Markhkg
Airbus Doors And Cabin Pressure
Sat Jun 23, 2007 11:10 am
Here's a question for all you Airbus guys:
Comment on the following statement:
"The A320 family of main cabin doors do not have vent doors to remove residual pressure."
The reason why I have this question is that I can see the vent doors on the B-777 and the E-170 when the door is opened. But my understanding is that the Airbus series doors do not have vent doors, which is why they have the red "CABIN PRESSURE" light that can be seen inside and outside. Therefore, the ability to open the door in a slightly pressurized cabin rests solely on the cockpit getting rid of the pressure, which is in contrast to the B-777 which will vent out the excess pressure with the vent.
Thoughts?
FlyingColours
RE: Airbus Doors And Cabin Pressure
Sun Jun 24, 2007 7:48 am
As former A320 cabin crew it is my understanding that the doors do not have vents (just like you mentioned) and that any excess cabin pressure will result in a warning light which is clearly visible in our door area, at that point it is on us to call the Flight Supervisor/ Cabin Chief / Purser who will call the flighdeck and the pilots will check the cabin pressure levels and manually open the outflow valve (manually as in set the valve control to manual and then set to full open).
I don't know why the A32X doesn't have a valve like you said however from experiance I can't say I have ever seen one one the 737-300/400/800 or the 757-200 either.
Phil
FlyingColours
Lifes a train racing towards you, now you can either run away or grab a chair & a beer and watch it come - Phil
WNCrew
Sun Jun 24, 2007 8:21 am
Quoting FlyingColours (Reply 1):
My understanding is that under normal operation any residual pressure in the cabin in a 737/757 is released through outflow valves when the main gear compresses upon intial touchdown and subsequent landing rollout.
Sun Jun 24, 2007 9:03 am
Quicker, and IMHO safer and more practical to crack open the cockpit window, if there is residual pressure, it would be due to a problem with the system, opening the window gives me instant inequivable feedback.
Quoting WNCrew (Reply 2):
Same on the airbus.
2enginesonly
Sun Jun 24, 2007 9:28 am
As a former 757 tech I can tell you that these vents are absolutely installed on that ship.
These valve are the top and bottom lip of each door which folds inwards when you open the door.....I have no experience with the 737 though however this might change  Smile
Arjan
WNCrew
Sun Jun 24, 2007 11:57 am
Quoting 2enginesonly (Reply 4):
The 737 operates the same way, but these flaps are not "vents"...they are not there to equalize pressure as they rotate INWARD...not OUTWARD...and they only do so when the door control handle has been moved past a certain point. The reference to the A318-19-20-21 valve (also reffered to as a "flap") is actually just THAT, it allows pressures to equalize between exterior and cabin.
The flaps on the 737-757 only serve as a means to "shrink" the outer surface area of the main doors so they can be opened and closed since the doors themselves are larger than the openings and to OPEN, the doors must first come into the cabin before rotating out.
Markhkg
Sun Jun 24, 2007 4:16 pm
Thanks for the replies everyone. I'm just curious why Airbus did not opt to install vent flaps into the doors, considering the deaths of at least two cabin crew in two separate incidents involving the A300.
What worries me is that the red "CABIN PRESSURIZED" warning light on the A320/A330/A340 family doors do not activate if the cabin crew are trying to open the door in emergency mode -- i.e. during an evacuation -- which puts them at risk of a sudden opening of the door if the cabin is still pressurized. The warning light only comes on if the door is disarmed.
jetmech
Sun Jun 24, 2007 4:34 pm
Quoting WNCrew (Reply 5):
True, but I also think that safety is just as an important reason for the vent flaps. The door handle is mechanically linked to the vent flaps which physically prevents the door handle being moved to the open position if there is a cabin pressure differential. The flaps are rigged to move before the opening mechanism, so that even if someone is strong enough to force the handle when the cabin is pressurised, the vent doors will at least vent some of the pressure differential. These vent doors are also fitted to the cargo doors of many Boeings.
Photo © Wolodymir Nelowkin
Quoting MarkHKG (Reply 6):
It does seem to be one of the noticeable differences between Boeings and Airbus. In many critical areas on the 747, Boeing will usually fit some sort of mechanical device to physically prevent something from being activated or moved when it is unsafe to do so. Airbus tends to usually only have some sort of light or buzzer or electrical disconnect to do the same. There does not seem to be as many mechanical interlocks on an Airbus, which then puts the onus back on the individual to be sufficiently trained to recognise these warnings.
Regards, JetMech
Users browsing this forum: battlegroup62, Google [Bot] and 1 guest
