Tiller Use On The Runway
Sat Aug 04, 2007 11:46 am
I spoke hastily in the Gen_av and got called on it. Now I need to do some hasty fast finding.  Wink
Is the tiller used after lining up for take off? Say at low speeds? Or is it only pedals?
EMBQA
RE: Tiller Use On The Runway
Sat Aug 04, 2007 11:56 am
Quoting Starlionblue (Thread starter):
The tiller is used until a specific airspeed when the rudder takes effect due to the air load over it. Every aircraft is different and if I remember from my Saab 340 days they were around 80kts
[Edited 2007-08-04 04:58:35]
Sat Aug 04, 2007 1:59 pm
Tiller is used for lineup
fr8mech
Sat Aug 04, 2007 3:53 pm
Some aircraft allow the rudder pedal steering to be deferred, thus tiller would be used on the runway.
roseflyer
Sat Aug 04, 2007 3:59 pm
It can depend on the aircraft. The tiller and rudder pedals usually can both control the nose wheel steering. However they do it very differently. The tiller on a modern jet usually allows the nose gear to rotate to about 70 degrees. The rudder pedals only allow the nose gear to rotate about 7-9 degrees. Therefore, the tiller is used for all turns, but once on the runway and straight, the rudder pedals usually are sufficient. Now this can depend on the plane, but usually steering input on the runway should be done with the pedals. The tiller can always be used as a back up, but the rudder pedals cannot back up the tiller.
wilco737
Sat Aug 04, 2007 7:39 pm
As I just posted in the BA RTO thread:
the tiller is used for line up, after that we use the rudder pedals for steering. With the pedals you steer the nose wheel as well, you not only use the rudder. The nose gear turns 7° (IIRC) to the left or right using ONLY the pedals. When airspeed is high enough (80knots) the rudder is affected as well. And those 2 are more than enough to keep the aircraft on the runway during take off run and as well during engine failure during RTO or after V1 to lift off and climb out!
Well, at least it works for 737s and MD11s I am flying... (and not in FS, in real and I always stayed on the runway just using the rudder pedals)
WILCO737 (MD11F)
P.S.: and in 2 hours I will be sitting in my MD11F again, and ONLY using rudder pedals for the take off run...
[Edited 2007-08-04 12:42:38]
PhilSquares
Sat Aug 04, 2007 8:01 pm
Generally speaking in commercial aircraft, such as the 747, A320, 777 it's a big NO NO to use the tiller at all during the takeoff run. There is sufficient nosewheel authority through the pedals to control the aircraft prior to 80 knots or so. Beyond that speed the rudder is effective and you don't even think about touching the tiller!
Fly fast, live slow
Sun Aug 05, 2007 2:32 am
If the Rudder is Ineffective.The Tiller is used until the Aircraft Speed Increases on the T/O roll.
regds
MEL
Sun Aug 05, 2007 2:34 am
If the Rudder is Ineffective due slow speed.The Tiller is used until the Aircraft Speed Increases on the T/O roll.
regds
MEL
CosmicCruiser
Sun Aug 05, 2007 3:34 am
Quoting HAWK21M (Reply 7):
regds
Quoting HAWK21M (Reply 8):
regds
As PhilSquares said..It's a big NO NO (at least in the jets I've flown both small and large) to use the tiller on the t/o roll or ldg roll for that matter. The rudder pedals have some nose wheel steering as well as rudder control. I've never NEVER seen a t/o that required use of tiller up to and including max allowable x-winds.
Quoting Fr8Mech (Reply 3):
hey FR8mech can you tell me a jet that can do this? just curious.
fr8mech
Sun Aug 05, 2007 4:00 am
Quoting CosmicCruiser (Reply 9):
I won't be near an MEL until Wednesday morning. I'll look at it then. Maybe sooner if I can find my MyBoeingFleet login information.
Sun Aug 05, 2007 4:54 am
What would you do if you are not aligned straight & the rudder is ineffective.Would you not use the tiller.
Rudder steering cannot be defferable.What Aircraft are you talking about.
regds
MEL
Sun Aug 05, 2007 5:09 am
Thanks to all!
fr8mech
Sun Aug 05, 2007 6:51 am
Quoting HAWK21M (Reply 11):
Mel, you're talking in absolutes again.
According to the MMEL at MBF:
-B727...Rudder Pedal Nose Wheel Steering. Category C. 1 installed, 0 required. Pilot in the left seat must make take-offs and landings and no other system is affected.
-B737 -Same restrictions
-B747 -Same restrictions except the pilot restriction.
-B747-400 -Same as classic + weather minimums do not require its use.
-B757 - Same as above
-B767 - Same as above
This list is not exhaustive. I'm tired of looking it up. It appears Boeing allows NWS to be deferred on most of its aircraft.
Of course, this is the MMEL. Each operator is free to make their MEL more restrictive.
Jetlagged
Sun Aug 05, 2007 9:20 am
Some 747-200s did not have pedal steering, so required tiller during takeoff. Certainly BA aircraft were like this.
9VSIO
Sun Aug 05, 2007 9:48 am
Just a quick question, when you move the tiller, does the rudder move as well? Or is that only linked to the pedals?
Me: (Lining up on final) I shall now select an aiming point. || Instructor: Well, I hope it's the runway...
Jetlagged
Sun Aug 05, 2007 9:56 am
The tiller does not move the rudder. The pedals are geared to the tiller so that pedal movement moves the tiller, and thus the nosewheel. On Airbus aircraft it's done by a computer, not mechanical linkage.
CosmicCruiser
Sun Aug 05, 2007 12:29 pm
I've never been off more than a few degrees and really so what. When you add t/o power you push on the appropriate rudder and t/o.
Quoting Fr8Mech (Reply 13):
Yes, you are correct...In my 9 yrs in the 727 I never saw it. Also I just referenced our 727 MEL and there is a BIG hit on x-wind and clutter for for dispatch w/o rudder steering. It's not a player. Thanks Fr8Mech for your reference.
sanjet
Sun Aug 05, 2007 12:37 pm
On the twin otter (DHC-6), we will use the tiller to stay aligned with the runway on take off / landing during high crosswind (30-40 kts) as rudder pedals have no direct control on nosewheel at low speeds. Ofcourse, above a certain airspeed, the rudder will be effective enough at which point the tiller is no longer used.
Will Fly For Food!
Sun Aug 05, 2007 6:56 pm
Any MELs incorporating this.
I'll def check this out,as Im surprised.
Quoting CosmicCruiser (Reply 17):
We are not talking of someone thats a few degrees off the cente,but someone much worse.
regds
MEL
CosmicCruiser
Sun Aug 05, 2007 10:22 pm
Quoting HAWK21M (Reply 19):
regds
Hey HAWK21, I can't imagine why that would happen. If you can't taxi onto the runway and line up within a few degrees you really screwed up TAXI 101. LOL
Bellerophon
Mon Aug 06, 2007 1:03 pm
CosmicCruiser
...As PhilSquares said..It's a big NO NO (at least in the jets I've flown both small and large) to use the tiller on the t/o roll or ldg roll for that matter...
I would agree, where rudder pedal nose wheel steering was fitted, but not all large aircraft were delivered with it fitted, necessitating the use of the tiller on the initial take-off roll, sometimes up to 80 kts.
...I've never NEVER seen a t/o that required use of tiller up to and including max allowable x-winds...
None of BA's B747-100 or B747-200 aircraft ever had rudder pedal nose wheel steering fitted, so all of those take-offs, over twenty years or so, required the use of the tiller, to some degree, in the early part of the take-off roll!
Why they didn't have it fitted, I do not know, because it is a useful feature.
Bellerophon
Mon Aug 06, 2007 5:09 pm
Quoting CosmicCruiser (Reply 20):
We have to cater to the worst senario possible.Thats how Flight safety works.right  Smile
regds
MEL
boeingfixer
Mon Aug 06, 2007 7:16 pm
Quoting HAWK21M (Reply 22):
I agree with that coment.
regds
MEL
Our 727 MEL States that the Rudder Pedal Nose Wheel Steering can be INOP for 10 days. It stresses caution when using the tiller duriing the takeoff roll as over controlling can easily happen.
BTW, Flight Safety is there to do things right the first time... not to salvage a poor take-off line-up or other scenario like that. Taking Flight Safety into account, one would re-allign for takeoff instead.
John
Cheers, John YYC
Users browsing this forum: bpatus297, Flow2706 and 10 guests
