B752 & A321 Dimensions
Tue Jul 17, 2007 12:44 am
Can anyone provide the Practical A321 dimensions with the B752 ones I already have.
Needed to make a comparism.
Length -- 155 feet-3 inches
Width -- 124 feet-6 inches
Height (vertical stabilizer tip, top of the fairing to the
ground) -- 44 feet-6 inches
Wing:
Root Chord (calculated, at body centerline) -- 360.85 inches
Basic Chord (calculated) -- 286.50 inches
Tip Chord (calculated) -- 68.00 inches
Planform Taper Ratio
Tip Chord/Basic Chord -- 0.237
Tip Chord/Root Chord -- 0.188
Dihedral (wing reference plane in relation to the body
reference plane) -- 5 degrees
Sweepback (25 percent chord line) -- 25 degrees
Aspect Ratio -- 7.95
Mean Aerodynamic Chord (basic wing only) -- 199.70 inches
Horizontal Stabilizer
Span -- 600 inches
Taper Ratio -- 0.347
Sweepback (25 percent chord line) -- 30.186 degrees
Dihedral (horizontal stabilizer reference plane in relation
to body reference plane) -- 7 degrees
Aspect Ratio -- 4.496
Vertical Stabilizer
Height -- 293.374 inches
Taper Ratio -- 0.346
Sweepback (25 percent chord line) -- 40 degrees
Aspect Ratio -- 1.615
regds
MEL
Buyantukhaa
RE: B752 & A321 Dimensions
Tue Jul 17, 2007 9:13 am
I scratch my head, therefore I am.
Tue Jul 17, 2007 4:54 pm
Nice data.
Any three view comparism available between the Two as there was with the AN225,A380 & B744.
regds
MEL
Users browsing this forum: SAAFNAV and 1 guest
