A346Dude
Small Turbine Aircraft (ie C152/C172)
Sun Aug 05, 2007 12:43 pm
I was reading about the Turbine 206 which got me wondering if there are any smaller airplanes with turbine engines.
Has anyone ever modified one of the smaller Cessna singles? If not, are piston engines inherently more efficient below a certain size, and if so, why is that?
You know the gear is up and locked when it takes full throttle to taxi to the terminal.
2H4
RE: Small Turbine Aircraft (ie C152/C172)
Mon Aug 06, 2007 1:30 am
Quoting A346Dude (Thread starter):
The closest thing I've ever seen is a turbine Luscombe:
The operating efficiency of, say, an O-200 or O-235 is probably superior to even the smaller turbine engines, but I think the real obstacle for turbine engines is the overhaul/replacement costs.
2H4
Intentionally Left Blank
cancidas
Mon Aug 06, 2007 2:14 am
"...cannot the kingdom of salvation take me home."
TripleDelta
Screener
Mon Aug 06, 2007 2:23 am
Quoting 2H4 (Reply 2):
Wouldn't a turbine be a power-overkill on a light single? As far as I know, and have been looking at this field with some interest, the lowest-powered feasible turbine is in the 300 HP range. That would be way to much for a Cessna 150 or 172, despite the higher empty weight and additional fuel tankage needed...
"Well, none of it makes any sense. You just have to send in the right number of forms" - Radar, MASH 4077
2H4
Mon Aug 06, 2007 2:32 am
Quoting TripleDelta (Reply 4):
The turbine Luscombe uses a 150 hp APEX T62-32...
Nonsense! As the saying goes, the only time an airplane is overpowered is when you can accelerate while pointed straight up at idle.  biggrin
2H4
Mir
Mon Aug 06, 2007 2:55 am
Quoting 2H4 (Reply 5):
I still wouldn't consider that overpowered.  biggrin
-Mir
2H4
Mon Aug 06, 2007 3:03 am
Quoting Mir (Reply 6):
Ok, perhaps we should amend the definition of "overpowered", at least for single-engine aircraft:
An aircraft is overpowered when, upon advancing the throttle 1mm, the resulting torque overcomes all aileron authority and continuously snap-rolls the aircraft until the throttle is returned to idle.
2H4
tdscanuck
Mon Aug 06, 2007 3:56 am
I know there are Seawind 3000's running around with turboprops.
Efficiency for both Otto (piston) and Brayton (turbine) cycles scales with the compression ratio/pressure ratio. Getting good compression isn't too hard on a piston, you just have to watch out for knock. Getting good compression on a small turbine is hard because it scales with blade speed and, with small turbines, you need enourmous RPM for that. A piston is also much cheaper to purchase, operate, and overhaul for small sizes.
At the extreme other end of the scale, turbines and extremely large two-cycle diesels are about on par for efficiency.
Tom.
TripleDelta
Screener
Mon Aug 06, 2007 5:03 am
Interesting, didn't know that turbines of that power existed... well then, one of these would certainly be welcome in the Skyhawk... especially during summer, taking off from a 1800 ft-elevation strip in +30 C with full fuel and two pax and forest-fire smoke drifting around Big grin. We had to climb at a whopping 200 fpm to avoid overheating the engine...
Is the APEXs fuel consumption significantly higher than that of a standard piston engine in that power range?
Fly2HMO
Mon Aug 06, 2007 7:43 am
Supposedly a turbine C152 landed at PRC once, but I never saw it. Word of mouth form the flightline.
A346Dude
Mon Aug 06, 2007 2:23 pm
Quoting Cancidas (Reply 3):
there is the turbine toucan:
http://www.airshowbuzz.com/videos/vi...c9175
Now THAT is a cool airplane. Apparently the power to weight ratio is greater than 1.0 so it can hover like a helicopter!
Quoting Corey07850 (Reply 1):
http://www.tradewind-bonanza.com/bonanza/main.html
Another ridiculously powerful aircraft. Interesting quote that a turbine is around 100 times more reliable than a piston engine.
n710ps
Mon Aug 06, 2007 2:47 pm
I have been up close with a turbine Bonanza that was being flown as an Air Ambulance. Quite an intresting airplane. This was about two years ago.
There is plenty of room for Gods animals, right next to the mashed potatoes!
cobra27
Mon Aug 06, 2007 7:16 pm
Quoting A346Dude (Reply 11):
Actually hellicopter have power to weight ratio way lower than 1 (around 0.25). Only fighter or rockets have power to wieght more than 1
Mon Aug 06, 2007 11:06 pm
Quoting FLY2HMO (Reply 10):
What powerplant.
regds
MEL
2H4
Tue Aug 07, 2007 12:02 am
Quoting TripleDelta (Reply 9):
I've heard 16 gph for the Luscombe.
There's video of a turbine Super Cub here.
2H4
airfoilsguy
Tue Aug 07, 2007 1:52 am
http://www.skymasterjet.com/image3/fl03.jpg
It's not a near miss it's a near hit!!
timz
Tue Aug 07, 2007 7:40 am
Offhand I think it was the 1960s that somebody put a ... 40 hp? Rover? turbine in a Currie Wot. 60000 RPM sticks in my mind.
atct
Tue Aug 07, 2007 10:40 am
Comp Air Turbines I believe make a kit thats 4 seats. A great aircraft.
ATCT
Trikes are for kids!
Dougloid
Wed Aug 08, 2007 11:40 pm
I used to work on a Garrett powered Pilatus Turbo Porter for Clay Lacey back in the day....it could damn near take off vertically.
TripleDelta
Screener
Thu Aug 09, 2007 2:49 am
Quoting 2H4 (Reply 15):
That's not at all much, given the boost in performance (especially T-O, climb and hot-and-high) and reliability.
Viscount724
Thu Aug 09, 2007 7:47 am
A long-lived Canadian type that's had both turbine conversions:
Photo © Jason Pineau
Photo © Lenn Bayliss
And was also factory-built as the Turbo-Beaver:
Photo © John Olafson
By the way, the DHC-2 Beaver made it's first flight 60 years ago next Thursday (August 16, 1947).
T prop
Thu Aug 09, 2007 9:49 am
Powerplant
Pratt & Whitney: PT6A-25C
Horsepower: 750
Empty weight: 1600 lbs
Brake release to 3000 meters in 1 minute 9 seconds  Wow!
http://www.waynehandley.com/archive.html
mark5388916
Thu Aug 09, 2007 1:15 pm
Quoting T prop (Reply 22):
OMG wow thats some serious stuff, look at the other spec though:
Fuel Capacity 150 gallons / Jet-A
G Limits 12 positive / 12 negative
Take-off Distance 200 feet @ performance weight
Landing Distance 800 feet (using reverse thrust)
Max Climb 10,000 fpm @ 120 KIAS
Cruise Climb 4,500 fpm @ 215 KIAS
Service Ceiling 30,000+ feet
Fuel Consumption 45 gph @ cruise power
Range 800 nm (VFR reserves)
Endurance 3 hours (VFR reserves)
Vne (never exceed) 300 KIAS
Vs1 (stall) 65 KIAS
Vref (approach) 80 KIAS
Top Speed @ 3,000 feet 260 KIAS (300 mph)
75% Power @ 3,000 feet 230 KIAS
Sustainable Vertical Speed 60 KIAS, 5,000 fpm, straight up!
Now that seems rather impressive for a plane that size!
I Love ONT and SNA, the good So Cal Airports! URL Removed as required by mod
T prop
Thu Aug 09, 2007 5:14 pm
Quoting Mark5388916 (Reply 23):
I never got to see it fly before it crashed but a friend of mine did. He said that Handley in that machine gave one of the most amazing performances he has ever seen.
2H4
Thu Aug 09, 2007 11:35 pm
Quoting T prop (Reply 24):
I'd agree with that. Handley would point the airplane straight up, hang it on the prop, and perform his "elevator routine". By applying or reducing power, he would hover, climb, descend, hover some more, and then recover. It was indeed pretty amazing.
2H4
sv2008
Fri Aug 10, 2007 1:06 am
I think it just used to much fuel. They could probably reduce the fuel consumption now to acceptable levels, but it'd still not be near as that of a modern piston engine.
What really stops turbines being used in cars is probably emissions regulations.
Tornado82
Fri Aug 10, 2007 3:58 pm
I saw a C182 with a turbine at ABE once or twice last year. He went apesh*t on a poor refueler who drove the 100LL truck over to him. Can't say I blame him though.
A346Dude
Fri Aug 10, 2007 4:51 pm
Quoting Tornado82 (Reply 27):
I'd say it's his responsibility to supervise refueling every time with an airplane like that.
I'm sure it'd be worth the hassle though!
Tornado82
Sat Aug 11, 2007 12:18 am
Quoting A346Dude (Reply 28):
No doubt about that.
2H4
Sat Aug 11, 2007 12:20 am
Are you sure it was a 182? Turbine 210s I've seen, but never a turbine 182....
2H4
Tornado82
Sat Aug 11, 2007 12:51 am
Quoting 2H4 (Reply 30):
I talked to the guy about it for a few minutes the 2nd time I saw it, so yes I'm as sure as can be.
2H4
Sat Aug 11, 2007 12:54 am
Quoting Tornado82 (Reply 31):
Wow, I'd love to see a photo. I've scoured the internet (as well as our database), and I can't find a single example.
2H4
Viscount724
Sat Aug 11, 2007 6:57 am
Quoting 2H4 (Reply 32):
Here it is!!!
http://www.youtube.com/watch?v=E4-IQSLqic4
atct
Sat Aug 11, 2007 9:46 am
That video is of a Piston powered Cessna 182. Just listen to the beginning. (Shakes head)...
Note the Manifold Pressure gauge...I havent seen one of those on a turbine before.
ATCT
bhmbaglock
Sat Aug 11, 2007 11:18 am
Unless for example it's a turbine GlassAir.
http://www.ntsb.gov/ntsb/brief.asp?ev_id=20001213X28231&key=1
WITNESSES REPORTED THAT THE TURBOPROP HOMEBUILT LIFTED OFF THE RUNWAY AT A SLOW AIRSPEED AND HIGH PITCH ANGLE. AND Irtysh-Avia (Kazakhstan)">IT THEN ROLLED TO LEFT AND SETTLED INTO TREES. DUE TO THE SUBTANTIAL P-FACTOR AND TORQUE OF THE TURBOPROP ENGINE, TAKEOFF THRUST IS NORMALLY NOT APPLIED UNTIL SUFFICIENT AIRSPEED FOR RUDDER EFFECTIVENESS IS ATTAINED.
Quoting 2H4 (Reply 7):
Exactly!
I wouldn't swear to it, but I seem to remember one being at Sun n Fun around 89-90. IIRC, it used a turbine based on the core of the tomahawk missile engine.
Where are all of my respected members going?
kbfispotter
Sat Aug 11, 2007 1:19 pm
I have always wanted to take a straight tail 150 with a texas taildragger STC and mount a PT-6 or Walter 601 in the nose...
It would be a plane for the express purpose of having fun in, and nothing else...
According to 2H4's definition, this plane would absolutely be overpowered, and a fun ass ride!
Kris
Proud to be an A&P!!!
Users browsing this forum: RetiredWeasel, VapourTrails, Woodreau and 24 guests
