Ballasts - Liquid Used.
Wed Jul 11, 2007 12:57 am
Photo © Calixius Casper Koh
What is the liquid used in these Ballasts & what weight.
regds
MEL
[Edited 2007-07-10 17:58:23]
aeroweanie
RE: Ballasts - Liquid Used.
Wed Jul 11, 2007 1:26 am
Typically, water is used. Its cheap and nonflammable.
Besides fluids, I've also seen lead shot and cat litter used as ballast.
Dougloid
Wed Jul 11, 2007 1:45 am
Quoting AeroWeanie (Reply 1):
When I worked for Garrett, new Falcon Jets came from France with lead plates (looked like battery scrap) and French beach sand.
Nobody wanted the lead plates so I took them home and started filling up the bottom of a gun safe. When I moved from the basin in 1983 I took all the plates to a salvage buyer and got myself five or six hundred bucks for my collection which was quite extensive..
WingedMigrator
Wed Jul 11, 2007 1:18 pm
Quoting HAWK21M (Thread starter):
I think it was A380 test pilot Jacques Rosay who said Bordeaux down one row, and Bourgogne down the other row.  Big grin
KELPkid
Wed Jul 11, 2007 1:33 pm
Quoting WingedMigrator (Reply 3):
Better hope that the pilots aren't sampling the merchandise before flight...  drunk  Then again, maybe France and the JAA don't have the 8-hour rule  silly
Wed Jul 11, 2007 5:14 pm
Why not use Gravel.
regds
MEL
XT6Wagon
Wed Jul 11, 2007 6:24 pm
Quoting HAWK21M (Reply 5):
Why not use Gravel.
Water is a good balast to use as its super easy to handle, and even better you can use a transfer system to move it around in flight so you can evaluate multiple CG configurations in a single trip. Oh and what are you going to do when you are testing MTOW takeoffs and want to land without flying around for 14hrs? Water balast is very easy and safe to dump overboard to bring the wieght below max landing wieght.
Wed Jul 11, 2007 11:48 pm
Quoting XT6Wagon (Reply 6):
How would the dump occur.Is there a routed over boad drain like the Galley drains.
regds
MEL
autothrust
Wed Jul 25, 2007 5:35 pm
I readed in a Magazine about A380 test flights and a Airbus test pilot declared its glycerin and not water. Because it doesnt freeze which means it keeps almost always the same weight unlike water.
“Faliure is not an option.”
airfoilsguy
Wed Jul 25, 2007 6:27 pm
Quoting AutoThrust (Reply 8):
Water changes weight?  eyebrow
It's not a near miss it's a near hit!!
autothrust
Wed Jul 25, 2007 8:00 pm
Quoting Airfoilsguy (Reply 9):
Well thats what i've readed when water freezes it gets a little havier, with all the ballasts on the A380 it can make a diffrence. Please correct me if 'm wrong.
[Edited 2007-07-25 13:04:18]
SEPilot
Wed Jul 25, 2007 8:10 pm
Quoting AutoThrust (Reply 10):
Well thats what i've readed when water freezes it gets a little havier, with all the ballasts on the A380 it can make a pretty diffrence.
It doesn't change weight (read mass); it changes density, which is a factor if it is floating in water but not in an airplane. Now if you were building an airplane that converts into a submarine you would have to worry about it unless the water/ice was completely contained in the sealed fuselage, where the only effect would be a miniscule increase in air pressure due to the larger volume of ice over water. However, I have not heard anyone propose such a beast, so I wouldn't worry about it.
autothrust
Wed Jul 25, 2007 8:27 pm
Quoting SEPilot (Reply 11):
Thanks for the info, i agree as i just checked myself this is right. However it was Uwe Rapsmeier Airbus Test Pilot which said its glycerin and not water. So if it isnt the weight why they would use glycerin instead of water?  Confused
Anyway i will search the article.
XT6Wagon
Wed Jul 25, 2007 8:31 pm
Quoting AutoThrust (Reply 12):
thermal issues I am sure. IE your tanks don't burst when cold soaking it or whatever.
SEPilot
Wed Jul 25, 2007 9:37 pm
Quoting XT6Wagon (Reply 13):
 checkmark
I think you've got it.
Wed Jul 25, 2007 9:40 pm
Thats an Interesting observation.I wonder why.
regds
MEL
Users browsing this forum: No registered users and 22 guests
