antenna element being somewhat further from the aircraft than it really is.
