AirEMS
Could The MD-11 Problems Happen Today?
Sat Jun 16, 2007 2:20 am
Could the performance problems of the MD-11 happen today with all of the computer technology and tons of wind tunnel testing that all potential and launched designs go through?
Could the A380 / 350 or the B 787 / 748 have performance problems that were not found during the planning or computer / wind tunnel testing.
Sorry if this has been put out before and remember if you flame please flame with care...  duck
-Carl
If Your Dying Were Flying
LTU932
RE: Could The MD-11 Problems Happen Today?
Sat Jun 16, 2007 3:35 am
It certainly is possible. Maybe the aircraft is on spec during windtunnel testing, but what if the performance problem is related to a part that's not built by Boeing or Airbus, like the engines? I mean, weren't some of the MD-11 problems not related to the engines not delivering the required performance as well?
ConcordeBoy
Sat Jun 16, 2007 6:57 am
...the M11's problems stemmed mostly from its outdated/compromised (relative to upcoming competitors) wing design, and its CoG/trim issues.
UAL747
Sat Jun 16, 2007 7:00 am
Any new aircraft can experience "teething" problems. One aircraft that comes to mind is the A340-600 and somewhat the -500.
Supposedly, the A346 original variants did not live up to performance specifications, thus Airbus introduced the HGW variant. Also, I've heard that the A346 is nose heavy, meaning that there a balance issue in some sense where the forward fuselage is a bit heavy. Now, I heard that on a.net and I don't have anything to back it up, but there you go.
For the -500, it's going to be outclassed and outperformed by the 772LR's lower fuel burn and cargo capacity.
UAL
ConcordeBoy
Sat Jun 16, 2007 8:39 am
Quoting UAL747 (Reply 3):
...and cabin width, and range, and payload/density capability, and speed, and...............
TrijetsRMissed
Sat Jun 16, 2007 11:10 am
Quoting AirEMS (Thread starter):
The A380's problems and delays make the MD-11 seem relatively minimal in comparison.
Quoting LTU932 (Reply 1):
Yes, during flight testing it became known that the CF6 and PW4460 experienced excessive fuel burn. The PW4462 solved most of these problems and added an 8% increase in range on the later PIP models.
The other major problem was the airframe was heavier and more drag-prone than expected. This was fixed with composite panels and a larger No.2 engine intake.
There's nothing quite like a trijet.
reins485
Sat Jun 16, 2007 11:17 am
Quoting ConcordeBoy (Reply 2):
Agreed, my dad use to fly to the MD-11 and they use to play a game to see if they could hand fly it and keep it at a level altitude, which was close to impossible he said and they would end up oscillating up and down . I don't remember how bad it would get.
TrijetsRMissed
Sat Jun 16, 2007 12:48 pm
Quoting Reins485 (Reply 7):
While the trim characteristics may have been undesirable, it did not contribute much to a loss of sales or the inability to initially meet range expectations during flight testing, which is what we're talking about here. The tail-heavy COG issue has been debated on here at nauseam. And while in hindsight a better wing design would have benefited the aircraft, it was not one of the main issues in 1990.
roseflyer
Sat Jun 16, 2007 2:24 pm
It could happen, but I think performance limitations would be known earlier on in the design stage. You should remember that the MD-11 had very very little computer support in the design process. They couldn't simulate the different systems anywhere near as well as they can today. Furthermore the testing process done for each of the components was no where near as good as it is today. So performance problems would be known about earlier on in the design process so corrective action could be taken earlier. I don't think we would see as much of a surprise as we did with the MD11.
But that doesn't mean that design problems can't happen. Technology is getting better, but planes are getting more complex and technology is always being pushed.
wilco737
Sat Jun 16, 2007 6:56 pm
Hi guys,
I just come out of the sim of the MD11F and I never experienced any performance problems! I mean, in the freighter you can take 94 tons of freight with you and still fly FRA-ORD nonstop, which isnt too bad. Even the take off performance isnt bad! Well, in NBO of course you cannot take off with MTOW (its reduced to roughly 275tons iso 286 tons).
One engine out isnt much big of a deal as well. normal approach, using flaps 35 and not 50 anymore, but normal go around procedure. 2 engine out will be a little more difficult, but under certain conditions you can still fly a go around (!!!) with only ONE engine remaining! Read carefully: under certain conditions... but it is possible! I did it in the sim several times and it worked...
Yes, the wing load is really high and the normal approach speed at MLAW is 168KIAS... which is a lot higher than most modern airliner. And of course the FAR required field length is increased as well... But still, the climb performance and the go around performance was/ is quite impressive...
WILCO737 (MD11F)
 airplane
moo
Sat Jun 16, 2007 8:25 pm
Quoting TrijetsRMissed (Reply 6):
Thats a totally different discussion - the A380 issues are not performance related.
CosmicCruiser
Sat Jun 16, 2007 11:35 pm
Quoting WILCO737 (Reply 10):
Your complete post was accurate and well stated. The T/O perf. even at MTOGW is very good and I've seen days at lighter wgts (CDG-FRA) where the vert. spd tape will be pegged. It's impressive!
Quoting TrijetsRMissed (Reply 8):
If you're referring to the OLD (very old) data base stab problems you're right that's been run into the grd and doesn't exist anyway anymore. And I don't think that was a CG prob. Wasn't it more of an LSAS prob? Tail fuel mgt. will give you an aft CG for cruise which improves range.
It's not so bad now BUT I probably wouldn't want to do it for very long. But hey I remember in my 727 days hand flying 2/3 the way across the country because the A/P was deferred and the F/O and I would swap up flying the thing every 30 min. because it was a lot of work. It certainly wasn't like trimming up the old beech and letting it ride!
 Wink
Big version: Width: 834 Height: 667 File size: 48kb
wilco737
Sun Jun 17, 2007 2:23 am
Quoting CosmicCruiser (Reply 12):
Phew Thank god I had it right, otherwise I have to give back my MD11 type rating  Wink
WILCO737 (MD11F)
 airplane
jwenting
Sun Jun 17, 2007 2:47 am
Ah, but the "problem" of course is that it has too much power (as compared to the A340-200 and -300)  Smile
I wish I were flying
TrijetsRMissed
Mon Jun 18, 2007 2:17 pm
Great post WILCO, this aircraft is more than capable, contrary to popular belief.
Quoting Moo (Reply 11):
I would consider weight to be completely relevant with this discussion. It is performance related and two years later it is still delayed..
Yes and you are correct.
moo
Mon Jun 18, 2007 5:28 pm
Quoting TrijetsRMissed (Reply 15):
The weight increase is offset by the better than expected engine performance, meaning that the A380s performance is as expected.
None of the big vocal purchasers (SIA, Qantas, EK) have voiced issues with the performance figures of the aircraft, therefor I still don't believe this is relevent for this discussion - so far there have been no demonstratable performance issues with the A380.
aeroweanie
Mon Jun 18, 2007 11:48 pm
No, this was not the cause of the performance shortfalls!!!
When a manufacturer considers buying an engine, the engine manufacturer supplies a computer program that simulates the engine performance, called an engine deck. Typically, Boeing and Airbus audit these decks, using their experience, and make them a little more conservative. Douglas at the time didn't have a lot of money, so they decided to trust the engine manufacturers and not audit the decks. As expected, the decks were optimistic and in flight test, they were found to burn 2-5% more fuel than the decks claimed. Douglas then scrambled to produce aerodynamic fixes that ended up partly recovering this deficit.
cloudy
Tue Jun 19, 2007 1:25 am
Hi guys,
Nobody is claiming the MD11 ever was a poor performer from a pilot's perspective. It had adequate thrust and handles well enough, The problem was that the payload/range was less then promised and the fuel burn was more than promised - at least initially.
wilco737
Tue Jun 19, 2007 1:41 am
Quoting Cloudy (Reply 18):
I just wanted to clear this up! Because I heard about complains about the performance... and I never experienced any... I am really impressed about he performance...
WILCO737 (MD11F)
 airplane
vmabuck
Tue Jun 19, 2007 11:26 am
I see a lot of under spec situations from the Airlines. I see parts fail prematurely due to too much stress/heat/current loads. At the moment it seems to be the actuator world that is affected the most; for the last few months anyway. Well minus a few power panels here and there (AAIB Bulletin S2-2007)
Another trend I notice is how quickly someone like Airbus or Boeing will put out a Service Bulletin to focus attention on the OEM. When you go to someone and ask them to build a part to your spec, you should be willing to step up and admit your responsibility in the situation.
Happiness is Vectored Thrust!
vmabuck
Tue Jun 19, 2007 12:08 pm
Quoting Vmabuck (Reply 20):
Edit*
I see a lot of under spec situations from the Aircraft manufacturers.
TrijetsRMissed
Wed Jun 20, 2007 4:02 pm
It is unfortunate how badly the MD-11 is looked upon in terms of payload/range. Consider this, in 1995 when both the A343 and 772 where in full production, the MD-11 greatly outperformed both of its competitors. The 777 may have been the a media darling, but the 772A models lack the MD-11ER by 2,000nm in range! The A343 also lacked in range and was far slower. This assumes each airliner is loaded with approx 300 passengers, give or take a little depending on the type. Not to mention the tri-jet has ample cargo space.
Since then, both the 777 and A340 series have improved variants, which surpass the MD-11. But for its time the MD-11 held its own. And who's to say if production and support for the type continued that newer versions of the MD-11 wouldn't have continued that trend?
XT6Wagon
Thu Jun 21, 2007 12:28 pm
Quoting Moo (Reply 10):
not being certifed, no production certificate are just minor performance issues the A380 has had after it was schedualed to be delivered.
Also if you think "IFE" wiring is the cause of the delay, I got some ocean front property in Tibet to sell you.
moo
Thu Jun 21, 2007 8:22 pm
Quoting XT6Wagon (Reply 22):
If those are performance related in the context that we are discussing with regard to the MD-11, Im the King of the United British Colonies of the North Americas.
Of course you can open up the context as wide as you personally like to attempt to bring the A380 into this.
Having *personally* seen the work going on in Hamburg, unless you have significant evidence that isnt someones blog somewhere, Im going to have to call bullsh*t on this one.
Dougloid
Fri Jun 22, 2007 1:43 am
Define performance problems. What were they, and how do you know this? Please do not cite wikipedia.
Quoting TrijetsRMissed (Reply 5):
Correct. I was there. I spent a lot of time crawling around inside 447.
The flight manual was revised to trim the aircraft for a more rearward flight cg. This is more efficient and yielded better fuel economy, Unfortunately all those performance tweaks came about after Singapore cancelled the order for 20.
Quoting TrijetsRMissed (Reply 7):
The only reason you say that is because there's no A380 performance numbers to assess yet-there ARE a lot of press releases from Airbus though. The information's being carefully controlled and until there are concrete numbers from operators it would be wise to take anything the manufacturer says with a grain of salt about the size for the ones we put out for cattle.
There's a lot of 'performance' misinformation about the MD11 and its predecessor the DC10 in this forum and elsewhere. One time I was going cross country with the old lady and I ask here "So honey, what do you think about the DC10?" She says "Oh, I wouldn't fly on one, everyone knows they're death traps." So I say, "OK then, what about this airplane and this flight? " She says "Oh this is much different-quiet and smooth." I say, "This is a DC10 we've been riding in for the last three hours".
moo
Fri Jun 22, 2007 2:59 am
Quoting Dougloid (Reply 24):
Both EK and SIA have stated (EK on more than one occasion) that they are happy with the performance of the aircraft - so unless they are being lied to by Airbus and GE/RR (not sure what engines each has atm), seems they are getting performance figures they like.
Fri Jun 22, 2007 3:16 am
Classic.
It can be argued that some accidents make a type safer since improvements are made based on what went wrong. And even without such events, types are continuously improved. But the general public seems to think that the last aircraft that rolls off the line is identical to the first.
Quoting TrijetsRMissed (Reply 21):
Rumor hath it LH Cargo wanted more MD-11Fs, but Boeing dragged them away kicking and screaming.
Dougloid
Fri Jun 22, 2007 4:10 am
Quoting Starlionblue (Reply 26):
I could believe that. Boeing let the line bleed to death.
Quoting Moo (Reply 25):
Saying someone's allegedly happy (whatever that means) is not a substitute for performance numbers and is in no sense a basis for saying that you (meaning you personally) are in possession of data that as far as we know have not yet been made public.
Remember the only intelligent thing Ronald Reagan said: Trust but verify.
moo
Fri Jun 22, 2007 4:39 am
Quoting Dougloid (Reply 27):
I made no statement about me personally having performance figures, however I take the public statements (no alledgedly here, the comments came from EK and SIA themselves) of the A380s major customers (who have both been extremely vocal when it comes to deficits on Airbuses part as well) well above an A.netters opinion on these matters when push comes to shove.
Fri Jun 22, 2007 5:11 am
Hehe. But what about: "How do you tell a communist? Well, it's someone who reads Marx and Lenin. And how do you tell an anti-Communist? It's someone who understands Marx and Lenin."
wilco737
Fri Jun 22, 2007 1:03 pm
As you said: only a rumour...
WILCO737 (MD11F)
 airplane
Dougloid
Fri Jun 22, 2007 11:33 pm
Quoting Moo (Reply 28):
What you said more or less was EK and SIA are happy so unless GE and RR are lying to them everything's just peachy keen with A380 performance.
Aircraft performance has a lot more to it than fuel burn, which is what I assume you're talking about. My opinion isn't important and neither is yours. But what I AM saying is that this is very much uncharted territory at present that cannot be reduced to merely accepting that if EK and SIA are happy then everything's great.
Quoting Moo (Reply 23):
That's fine, but that's a one dimensional viewpoint. there may be other things going on about that you and I do not know about.
Why is the airplane sitting on its ass parked on the ramp instead of going out to Singapore to make money?
TrijetsRMissed
Sun Jun 24, 2007 1:37 pm
Indeed, that was a significant blow to the MD-11 program, from which it never recovered. I don't think it's any coincidence that the MD-11ER was launch was announced at the Singapore Air Show in Feb. 1994.
Absolutely. You'd think that everything Douglas built after the DC-9 was crap if you believed everything you read here. The DC-10, while had it's unfortunate accidents, greatly outperformed the L1011-500, -30 that is. The MD-11 has been greatly under appreciated, granted not much can currently come close to the 772LR & 773ER.
This is not a rumor. LH order for 10 firm with 10 options in September of '96 came before the "merger." Once the takeover was complete, Boeing was reluctant to allow LH to convert further options to firm orders or place new orders. Boeing feared with SV order, that the MD-11F program was picking up steam, which would hurt 744F sales. The decision to terminate production because of a "lack of interest" in the market is pure BS.
Believe what you want, but I remember reading articles of the airframe being heavier than expected as early as 2005. Do you really think it takes Airbus 36 months to solve wiring issues, and wiring alone?
Quoting Dougloid (Reply 31):
 checkmark  Exactly!
XT6Wagon
Sun Jun 24, 2007 2:28 pm
yes its clearly not a performance issue that for the first year and a half after the delivery date in the contract its managed to haul $0 of revenue.
If thats not a performance issue I don't know what is.
