cancidas
EMB-170 Airstairs
Mon Sep 03, 2007 4:56 am
Photo © Herson Mendes
how do pax and crew gain access to this airplane? does it have the same airline non-airstair door installed or are there after-market stairs designed for that airplane? i've tried to search for something but haven't found anything as yet... kinda defeats the purpose to have an airplane that depends solely on jetbridges and ground stairs outside of the airlines.
[Edited 2007-09-02 22:00:37]
"...cannot the kingdom of salvation take me home."
roseflyer
RE: EMB-170 Airstairs
Mon Sep 03, 2007 6:11 am
I believe that Embraer may have tried to install a stair system like the one that is optional on the 737 or A320, but I'm not sure. It certainly wouldn't be in the door like it is on the ERJ145.
Viscount724
Mon Sep 03, 2007 9:10 am
Forward airstars are optional. The Embraer 170 demonstrator below is so equipped.
Photo © Mariusz Siecinski
Following photo from Embraer website. Caption reads:
An optional self-contained airstair on all models means E-Jets can operate virtually anywhere.
cancidas
Mon Sep 03, 2007 10:00 am
is the same available on the -175, -190 and -195? how does it stow/ retract? is it manual or hydraulic?
EMBQA
Mon Sep 03, 2007 10:22 am
Quoting Cancidas (Reply 3):
They're all the same plane, so yes. Electric.... but cost, weight and required space have been the big downside
roseflyer
Mon Sep 03, 2007 11:25 am
You couldn't have them be hydraulic since hydraulics only work when the pumps are energized, which means that the engines are on unless the electric motor pumps are being operated, which is unusual without the engines on.
srbmod
Tue Sep 04, 2007 8:33 am
Quoting EMBQA (Reply 4):
Which is why many airlines don't have integral airstairs. They were an optional feature on the 717 as well. These days, the number of commercial airports with regular scheduled that would require an airline to use integral airstairs are far less than say 30-40 years ago when a/c like the 727, DC-9, and 732 first came out. And those airports that still board using stairs typically have them as GSE (either airport owned/operated or airline owned/operated).
loggat
Tue Sep 04, 2007 11:30 pm
Quoting RoseFlyer (Reply 5):
Not quite. Such as in the case of the EMB-145, the stairs can be raised using stored hydraulic pressure in an accumulator. The activation solenoid is on the hot battery bus. This means you can use the stairs on a completely dark airplane.
There are 3 types of people in this world, those that can count, and those that can't.
cancidas
Wed Sep 05, 2007 3:36 am
Quoting Loggat (Reply 7):
that depends actually. there is only enough stored pressure for one or two retractions. it does mean that you can fly an airplane in, power it down and leave the door open for the caterers or cleaners to work overnight. once they're done, all it takes is pushing a button to close the door. it does take a little longer to retract than when the airplane is power-up but it servs the purpose nonetheless. IMO, great tool to simplify life...
flyboy80
Wed Sep 12, 2007 1:08 pm
Interesting, I believe the brasillia must have power to close the door...hence its usually closed manually from the ground at night.
CanadianNorth
Mon Oct 01, 2007 6:02 pm
Not really relative to the E-jet, but I myself have extended the fwd stairs on our 737-200 on a completely dark aircraft (with just pulling out the thing and holding the button).
CanadianNorth
HS-748, just like a 747 but better!
EMBQA
Mon Oct 01, 2007 7:16 pm
Quoting Flyboy80 (Reply 9):
Not true. It must still have some charge left it the hydraulic system. If not, you must close it by hand.... the ERJ is the same way
Dufo
Mon Oct 01, 2007 9:43 pm
True about the Brasilia. According to manuals, hyd. reservoir pressure is sufficient for four door cycles but it is possible to raise the door by hand. Been there done that - not that hard actually.
I seriously think I just creamed my pants without any influence from any outside variables.
Users browsing this forum: 747classic and 23 guests
