WNCrew
Changing Cabin Pressure On Purpose?
Mon Aug 13, 2007 6:30 am
I sincerely hope this isn't a stupid question but recently a passenger asked me if the pilots could alter the interior cabin pressure and I wasn't quite sure what to tell him.
He also wanted to know what our internal cabin pressure was and since we were at 30K I said around 6K, but that if we climbed up to 40K we could go as high as 8K inside the cabin. I also told him that yes the captain could alter the cabin pressure but only in the sense of "releasing it", not necessarily adding to it, that is automatic.
I wasn't able to verify my answer with the captain so did I completely lie to him? CAN the pilots in effect create a decompression? What would be the reason?
SlamClick
Mon Aug 13, 2007 7:05 am
Quoting WNCrew (Thread starter):
Depends very much on airplane type. Some jets have a limit of less than 7 PSI differential, others are well above 8 PSI.
Yes we "can" vary some values but normally we would not. We don't generally set the "pressure" per se but set the actual altitude at which we will cruise and perhaps the elevaton of our destination airport.
When we start up the air conditioning and pressurization system begins pumping air into our cabin. Some gets recirculated, some gets bled overboard by way of radio compartments (to cool the radios) some heats the bag pits, and some ultimately just gets released overboard through the outflow valve. It is this release through the outflow valve that is the means of controlling differential pressure. (difference between cabin and outside pressure)
The more automated systems (meaning last 30 years or so) will drive the outflow toward closed on takeoff roll to lock in departure ambient pressure. As the plane climbs conditioned air continues to be pumped in. Some is released as needed to prevent overpressure.
What the system aims for is a smooth cabin climb from takeoff to cruise "altitude" or internal pressure, then to maintain cruise until descent is begun. From there it will begin increasing pressure (decreasing cabin altitude) until it is more or less equal to expected arrival airport pressure. Result is that your ears get a smooth ride.
Normally at a high cruise altitude, the system will head toward maximum normal differential pressure giving the lowest possible 'cabin altitude' which is the healthiest.
So to vary it, all we could do would be to raise the cabin altitude. That would not be a good idea. We have passengers with pulmonary problems, smokers (but I repeat myself) even people with heart problems who might be adversely affected. As a matter of company policy we usually let it run itself.
CosmicCruiser
Mon Aug 13, 2007 7:38 am
On our emergency chk list for CABIN SMOKE it calls for MANUALLY raising the cabin alt to 25,000' and going on O2. This will inhibit the growth of the fire.
SlamClick
Mon Aug 13, 2007 8:57 am
Quoting CosmicCruiser (Reply 2):
Obviously not for passenger operations!  Wow!
I actually knew of a 727 crew that flew around an airport for 25 minutes trying to work their way to the end of a cockpit smoke checklist. As you know they can be pretty long and drawn out. Management pointed out to them that fires are a lot more fun to watch from the ground and don't ever do that again. Apparently they thought they had to work all the way through it before they could start on the landing preliminary checklist.
The checklist was modified to include big, BOLD words: "Land as soon as practicable and..."
Over the ocean in a freighter. No prob!
CosmicCruiser
Mon Aug 13, 2007 9:33 am
Quoting SlamClick (Reply 3):
Absolutely, In the sim in days of past they wanted to see you wander thru the chklist but thank goodness nowdays one can work on the chklist while the other does 300kts to the nearest arpt. We've seen with the few fires we've had that getting on the ground ASAP is paramount to the survivability of the crew.
Along the lines of what you're saying I had an old F/E get upset with me after the sim in debrief because on our 2-eng out app I lined up with the runway and said tell me what I've got when we land and he was pi**ed that I didn't HOLD so he could finish the 2-eng out chklist!
OB1504
Mon Aug 13, 2007 10:32 am
And for cargo operations with live animals on board (racehorses, etc).
CosmicCruiser
Mon Aug 13, 2007 10:57 am
Quoting OB1504 (Reply 5):
No, if the situation called for it the horses would not make it. You probably wouldn't have haz mat on the main deck w/ horses BUT if you did keeping the fire from growing and getting back on the ground is the most important thing.
pilotpip
Mon Aug 13, 2007 4:49 pm
The EMB-145 has two modes of operation when it comes to pressurization. Manual, and auto. Manual is a bear to operate. A knob on the controller is attached to a pneumatic line which opens and closes the pneumatic outflow valve. You have to watch the EICAS while doing this. Anytime you change power settings, climb or descend you have to adjust. It's basically a full time job. Auto is easy. We set the landing field elevation, and does everything on its own using static pressure readings from the ports in the back of the airplane, and Pitot/static 3 which has the computer that figures everything out which we call a CPAM. I'd tell you the name if I could remember, but it's 3am and my manual is in the other room. It's a very neat system. Much more simple than the kingairs and 400 series cessnas I've flown.
Also a dump button. This will raise cabin altitude to either 14,000 feet, or ambient if below 14,000. Beyond that you have to use the manual override and turn the nob to raise the pressure.
When training in the sim, we were taught there are basicalliy two events which you perform memory items, and get to the checklist when/if you can. The first is an emergency descent, which will usually allow you time to do it but you're not going to last long if you don't get the O2 on and communicating in those masks is next to impossible. The second is fire. That one is pretty self-explanitory.
DMI
Tod
RE: Changing Cabin Pressure On Purpose?
Mon Aug 13, 2007 10:48 pm
Quoting SlamClick (Reply 1):
In most cases, you also lose cabin air via the sink/floor drain system out through the drain masts.
Vacuum waste systems also lose air overboard to create the vacuum.
On 742 and 743, in addition to lav/galley vent system dumping air near the outflow valves, some of the air is extracted overboard via a valve on the side of the plane.
Tod
SlamClick
Mon Aug 13, 2007 11:54 pm
Quoting CosmicCruiser (Reply 4):
One of my last LOFT periods we ended with the Airbus fuel leak scenario. (The Transat-Azores thing)
Well the problem manifested as we were about twenty miles abeam a major airport not on our flight plan. I was PF so I had him deal with it. He gets into the problem and the first time he looks up, maybe five minutes later, was when I put the gear down. We were 4-5 mile final.
He was a little out of sorts. He wanted to know more about the problem. I wanted to be on the ground. In the real world I would want to be on the ground. It can not end well otherwise.
Afterwards he sat silently and let me be debriefed. ("Kudos for getting us on the ground quickly. Nice ride.") then he asked the instructor to talk at length about the problem. He ended up missing our flight home. They might have been there 'til midnight!
Not that I didn't want to know more about the problem. It is just that I think I had extracted the most important single lesson from it. Easier to fix on the ground.
kalvado
Tue Aug 14, 2007 11:51 am
Quoting Pilotpip (Reply 7):
For either manual mode, or in case of auto failure - is there a safety relief - I assume there should be something, but what would be the design - rapture membrane, spring-loaded valve or something else?
And yes, I remember photos of that KC-135 (?) ripped apart by pressurization..
pilotpip
Tue Aug 14, 2007 1:33 pm
Dual outflow valves. One is electopneumatic, the other is pneumatic. If the lights go out, the pneumatic valve is still operational via a totally independent system. The manual valve is a totally self-contained system.
Max differential pressure is 7.8PSI for the 145. Max differential overpressure is 8.1. We have a little margin there, also don't usually see 7.8 as we fly short legs and don't go up to FL370 very often.
DMI
Fly2HMO
Fri Aug 17, 2007 6:29 am
Quoting Kalvado (Reply 10):
KC-135 (?)
Are you talking about this? Was a C-141
Photo © Mark Baker
Thats what happens when you don't vent the tanks when fueling.
Tod
Fri Aug 17, 2007 10:54 pm
Quoting FLY2HMO (Reply 12):
KC-135 (?)
Or this KC-135
Big version: Width: 756 Height: 540 File size: 25kb
Tod
CosmicCruiser
Sat Aug 18, 2007 6:03 pm
yes there are pressure relief valves. on the MD-11 (probably the same for DC-10) they open at 8.9psid and limit pressure to 9.1psid.
UAL Bagsmasher
Sun Aug 19, 2007 9:54 am
CPAM= Cabin Pressure Acquisition Module.
The CPAM on the CRJ-200 provides the EICAS with the cabin alititude, cabin altitude rate of change, and cabin Delta P. It also causes the Fasten Seat Belts and No Smoking signs to illuminate if cabin altitude exceeds 10,000' with the switches in auto setting. The CPAM is also responsible for deploying the pax o2 masks automatically if cabin altitude exceeds 14,000'. The ERJ-145 probably has a similar setup.
