ultrapig
777 Parked At Gate-Engines On Idle
Fri Aug 03, 2007 3:56 am
I was at Logan yesterday-taking an AA MD-80 from B-33. I was there about 1.5 hours before departure time. Next door at Gate B-32 is a T7 which I assumed was eventually going to LHR. I noted that both of the engines were going at about 30 rpm-and continued to do so until I enplanned next door.
Help me-I assume the engines were running to generate electricity to run the airconditioning-but isn't this normally done using ground based service? It was hot-would the grounded service not be sufficient to cool the plane? But would two engines be needed and if my guess is correct why cool the plane at 3:30 for a 7 pm flight?
Even at idle these engines must use a significant amount and chalk up several hours operating time.
I'm sure one of you will tell me what I am missing.
graphic
RE: 777 Parked At Gate-Engines On Idle
Fri Aug 03, 2007 3:58 am
30 RPM is effectively 1 rotation every 2 seconds, the rotors were probably just windmilling, as even at idle power, the fans would appear to be a blur.
Demand Media fails at life
FriendlySkies
Just for clarification...did you hear them or just see the fans blowing? A gas turbine cannot operate at 30 rpm.
ultrapig
Fri Aug 03, 2007 4:08 am
At first I assumed they were spinning down after engine shut off. But they kept spinning at 30 rpm (I timed them using the "squiggles".) It did not occur to me that the wind was spining them- in fact I don't think there was much wind-You gentlemen may know better but I thought it would take a pretty strong win to spin a turbine and the spinning seemed pretty consistent.
unattendedbag
Fri Aug 03, 2007 4:14 am
Quoting Ultrapig (Reply 3):
It takes a good 10-15 knot wind to spin the blades. They are heavy, but they are also free spinning and those fans can easily catch air if the wind is blowing in the right direction. At engine idle, you would never had been able to count the revolutions per minute.
Slower traffic, keep right
flyf15
Fri Aug 03, 2007 4:16 am
Turbofans have extremely good lubrication and bearings. It doesn't take much at all to spin them and this happens fairly commonly.
Yesterday I was at an airport that had winds gusting to 30kts and we were parked directly into the wind. Those fans were spinning very fast just windmilling.... it was showing almost 3% N1!
unattendedbag
I am not familiar with that measuring method.
ultrapig
Fri Aug 03, 2007 4:25 am
Quoting UnattendedBag (Reply 6):
It was invented by me yesterday-Counting the number of turns of the squiggles marking on the engine hub per minute.
I'm still confused-I'm not doubting anyoen that the wind can spin the turbines but the wind was pretty slow yesterday.
EMBQA
Fri Aug 03, 2007 4:33 am
Quoting Ultrapig (Reply 7):
I'm still confused
Just shut your window fan off and watch the blades... they'll start spinning for the reason. It's just the wind passing through the fan case. Very-very-very-very common.....
The blades are also very efficient... I hand spun a CF34-10E once and I could fell the air around me getting sucked in. It doesn't take much to start the blades moving.
[Edited 2007-08-02 21:36:12]
darkblue
Fri Aug 03, 2007 4:50 am
It doesn't take much. I assume it was an AA 777, which means it had Trent800 engines. The 110in diameter fan (66sqft) does a good job of catching any bit wind there is. On top of that, fan blades may be designed to compress the air, but when the fan is unpowered, they make really good wind turbines.
Just for comparison, a Trent800 at idle would have fan speed around 500rpm and would make significant noise.
ultrapig
Fri Aug 03, 2007 5:20 am
OK all I think I've got the answer! Thanks
Fri Aug 03, 2007 6:05 pm
Interesting term.
Quoting UnattendedBag (Reply 4):
Depends on the direction of the wind too.
regds
MEL
boeing767mech
Wed Aug 08, 2007 4:01 am
Quoting Ultrapig (Thread starter):
Gate 32 is at the end of the terminal so you get the wind blowing around causing a high pressure area next to the jetbridge. I has seen B32 almost ripped off the side of the building in a snow storm because of the way the wind blows around the building
David
Never under-estimate the predictably of stupidty
sv2008
Wed Aug 08, 2007 6:15 am
This (random guess) might be caused by the mass of the blades which smooths out the irregularity of the wind speed (a sort of flywheel affect). For example a car engine is smooth(ish) because it has a flywheel at one end of the crankshaft despite distinct, large irregular forces caused by the combustion process/timing.
Quoting Flyf15 (Reply 5):
But are they lubricated without the engine running? Most machines have engine driven oil pumps don't they? I have no idea about this just wondered.........
tdscanuck
Wed Aug 08, 2007 6:28 am
Quoting Sv2008 (Reply 13):
Sort of. Most jets run the lube pump off of the accessory gearbox, which is hard-connected to the inner spool (or one of the inner spools in the case of a RR engine). So, if the inner spool turns (for any reason) the lube pump turns too. However, most windmilling will get the fan (outer spool) going but unless the wind is really kicking I doubt it gets the inner spool turning much at all.
So yes, they can be lubricated without the engine running but no, in the case of normal windmilling at the gate, they're not well lubricated.
Tom.
Goldenshield
Wed Aug 08, 2007 8:38 pm
Quoting HAWK21M (Reply 11):
Interesting term.
He's talking about the spiral on the engine spinner which is a visual cue to rampers when an engine is safe to approach.
Wed Aug 08, 2007 10:49 pm
Quoting Goldenshield (Reply 15):
Photo © Florian Negele
Is that an official term."Squiggles" or just a nickname.
regds
MEL
flyf15
Thu Aug 09, 2007 12:22 am
Well, there won't really be any oil pressure when the engine is not running, but there will be residual oil present that is more than adequate to lubricate the engine during windmilling.
airfoilsguy
Thu Aug 09, 2007 12:49 am
It's supposed to keep the birds out too.  duck   spin
It's not a near miss it's a near hit!!
Users browsing this forum: mmo and 1 guest
