1337Delta764
MD-90 - Less Range Than The MD-83?
Sat Jul 28, 2007 12:03 am
On Wikipedia, I found something that might seem quite odd: the MD-90 has less range than the MD-83. It states that the MD-83 has a range of 4,600 km, while it states that the MD-90 has a range of 3,860 km. The MD-90-30ER still comes short of the MD-83, with a range of 4,426 km.
Why would McDonnel Douglas give the MD-90 less range than the MD-83? Yes, I know that the MD-90's lack of range was a reason for its failure, but at least it should have been given more range than the MD-83. The MD-90 is only superior to the MD-83 in more powerful and fuel efficient engines, allowing for better hot-and-high performance. But it seems strange that it would feature less range than its predecessor. The A320 and 737-800 offer more range than all MD-80 and MD-90 variants.
A342
RE: MD-90 - Less Range Than The MD-83?
Sat Jul 28, 2007 1:35 am
Here's the payload-range chart:
MD-80 series aircraft:
http://www.boeing.com/commercial/airports/acaps/md80sec3.pdf
MD-90:
http://www.boeing.com/commercial/airports/acaps/md90sec3.pdf
So yes, the MD-83 has more range.
Exceptions confirm the rule.
rfields5421
Sat Jul 28, 2007 1:40 am
Quoting 1337Delta764 (Thread starter):
Because they are aimed at different customers and different type flights ?
Because the MD90 carries more weight on the same basic engines and fuel load?
There are many, many reasons why the model 90 would be different than the model 8x series - and range is only one of the possible considerations.
1337Delta764
Sat Jul 28, 2007 1:54 am
Quoting RFields5421 (Reply 2):
Well, each generation of the Boeing 737 got their range increased. The 737-100 and 737-200 were designed for short-haul routes. The 737 Classics have more range than the original models, and 737NGs have transcontinental range.
The point is, the MD-90 was designed to be a successor to the MD-80 series, and should theoretically have more range than its predecesor. While the MD-90 features more range than the MD-81, MD-82, and MD-88, it has less than the MD-83.
rfields5421
Sat Jul 28, 2007 2:07 am
Quoting 1337Delta764 (Reply 3):
Was the 83 configured for extra range for some reason?
DL_Mech
Sat Jul 28, 2007 4:20 am
The MD-83 has fuel tanks in the cargo compartment for extra range.
This plane is built to withstand anything... except a bad pilot.
1337Delta764
Sat Jul 28, 2007 4:43 am
Strangely, the MD-90 was originally supposed to be Delta's 727 replacement. The MD-90 actually features less range than the 727-200s that they were supposed to replace. The 727-200 has a range of 4450 km, while the MD-90 (non-ER) is 3860 km. Why would the MD-90 be a good 727 replacement? Delta soon cancelled their remaining MD-90 orders for the 737-800. The 737-800 has a range of 5665 km, making it useful on transcontinental routes.
AA737-823
Sat Jul 28, 2007 9:04 am
You're not comparing apples to apples.
The MD-83 was the long-range bird in the -8X fleet, with more tanks.
The MD-90-30 was not a long range bird. The -ER, which I believe never made it into production, was the long range bird.
So let's compare that way... 4600 versus 4426.
That's a very close range. 174 miles difference.
When you were looking at all that stuff, did you notice that the MD-90 is a longer, larger aircraft? With far heavier engines?
As far as why the MD-90 would make a good 72S replacement for DL, you're forgetting that very few of the flights these birds fly are at max range. Especially at that time, when DL was doing DFW-MCO runs with MD-11s and L-1011s... just as an example.
So yeah, the MD-90 would have been a good replacement for Delta's 727 fleet had things worked out properly.
The biggest shortcoming in the arcraft was its wing, in my opinion. If Douglas had upped the budget to put a better wing on it, they might have increased range, reduced parasite drag, helped out the lackluster climb and cruise performance, etc.
pr1268
Sat Jul 28, 2007 9:37 am
Quoting AA737-823 (Reply 7):
Actually, it's 108 (statue) miles difference - the 4600 and 4426 were kilometer values. But, yes, it's an almost-negligible difference.
The only time an aircraft has too much fuel is when it is on fire.
dl757md
Sat Jul 28, 2007 2:20 pm
Wrong, completely different engines and less fuel on the 90.
TrijetsRMissed
Thu Aug 02, 2007 3:05 pm
Why would McDonnell Douglas give the MD-90 less range than the MD-83?
Good question. While the MD-90 is a more advanced aircraft, the -30 was not a direct replacement of the MD-83. The MD-90-30 was intended to take the place of the MD-82. The -30ER, the MD-88. The MD-90-50 was the long range version that would take the place of the MD-83, although that ended with the merger. This explains why TW was receiving new build MD-83's four years after the MD-90-30 was in production.
The -30ER was produced in limited numbers.
Quoting 1337Delta764 (Reply 6):
Most DL 727's did not fly routes longer than three or four hours. The MD-90-30's were intended to replace 727's on shorter distance routes. After the first 50 were to be delivered, DL planned to exercise a portion of the 115 options, many of which would be the MD-90-50 series (assuming MDC was still in business). The MD-90-50 would have a range of 5600 km, allowing for transcons and very comparable to the 738.
Quoting Dl_mech (Reply 5):
And higher performing JT8D's.
The biggest shortcoming in the aircraft was its wing, in my opinion. If Douglas had upped the budget to put a better wing on it, they might have increased range, reduced parasite drag, helped out the lackluster climb and cruise performance, etc.
 checkmark  You pretty much hit the nail on the head. In addition, the electrical system should not have been revised, this was the major reason for the DL cancellation as it was an mx nightmare. Furthermore, MD should have implemented the MD-95 FBW system in the MD-90.
There's nothing quite like a trijet.
MD-90
Sat Aug 04, 2007 9:15 am
No room for extra fuel in the wings or fuselage without reducing cargo space.
Not without a new, larger wing (like the 737NG's got).
Users browsing this forum: radarvector, SJL and 1 guest
