B752 Alternate Flap/slat U/s
Tue Jul 17, 2007 5:03 pm
Since the B752 TE Flap & LE Slat mechanism is the same for both Hydraulic & Electric operation [Main & Alt],apart from the Hydraulic motor or Electric motor providing the drive.
Is there any way to know if the Electric motor has malfunctioned & the Hydraulic motor serviceable without operating Alternate flaps.
Also is there a fixed interval to test the Alt flap operation on this type or only post service check 500hrs.
regds
MEL
Mender
RE: B752 Alternate Flap/slat U/s
Tue Jul 17, 2007 5:54 pm
Task card 27-063-01 is a 2000 hr check of the Alternate flap/slat system. Testing it after a 500 hr check is probably company policy. A good policy too in my experience.
I don't know of a way to check the electric motor without operating it. If there is it would be more work than operating it anyway.
If you do the test correctly it is quick and easy. Do it wrong and the system will lock out. If this happens just cycle the FSEU C/B's on P11 and you should be back in business. (This only usually happens during heavy maintenance when things are operated out of the normal config)
Tue Jul 17, 2007 7:46 pm
Quoting Mender (Reply 1):
I Agree
Thats the concern.How do you know that your Electric motor is u/s prior to flight.
regds
MEL
boeingfixer
Tue Jul 17, 2007 8:26 pm
Quoting HAWK21M (Reply 2):
regds
MEL
The only way to do a confidence check of the Alternate Flap Motor is to operate the Alt. Flap system. Unless there is a suspected problem with the Alt. Flap system, it should be assumed that the system is functional. Especially if the previous maintenance inspection and functional checks were ok. The Alt. Flap system is one of the least used systems and the motor rarely fails. I've been working on Boeings for the past 10 years and have never had a failure of one on our fleet of 727's and the B757 system is very similar. The part that does fail for us is the hyd. flap motor bypass valve. This usually results in normal flap system failure.
John
Cheers, John YYC
Users browsing this forum: kalvado and 2 guests
