speedracer1407
777 LCD Display Frames
Mon Jun 18, 2007 12:18 pm
I've been meaning to ask this for a while--on the below 777 cockpit photo, the LCD display screan frames appear to have a hinge of some sort, but only at the bottom. The fact that this "hinge" doesn't have a corresponding one on the top leads me to believe that it's not a hinge. So what is it?
Photo © Werner Horvath
777wt
RE: 777 LCD Display Frames
Mon Jun 18, 2007 1:24 pm
If you look closer, the bar on the bottom is raised, as it's seperate from the whole frame.
Unscrew the screw/knob on the right of the hinge and you can flip it open to get access.
speedracer1407
Mon Jun 18, 2007 2:25 pm
Ah hah. So simple. Should have looked closer. Thanks.
TEBGuy
Thu Jun 21, 2007 7:18 am
Quoting 777WT (Reply 1):
Access to what?
[Edited 2007-06-21 00:18:57]
Remember, taking off is optional, landing is mandatory.
atlamt
Thu Jun 21, 2007 7:35 am
Quoting TEBguy (Reply 3):
Access to what?
Access to remove the screen.
Fwd to MCO and Placard
Thu Jun 21, 2007 4:44 pm
Quoting ATLAMT (Reply 4):
Is the Screen removable.Or is the entire LCD Display unit removable.
regds
MEL
Tristarsteve
Thu Jun 21, 2007 6:37 pm
Quoting HAWK21M (Reply 5):
Our B777 have cathode ray tubes., not LCDs. But the whole unit comes out. All 6 screens are the same so can be interchanged if one fails, to comply with the MEL. They slot into a frame with fitted connectors.
GearDownPlease
Thu Jun 21, 2007 7:13 pm
Quoting TristarSteve (Reply 6):
Feel free to correct me but... aren't all 777 flight decks equipped with Honeywell LCD screens ? I think it was even a Boeing argument in the 777 design phase, that LCDs are lighter than CRTs, due to the fact that the first generates less heat than the second, meaning that it needs a lighter cooling system.
Best regards, GearDownPlease
CItro�«n SM ? Sa Majest�© !
Tristarsteve
Fri Jun 22, 2007 12:35 am
Quoting GearDownPlease (Reply 7):
Yes you are right. I stand corrected. I had to look in the AMM to check. The reason is when I interchange them they are so big and heavy I assumed they are CRTs. They are 8.75in deep 8x8 in screens and weigh 18lbs.
Fri Jun 22, 2007 6:07 pm
Quoting Tristarsteve (Reply 8):
Can the Screen in off position give a sign if a display unit is a CRT or LCD.Any way of telling.
regds
MEL
Users browsing this forum: KarelXWB, slcguy and 12 guests
