bongo
Window Cracked In Flight, Procedure? (pic)
Sat Jun 16, 2007 11:13 pm
What is the procedure in this case?
Three hours before landing, over the atlantic, must be scary!
Photo © Christian Frei
MDE: First airport in the Americas visited by the A380!
xjramper
RE: Window Cracked In Flight, Procedure? (pic)
Sat Jun 16, 2007 11:22 pm
This thread needs to be moved over to tech ops.
But my recollection says that its actually a two pained glass. This has been discussed before. But lets atleast get this to the correct forum.
XJR
Look ma' no hands!
aileron11
Sun Jun 17, 2007 12:32 am
From looking at the picture, I say the visabality is bad, but if he can use the wipers the visabality will improve. Most of the blurr is from the rain not the cracks.
Jersey Lou
OPNLguy
Sun Jun 17, 2007 12:48 am
Unlike what the movies show ("Cliffhanger" and "Eraser" come to mind), aircraft windshields are not single pane glass and do not shatter, per se. They are made from multiple layers with heating elements in between, and the inner and outer panes are glass.
IIRC from a previous thread, the picture in question shows that the outer pane has cracked, and the rest of the window is fine. If an inner pane cracks, one usually has to lower the cabin pressure differential and one decends to a lower altitude. I say "usually" because I'm not familar with every QRH for every different aircraft out there.
MD11Engineer
Sun Jun 17, 2007 7:19 am
Aircraft windshields resemble bullet proof glass. They usually consist of 3-5 layers of mineral glass alternating with acrylic (total thickness about 1-2 inches and very heavy).
Between the outer (mineral glass) and the next layer there is a conductive layer, through which electric current is routed for windscreen heating. The temperature is being regulated by a window heat controller unit (WHCU) using a small temperature sensor laminated into the window. In this case I think that the WHCU or the sensor were defective, causing the outer layer of window to overheat and crack. Obviously the window will have to be changed on ground.
Jan
mohunk
Sun Jun 17, 2007 11:17 am
Try:
www.acaptainslog.blogspot.com/2007_04_01_archive.html
for more on shattered windshields.
A320ajm
Mon Jun 18, 2007 5:46 pm
Quoting Bongo (Thread starter):
I think for the procedures you descend to a lower altitude to relieve the pressure of the screen. You are supposed to turn the heating off the windscreen because this can cause the crack to get worse. Finally, i would suspect that the crew, both cabin and flight, would be prepared for an emergency descent and procedures in case the screen broke, such as what happened on BA flight 5390. This would then be classed as a rapid decompression and the procedures would be taken from there.
A320ajm
If the British Empire and its Commonwealth last for a thousand years, men will still say, 'This was their finest hour.'
greasespot
Mon Jun 18, 2007 6:01 pm
Quoting A320ajm (Reply 7):
 no  On the B727 and B737 You just fly normally. The MEL even lets the airplane be dispatched on the capt's discretion if there is no maintence avaliable at the base. It says something about as long as the pilot vies is not distorted...
GS
Sometimes all you can do is look them in the eye and ask " how much did your mom drink when she was pregnant with you?"
jamesbuk
Mon Jun 18, 2007 8:55 pm
Just out of interest, isnt that a bit of "6 and 2, 3's" ? If your higher up you have a bigger pressure diferential but if you descend you have denser air hitting the screen maybe forcing a crack further. Thoughts?
Rgds --James--
You cant have your cake and eat it... What the hells the point in having it then!!!
flymatt2bermud
Tue Jun 19, 2007 1:03 am
Our SOP in the event of a cracked windshield is pretty straight forward.....1) JUMP.
Sorry, I couldn't help myself. All aircraft windshields by certification must be able to withstand cracking beyond typical exposure. I flew the Challenger 601 and 604. They had acrylic windshields which have a history of failure. Most incidents of 601 or 604 cracked windshields are within tolerance for dispatch or continued trips with an hourly and/or short calendar limitation. We found the best way to prevent cracking was to wax the windshields once a month. This would prevent moisture from getting between the windshield layers and we never had a problem with our aircraft. The waxing of windshields was also bery beneficial as the Challenger 600 models do not have wipers.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward" Leonardo Da Vinci
A320ajm
Tue Jun 19, 2007 1:38 am
Quoting Jamesbuk (Reply 8):
Just out of interest, isnt that a bit of "6 and 2, 3's" ? If your higher up you have a bigger pressure differential but if you descend you have denser air hitting the screen maybe forcing a crack further. Thoughts?
Rgds --James--
But there is less of a differential from the outside to the inside, as the pressure in the cabin is similar to that of a low altitude.
A320ajm
Wed Jun 20, 2007 8:24 pm
Quoting Greasespot (Reply 7):
Any MEL reference.
regds
MEL
Users browsing this forum: Balerit, Classa64 and 1 guest
