jeffry747
Hydraulic Fluid And The 757
Sun Jul 08, 2007 1:02 am
As my crewmates and I were loading the rear belly of an outbound UPS 757 last night, we came across some cargo which sparked a discussion; 3 five gallon containers of Skydrol LD-4 fire resistant hydraulic fluid. They weighed in at 47 lbs. per can and were being shipped as COMAT (COmpany MATerial). We started pondering a few questions such as:
A) How much in U.S. dollars does this stuff cost? One person guessed $100 per 5 gallon can, I guessed $250 and one other guessed as high as $500 per can. Which is the closest estimate?
B) How much hydraulic fluid does a 757 require to be operational?
C) Since the label marked it as fire resistant, does that make Skydrol LD-4 a "higher grade" hydraulic fluid than any other?
D) Why is hydraulic fluid so darn heavy?
C'mon Big B, FLY!
roseflyer
RE: Hydraulic Fluid And The 757
Sun Jul 08, 2007 1:41 am
Quoting Jeffry747 (Thread starter):
I've heard that skydrol can be up to $40 per liter. I would think that $500 is on the lower side of how much it costs.
This is a rough guess, but I'll say 25 or so gallons.
I believe the high density is directly related to its performance. It is pressurized at 3000psi, so a denser fluid works better. I don't understand exactly why though.
avioniker
Sun Jul 08, 2007 1:53 am
Here's a little bit too much info for you. . . I've forgotten what the actual capacity is. Hawk, you out there???
http://www.757.org.uk/systems/sys7.html
 Smile
Sun Jul 08, 2007 4:10 am
Quoting Avioniker (Reply 2):
From what I remember something around 25litres for LH & RH reservoir each & 13 litres for CTR Reservoir.
Not sure about the Fluid trapped in the line.Would need to check it up.
regds
MEL
jetmech
Sun Jul 08, 2007 9:59 am
Quoting RoseFlyer (Reply 1):
The "LD" on the side of a can of Skydrol actually stands for Low Density! A 5 US gallon can is 18.925 litres, which according to Jeffry747, weighs 47lbs, or 21.354 kg. This gives Skdrol LD-4 an SG of around 1.128, which is a bit denser than water. I don't think there is any real relationship between the density a fluid it's suitability to high pressure, as all fluids by definition are incompressible. More important with respect to a hydraulic fluid would be the overall bulk modulus of the fluid.
Regards, JetMech
fr8mech
Mon Jul 09, 2007 10:28 am
Mel is correct on the reservoir quantities. I'd guess at least that much in the various systems. I wasn't able to find anything in the maintenance manual. But that kind of information is usually 'gee-whiz' type stuff found in training manuals.
I found an online source for LD4: 229.51 British Pounds per 5 Gallon drum. That's $461.40 at current rates.
roseflyer
Mon Jul 09, 2007 2:21 pm
Quoting Fr8Mech (Reply 5):
I don't know if anyone truly knows the exact volume of the system. It's pretty difficult to calculate the amount used by every actuator, every hose and every tube. Only once is the system ever filled completely from scratch, and that's in production. I don't think the system is ever completely bled in normal service although sections are.
Mon Jul 09, 2007 6:04 pm
I checked the AMM found the Quantities correct as remembered.  Smile
However no mention on total system capacity.
Will def try & find out though.
regds
MEL
Tristarsteve
Tue Jul 10, 2007 1:13 am
Can't help you on B757, but I have just serviced a B777 hyd system, and beside the refill point was a placard with the quatities.
Left tank 42 lts system 159 lts
Centre tank 89 litres system 337 litres
Right tank 41 litres system 155 litres.
I don't see many B757 so MEL, go out and check.
Tue Jul 10, 2007 7:56 pm
Quoting TristarSteve (Reply 8):
out here there are Two registered in the Country [VT-BDJ & VT-BDK] & Three from outside [AI leased B752,Ethiopean B752 & B752PF]
I'll try & check the docs.
regds
MEL
Mon Jan 21, 2013 9:26 am
Found this oldie , while posting a new thread......thought I'd add the Skydrol link for Information.
http://www.skydrol.com/pages/
rwessel
Mon Jan 21, 2013 10:09 am
Random Google search result:
http://www.skygeek.com/skydrol-ld-4-hydraulic-fluid-5-gallon.html
"Skydrol LD-4 Low Density Hydraulic Fluid - 5 Gallon
In Stock: 131 units. Ready to Ship: Today, Jan 21, 2013
International Orders
Part#: LD4-5GL
by Skydrol
Our Price: $493.57"
wingscrubber
Mon Jan 21, 2013 7:24 pm
Skydrol HD4, and Skydrol 5 are heavier, LD4 has a specific gravity slightly below that of water, HD4 and 5 slightly above. ALL are heavier than any of the red oils which are all lighter than water, Mil 5606, 87257 and 83282. Skydrol also has a higher thermal expansion coefficient.
'Fire resistant' is just marketing, the so-called 'flammable' red oils, 87257 and 83282 have equal or higher flash points, don't believe for a second that skydrol can't catch fire too. 5606 on the other hand is genuinely more flammable, but it's generally obsolete.
There's nothing 'high grade' about LD4, either skydrol brand or hyjet, it's just bog standard civil aircraft hydraulic fluid.
Skydrol 5 is supposed to be more advanced, IMHO the modern red oils are better, but the industry still loves skydrol for some reason, despite its numerous shortfalls. If I sound biased that's because I am.. for a reason too.
Resident TechOps Troll
Tristarsteve
Wed Jan 23, 2013 5:49 pm
Just found the following in a Boeing presentation (But can't quote it!!)
Hydraulic system total quantities in US gallons.
B767 L 18 C 43 R 20
B777 L 42 C 89 R 41
B787 L 21 C 49 R 20
KC135Hydraulics
Wed Jan 23, 2013 9:24 pm
Totally not regarding the 757, but I have KC-136 gee-whiz if you're interested!
Left HYD sys holds 21.5 gals, Right HYD sys holds 27.6 gals total. MIL-PRF-87257. A 55 gallon drum of this fluid costs the Air Force $1,733.68. Yikes!
MSgt, USAF
KC-135R / C-17A Pneudraulic Systems Mechanic Supervisor
yeelep
Wed Jan 23, 2013 10:16 pm
Quoting KC135Hydraulics (Reply 14):
Compared to Skydrol/Hyjet, that's cheap.
KC135Hydraulics
Wed Jan 23, 2013 10:30 pm
Of course the 136 is a typo. I can't seem to find the edit post function.
MSgt, USAF
Thu Jan 24, 2013 1:22 am
Quoting KC135Hydraulics (Reply 16):
Goes away after an hour. You missed it by 6 minutes and 38 seconds.
Sat Jan 26, 2013 7:09 am
Quoting Tristarsteve (Reply 13):
Interesting on the B767/787 numbers....I presume B764.
Users browsing this forum: baje427, JFK31R, meecrob, StereoTechque, Yahoo [Bot] and 2 guests
