bio15
Green Painted Taxiway Centerlines?
Wed Jul 18, 2007 4:35 am
Hi, I came across this picture in Nuremberg which shows green painted taxiway centerlines.
Photo © Konstantin von Wedelstaedt
I had seen green centerline lights used at night, which are also visible on this picture along the paralell taxiway behind the aircraft, but I had never seen green painted taxiway centerlines. Does green paint have any special meaning? The taxiway centerline that is being followed by the aircraft is regular yellow. There's a definite distinction among the two, and it would be more noticeable during daytime. Any insights?
Alfredo
aidoair
RE: Green Painted Taxiway Centerlines?
Wed Jul 18, 2007 5:37 am
I'm not entirely sure but i think it is something that aids visibility on the ground in snowy conditions, similar in Switzerland they have yellow markings on the runways at certain airport to aid better visibility on the ground with snow etc. Or perhaps they may have just run out of the yellow marking  Wink .
Aidoair   Smile
[Edited 2007-07-17 22:39:12]
MDorBust
Wed Jul 18, 2007 5:56 am
It appears to be a ramp area only marking
Photo © Gerhard Plomitzer
Left side of the image.
"I KICKED BURNING TERRORIST SO HARD IN BALLS THAT I TORE A TENDON" - Alex McIlveen
vikkyvik
Wed Jul 18, 2007 8:34 am
Quoting MDorBust (Reply 2):
Maybe something to do with the fact that when there are aircraft parked there (as there are in the photo), you can't actually use that taxiway?
Just a guess.
AirportSeven
Wed Jul 18, 2007 8:44 am
Color coded parking lead-ins?
Wed Jul 18, 2007 5:01 pm
Quoting Vikkyvik (Reply 3):
Thats what I thought too.Subject to Area clear,can be used as a taxipath.
regds
MEL
atct
Wed Jul 18, 2007 10:18 pm
I thought that ICAO did away with the color coded routes. Not sure the reason. At IAH we use "Spots" (big round yellow spots with a black number emblazed in the middle) to mark entrance and exit corridors into the ramp control area. (When we re-did out last spot last month, I know there was something about that was the ICAO preferred or mandated way...not 100% sure).
ATCT
Trikes are for kids!
Mir
Wed Jul 18, 2007 11:22 pm
I think FRA has colored centerlines on a portion of the ramp as well - just from memory, the center one is yellow, and is used for big planes, but there are two other centerlines on each side which can be used for smaller planes with smaller wingspans.
-Mir
Viscount724
Thu Jul 19, 2007 2:19 am
Quoting Aidoair (Reply 1):
This reminded me of the following related thread referring to yellow runway markings in Norway. RE: Yellow Runway Markings- Why? (by JHSfan Aug 18 2006 in Civil Aviation)
I can't recall seeing yellow runway markings in Switzerland, at least at the major airports (GVA/ZRH) but perhaps you are referring to smaller airports.
LTU932
Thu Jul 19, 2007 9:31 am
Just to name a few examples of airports with yellow runway markings, some of them are SVG, KSU and OSL.
Photo © Eduard Brantjes
Photo © Anders Presterud
Photo © Thomas Lorentzen
The way it looks, Norway is probably the only country (or one of the very few countries) with these yellow markings, probably due to its close location to the polar circle.
MDorBust
Thu Jul 19, 2007 10:24 am
Quoting LTU932 (Reply 9):
The way it looks, Norway is probably the only country (or one of the very few countries)...
Japan also has at least one runway marked with yellow.
Last I saw Niigata it was marked in yellow.
I believe that Yamagata is also yellow, but have never been there... Sounds like it's time to sechedule another vacation.
LTU932
Thu Jul 19, 2007 12:26 pm
Quoting MDorBust (Reply 10):
Make sure to make a TR with pictures on the way.  Wink
MD11Engineer
Thu Jul 19, 2007 1:26 pm
Quoting Mir (Reply 7):
-Mir
Yes, on the ramp in front of terminal 2, between the E/D positions at the terminal and the V positions on the far side of the ramp. The line running along the center of the ramp is yellow (for big planes), but there are two additional lines, one blue, the other orange, for aircraft with a smallr wingspan, which then fit on the taxiway side by side.
Jan
[Edited 2007-07-19 06:26:50]
Mir
Thu Jul 19, 2007 2:40 pm
Why would proximity to the polar circle be a factor causing one to paint runway markings yellow instead of white?
-Mir
Soku39
Thu Jul 19, 2007 3:52 pm
Quoting Mir (Reply 13):
my guess would be snow.
The Ohio Player
SailorOrion
Thu Jul 19, 2007 8:54 pm
Quoting MD11Engineer (Reply 12):
MUC has similar coding for T1 too, and for some of the T2 "crossovers"
T2: See the lower left. The "main" taxiways are apparently widely spaced  Smile
Photo © Michael Fritz
T1: Best to see in the middle between the UA and US tails, a red and a blue curved taxiway.
Photo © Florian Kondziela
Hope this helps,
SailorOrion
mhodgson
Fri Jul 20, 2007 10:52 am
I think RYN has blue taxiway markings adjacent to the standard yellow, to guide pilots to the transient parking and restaurant - hence it is known by some as the 'blueberry pancake' line!
Fri Jul 20, 2007 4:28 pm
Quoting Mhodgson (Reply 16):
Whats this.
regds
MEL
IAHFLYR
Fri Jul 20, 2007 8:44 pm
If that picture was in Houston this summer that green would be MOLD......  raincloud   rotfl
Users browsing this forum: Dt91c, gloom, Google Adsense [Bot], LAX772LR and 17 guests
