SABE
Error In AA New Routemap Software On B767
Mon Jul 02, 2007 1:12 am
Hi everyone,
I've recently flown several routes on AA's B767 with the updated interior (new business class seats). The flight map software was also updated on these planes, with nicer higher-resolution maps. However, I noticed an error and I wonder how to contact AA or the vendor to get it fixed. I think that the "date" on the map is probably set to January 1st by default and it is not updated -- I don't know if this should be done by the cabin crew or the pilots because I don't know how the system works.
The error is quite noticeable on the world map that shows the flight path, because the Sun is always located on the tropic of Capricorn (23 degrees southern latitude), so that the shaded area of the map that denotes "night time" is very much incorrect, specially at this time of year when the Sun is on the tropic of Cancer (23 degrees northern latitude). A more serious problem related to this is that the "time in Dallas" is always shown with daylight savings off and as a result, the flight software says that the plane will be arriving one hour earlier than the real arrival time. This could pose a problem for inexperienced travelers with short connecting times.
I'm attaching two images, of the map that was shown in the plane, and the one that should have been shown, to illustrate the problem.
So, who should I contact about this?
--Lucas
Big version: Width: 637 Height: 318 File size: 36kb
day/night map that was shown
Big version: Width: 638 Height: 321 File size: 48kb
day/night map that should have been shown
TUS-DFW-EZE... can't wait to visit home again!
OPNLguy
RE: Error In AA New Routemap Software On B767
Mon Jul 02, 2007 2:04 am
Quoting SABE (Thread starter):
I don't know how it works either, but it almost sounds like a computer running it is using DOS and its 01-01-80 default date.  Wink
AAR90, if you're out there, any idea if this system (part of the IFE package, I presume) gets its time info from a dedicated computer, or is there an input from the FMS?
auslimbo
Mon Jul 02, 2007 6:23 am
These look like maps from the Airshow 4200 System.
It's a seperate system with its own dedicated computer.
The System gets its information from various sources (such as FMS, ACARS, CMC).
It can be programmed through the IFE System and, if installed, through an ACU (Airshow Control Unit, installed in the VCC) but these program changes would mostly only be destination location or arrival time.
In this case, I think it's best to inform the airliner so they can contact Rockwell to update the software (uploaded into the system via USB) or if they have dedicated personnell, they can do it themselves.
AAR90
Mon Jul 02, 2007 8:03 am
Quoting OPNLguy (Reply 1):
Sorry, I haven't got a clue. Then again, I haven't flown a 767 in almost a decade.  Wink
Try AA Customer Relations at: http://www.aa.com/apps/utility/conta...fileName=aaCustomerRelations.jhtml
SABE
Mon Jul 02, 2007 2:10 pm
Thanks guys, I'll try customer relations but just in case next time I board a 767 I'll talk to the purser  Wink
KELPkid
Mon Jul 02, 2007 2:22 pm
Actually, if it's pulling down information from GPS, then it's privy to time signals 24 hyper-accurate atomic clocks that just happen to be orbiting the earth...  Wink The time is encoded in the NMEA 182/183 data.
SABE
Mon Jul 02, 2007 11:33 pm
Quoting KELPkid (Reply 5):
But it clearly can't be, otherwise it wouldn't have the wrong date in the system. My hunch is that while the routemap software is taking to the FMS at some level (to get the position, heading, speed, etc.), the actual date/time is either not being passed along, or the routemap software is misconfigured and is not receiving it properly. Since this system was installed fairly recently on the AA B767's, they probably haven't worked out all the bugs yet.
Tue Jul 03, 2007 2:16 am
Quoting SABE (Reply 6):
And they never will...  Wink
Couldn't resist. If you work with software you know very very little software is completely bug free.
SABE
Tue Jul 03, 2007 5:00 am
Quoting Starlionblue (Reply 7):
Agreed! I keep finding bugs in my programs all the time... but, you'd think that the developer of this flight map software could get the date right!!  Smile
Tue Jul 03, 2007 8:54 pm
Quoting SABE (Reply 8):
Agreed. Seems pretty basic. Big grin
lincoln
Thu Jul 05, 2007 12:35 pm
Naah, they just become features... remember "A 'feature' is a bug with senority!"  Smile
In this case, knowing next to nothing about Airshow but enough to be more than a little dangerous on the software end of things, I would guess that somewhere along the way someone assumed that since, clearly, whoever installed the unit would ensure that the proper date was configured and since most computers are more-or-less capible* of keeping track of the date/time on their own that there was no need to have the FMS (or GPS receiver or whatever) pass the date since that would just be redundant (not to mention require additional programming)
Lincoln
*- Some of the systems I work with are frighetningly good at keeping track of time...others can drift a net of as much as 12 minutes a day!
Users browsing this forum: FAST Enterprise [Crawler] and 2 guests
