SEPilot
RE: Stupid 777 Fact That Is Bugging Me!
Fri May 10, 2002 8:01 pm
Quoting OldAeroGuy (Reply 16):
Who said all the ratios are the same?
I didn't; in fact I said that if they weren't that could account for the difference.
Boston92
Sun Jul 01, 2007 10:09 am
Why is the 777-200 one inch taller (tail height) than the 777-300?
[Edited 2007-07-01 03:09:46]
"Why does a slight tax increase cost you $200 and a substantial tax cut save you 30 cents?"
Go3Team
Sun Jul 01, 2007 10:23 am
I think it's because shorter planes need taller tails, although one inch probably doesnt make much difference. Could be, they have the same gear, and the inch difference is due to the weight.
Yay Pudding!
lehpron
Sun Jul 01, 2007 11:24 am
Quoting Boston92 (Thread starter):
I grow an inch every time I sleep and loose it throughout the day.  Wink
Sun Jul 01, 2007 11:55 am
Quoting Go3Team (Reply 1):
Both good theories.
Viscount724
I stand to be corrected but I'm almost certain the the tails themselves are the same height on all 777s but the overall height from the ground to the top of the tail probably varies slightly due to the different overall lengths and weights etc. I believe the landing gear is also somewhat different on the -300ER vs. the standard -200 and -300.
roseflyer
Sun Jul 01, 2007 3:39 pm
I would assume it has something to do with the modifications done to the landing gear for the 777-300. 1 inch isn't that much, but could be accommodated with a different gear.
A342
Sun Jul 01, 2007 5:49 pm
I also think it has got to do with the landing gear. Maybe the 777 has a (very small) "negative AOA" on the ground. As the nose gear length is the same, the shorter fuselage of the 772 makes the tail stand up higher than on the 773.
Exceptions confirm the rule.
OzTech
Sun Jul 01, 2007 9:31 pm
Just a thought but it might have something to do with the tyre size.. Ply ratings etc. I know the different versions of most Boeings have different ply ratings and diameters etc.
No defect too big, no defect too small, nothing in the log --- No defect at all !!
KFLLCFII
Mon Jul 02, 2007 1:39 am
Why is the tail taller on the 747SP compared to the regular 747 models?
Why is the tail taller on the 736 compared to other 737 models?
Why is the tail taller on the A318 compared to other A32X models?
Because shorter (length-wise) aircraft, in order to get the same amount of lateral performance out of the rudder for engine-out operations, need a larger surface area on the tail to account for the decreased distance of the moment "arm" about the CG.  Wink
And yes, that extra "inch" of additional height can make all the difference in the world with regard to Vmc (minimum-controllable airspeed with an engine out).
"About the only way to look at it, just a pity you are not POTUS KFLLCFII, seems as if we would all be better off."
OldAeroGuy
Mon Jul 02, 2007 2:46 am
Quoting KFLLCFII (Reply 8):
Good thinking, but there is no difference in vertical tail sizes between the -200 and -300 models.
Quoting A342 (Reply 6):
You're on the right track, but the concept is wrong. A negative attitude on the ground would mean the longer body airplane would have the tip of the vertical higher off the ground.
Actually it's the weight and the gear. The documents below give a range for the distance between the tip of the vertical tail and the ground. This distance varies as a function of airplane weight, CG position, and gear strut charge pressure.
Model Min Dist Max Dist
-200 60' 5" 61' 6"
-300 60' 5" 61' 6"
-200LR 60' 8" 61' 6"
-300ER 59' 10" 61'10"
http://www.boeing.com/commercial/airports/acaps/777rsec2.pdf
brettbrett21
Mon Jul 02, 2007 3:36 am
I have another questionable fact. I dunno where I heard this and I'm pretty sure that it's wrong.
Is the horizontal stabilizer of the 777 roughly the same size as the 737's wings?
i'm so excited i wish i could wet my pants!
Boston92
Mon Jul 02, 2007 3:45 am
Quoting Brettbrett21 (Reply 10):
The 777 Horizontal Stabilizer is 66 feet wide, the wingspan of the 737 is 112 feet, so yeah, the 777 HS is larger than a 737 wing.
Viscount724
Mon Jul 02, 2007 6:41 am
Quoting OldAeroGuy (Reply 9):
Assuming you're referring to the 747, the -200 and -300 are the same length.
legoguy
Mon Jul 02, 2007 8:22 am
Slightly off topic but I thought the fact was more along the lines of the A380 horizontal stabilizer is the same size as a 737's wing.
Can you say 'Beer Can' without sounding like a Jamaican saying 'Bacon'?
jetmech
Mon Jul 02, 2007 11:58 am
Could be the extra sag in the longer fuselage  Wink !
Regards, JetMech
SEPilot
Mon Jul 02, 2007 8:41 pm
Actually, both of you are wrong. If the landing gear are both the same length and the ratio of the length from main gear to nose gear and main gear to tail is the same, the tail height will be exactly the same regardless of length, although the angle will be different. If the ratio changes the height will also change, which may account for the difference.
OldAeroGuy
Tue Jul 03, 2007 1:04 am
Quoting SEPilot (Reply 15):
Boston92
Tue Jul 03, 2007 1:57 am
Quoting SEPilot (Reply 17):
5 years 1 month 3 weeks 3 days 5 hours ago
I started the thread yesterday, a.net is broken...
SEPilot
Tue Jul 03, 2007 3:45 am
Quoting Boston92 (Reply 18):
Are you sure? Perhaps you took a quick unwitting trip in your time machine....
brettbrett21
Tue Jul 03, 2007 8:36 pm
Quoting Boston92 (Reply 11):
I actually *gasp* looked it up after I asked, man do I feel dumb!
A342
Tue Jul 03, 2007 8:44 pm
Yes, but because the forward fuselage is also longer (on the 773), the negative attitude should be reduced, shouldn't it?
OldAeroGuy
Tue Jul 03, 2007 10:13 pm
Quoting A342 (Reply 21):
As noted earlier, the change in tail height depends on the ratio between forward and aft body stretches. Note that there is no difference between 772 and 773 vertical tail ranges in Reply 21.
-200 60' 5" 61' 6"
-300 60' 5" 61' 6"
InnocuousFox
Tue Jul 03, 2007 10:55 pm
I like the 777 fact that you can fit a 737 or MD-80 fuselage inside a 777 engine.  Smile
Dave Mark - Intrinsic Algorithm - Reducing the world to mathematical equations!
Users browsing this forum: slvrblt and 2 guests
