8b775zq
767 Variants
Tue Jul 24, 2007 1:33 pm
What are the different variants of the B767. Also what are the different ranges for each variant.
Acey
RE: 767 Variants
Tue Jul 24, 2007 3:31 pm
767-200 - 5,200 nm (9,400 km) transatlantic
767-200ER - 6,590 nm(12,200 km)transpacific
767-300 - 5,230 nm (9,700 km) transatlantic
767-300ER - 5,975 nm (11,065 km) transpacific
767-300F - 3,255 nm (6,025 km) transcontinental
767-400ER - 5,625 nm (10,415 km)transpacific
http://en.wikipedia.org/wiki/Boeing_767
If a man hasn't discovered something that he will die for, he isn't fit to live. -- Martin Luther King, Jr.
8b775zq
RE: 767 Variants
Tue Jul 24, 2007 9:03 pm
How is it that the 767-200ER manages to have more range than the 763, 763ER and 764? Is it that these planes are much heavier than the 762ER?
XT6Wagon
RE: 767 Variants
Tue Jul 24, 2007 9:07 pm
http://www.boeing.com/commercial/airports/plan_manuals.html
only place you need to go for info. Be aware that many of the documents have english -> metric conversion errors in some places, so either just use the english numbers or double check the conversion before using. All boeing planes are done in english units so assume those are correct.
Tristarsteve
RE: 767 Variants
Tue Jul 24, 2007 9:14 pm
Quoting 8B775ZQ (Reply 2):
Same fuel tanks, smaller (lighter) plane
RE: 767 Variants
Tue Jul 24, 2007 9:16 pm
Yes. The same wing mounted on a heavier airframe tends to give shorter range. The raked wingtips on the 764 compensate but not all the way
If you look at most aircraft, the stretches tend to have shorter range, all other things being equal. However, a stretch has more room for ventral fuel tanks.
Acey
RE: 767 Variants
Wed Jul 25, 2007 12:35 am
It seems to me, though, that 763ER's are used on longer stage lengths than the 762ER. AC has both of the type, but the 762ER mostly flies within the domestic system. Their longest routes (the nearly 4,900 nm YVR-PVG and the 5,000+ nm YYZ-TLV) are operated by 763ER.
RE: 767 Variants
Wed Jul 25, 2007 2:55 am
Quoting Acey (Reply 6):
Sure, but this is more of an operator thing. They may need the 300 for capacity and the ER version for range. Even at 5000nm you are not close to max range for the 763ER.
It's not always a perfect fit.
flynavy
RE: 767 Variants
Sun Jul 29, 2007 12:27 am
For one, the 767-200s generally are older (minus the case of CO). DL, for example, used to fly the 767-200 but it was a non-ER version. TWA and American used to fly their 762ERs transatlantic (AA even subs-in a 762ER on occasion). CO doesn't have any 767-300ERs to fly their translant and transpacific flights, so its divided up between the -200ER and -400ER. LOT and Malev fly their 762ERs transpacific pretty regularly, as does US Airways, Aeromexico, Air Canada, Maxjet, Silverjet, and others.
Photo © Jeamourra Franck
Photo © Philippe Noret - AirTeamimages
Change is: one airline, six continents!
SKY1
RE: 767 Variants
Mon Aug 13, 2007 12:39 pm
Quoting Starlionblue (Reply 5):
Is it exactly the same wing mounted for both, 767-200 and 767-300?
Time flies! Enjoy life!
tdscanuck
RE: 767 Variants
Mon Aug 13, 2007 7:10 pm
Quoting SKY1 (Reply 9):
It may have some heavier gauge structural members in places to handle the increased weight, but the design and mold lines should be identical.
Tom.
RE: 767 Variants
Mon Aug 13, 2007 10:48 pm
As Tdscanuck says, it is the same airfoil wise, but may be heavier. The 764 has the same wing + the raked wingtips.
The same wing thing within a type is pretty normal. Some exceptions would be the 321 (double slotted flaps instead of single slotted) and the ERJ (winglets on the XR). Still, basically the same wing.
Wings are expensive to design and manufacturers want to get maximum mileage out of them.
Viscount724
RE: 767 Variants
Tue Aug 14, 2007 9:54 am
Quoting Flynavy (Reply 8):
I believe AC has only used the 763ER on transpacific routes, not the 762ER.
BreninTW
RE: 767 Variants
Tue Aug 14, 2007 10:22 am
TransPacific or transAtlantic? I didn't think that US Airways has any destinations in Asia (but could easily be mistaken).
Users browsing this forum: 69bug, citrusrsw, Google Adsense [Bot], SQfan1 and 3 guests
