jaylink
Strange Sound On 717 Before Engine Start
Mon Jul 09, 2007 2:48 am
Does anyone know what the unusual sound is on a 717 that happens approximately one minute before the engines start? Perhaps it is a pump -- it sounds a little like a pump, or even a brief, muffled electric drill. It goes "wrrrt!" for about a second, then stops for 2 - 4 seconds, and then does it again a few more times. The cycle repeats maybe 5 times in total.
I mostly notice the sound towards the rear of the aircraft, right around push-back time.
ATC-SIM: the browser-based air traffic control simulator http://atc-sim.com
calpilot
RE: Strange Sound On 717 Before Engine Start
Mon Jul 09, 2007 12:23 pm
Your right, it's the hydraulic pumps.
n710ps
Mon Jul 09, 2007 12:36 pm
Electric hydraluc pumps pressureizeing the systems.
There is plenty of room for Gods animals, right next to the mashed potatoes!
hangarrat
Mon Jul 09, 2007 12:47 pm
There was a thread along these lines last year, with regard to the DC9/MD80. The sound was described as a whoop-whoop sound. The greatly revered and respected SlamClick opined that it was something to do with the ignitors charging, as discussed below.
RE: WHOOP-WHOOP Sound On Engine Start UP (by SlamClick Nov 22 2005 in Tech Ops)
Far as I am from arguing with a man who flew the DC9, the hydraulic PTU sound often noted on the A32X series sounds similar. I've noticed both the sound on start up on the DC9 and the MD80, and the "barking" sound on the A32x often heard during taxi and shutdown. I wonder if they have similar explanations.
HR
Spell check is a false dog
FBU 4EVER!
Mon Jul 09, 2007 5:03 pm
It is the electrical hydraulic pump.It is usually switched on before pushback to pressurize the right hydraulic system, which is needed to raise the aft stairway (not on the 717 as it doesn't have one!), and prssurize the brakes.The "barking",or groaning,sound results from the pump operating to top up the hydraulic pressure to the 3000 lbs.
The pump is almost identical on all DC-9's and it's developments.
The "whoop-whoop" sound referred to above,is the ignition capacitors recharging during engine start.It interferes with the PA-system.
"Luck and superstition wins all the time"!
FBU 4EVER!
Mon Jul 09, 2007 6:36 pm
Having re-read my reply above,I realize that in my jet-lagged state,I've forgot to mention the Power Transfer Unit.It is this one that gives the "barking" sound.It is powered by the electrical hyd. pump and charges the left hydraulic system until the left engine driven pump takes over after engine start.Sorry!
skoker
Tue Jul 17, 2007 8:51 am
Are you talking about the same sound heard at :25-:30 here?
