fr33fr0mlif3
P.A.S.T Critical Engine / Vmc
Wed Sep 12, 2007 5:34 am
Hello, I am posting here to get some help on figuring out how P-Factor, Accelerated Slipstream, Spiraling Slipstream, and Torque define the left engine as the critical engine in conventional twins that have both props rotating clockwise from cockpit view.
Another factor apart of Multi-Engine flying I am interested in learning about is Vmc. What defines Vmc, what causes the plane to Vmc.
I appreciate all detailed explanations and I thank you very much!
-Proud Aviation Student.
futurecaptain
RE: P.A.S.T Critical Engine / Vmc
Wed Sep 12, 2007 5:49 am
I'll start and let others add info later cause I don't have alot of time...
What defines the critical engine?
As a prop is spinning it takes a bigger "bite" out of the air on the downward stroke compared to the upward stroke. The critical engine is the one which when lost will create the most adverse effect on your performance. If you lose the left engine in a conventional twin the right prop, spinning clockwise, is on the downward stroke on the far side of the fuselage. Because it is taking the bigger bite out of the air so far away it has a greater moment and affects performance moreso. basically.  Smile
Vmc?
Minimum control velocity. The airspeed you don't want to go below when you lose an engine. Many, many things affect Vmc including but not limited to CG location, total aircraft weight, bank angle, ect, ect, ect. When you lose an engine the rudder and ailerons have to take over to control the aircraft. Vmc is where you no longer have control of the aircraft on one engine because there is not enough air moving over the surfaces to keep the plane under control. When you practice with an instructor doing Vmc you will probably be told to say something like "at the first sign of yaw, roll, or stall I will recover." If you stall, can no longer control roll, or can no longer control yaw with one engine inop you have found Vmc.
If nobody else chimes in I can go into more details later.
as739x
Wed Sep 12, 2007 6:49 am
Please move to Tech Forum
ASSFO
fr33fr0mlif3
Wed Sep 12, 2007 7:24 am
So with P-Factor, with the loss of the left engine, you gain asymmetrical thrust. The left engine was produces the thrust closer to the centerline of the aircraft and right engines produces it on the right side of the engine, from the descending blade thus causing a lot more yaw? Is that correct?
KELPkid
Wed Sep 12, 2007 8:31 am
Actually, in a propeller-powered multi, the single largest contributor to the critical engine phenomena is the corkscrew effect ("Spiraling slipstream" from your original post). The engine whose corkscrew airflow spirals into the rudder will have the greatest effect, so for traditional American aviation engines, that would be the left engine  Wink
Trivia time: name a twin-engined aircraft (and actually, it's only certain sub-variants of it  Wink ) that actually has two critical engines, and explain why that's the case  Smile
IFIXCF6
Wed Sep 12, 2007 9:21 am
My guess (and it is a guess) is the P-38, due to counter rotation on the left and right engines.
Mike
futureualpilot
Wed Sep 12, 2007 9:22 am
Quoting KELPkid (Reply 4):
Actually I think it is the loss of induced flow over the wing that causes the airplane to roll/yaw to the side of the failed engine, afaik, the slipstreams off of non-centerline powered twins doesn't contact the tail, or at least not enough to do anything.
Trivia time: name a twin-engined aircraft (and actually, it's only certain sub-variants of it ) that actually has two critical engines, and explain why that's the case
Piper Seneca. Either both, or neither engine is the critical engine. They both rotate towards the fuselage, so losing one engine over the other doesn't create any worse of a situation. I beliebe the P38 had counter rotating props, did it not?
Quoting Fr33fr0mlif3 (Reply 3):
Think of lever arms...would you rather use a short crowbar to pry open a door, or a longer one? Which one gives you greater leverage? The descending blade furthest from the centerline...so yes, you are essentially correct
I learned that there are 12 factors that affect Vmc...4 engine, 4 configuration, 2 weight and 2 pilot input...
1. Critical engine inop (greater yaw - more control input required to start - Vmc increases)
2. Prop on critical engine windmilling (unless autofeather installed) (Windmilling prop = more drag, Vmc increases)
3. Takeoff, or max available power on operating engine (Maximum power = more yaw = Vmc increases)
4. Sea level (More power at SL than at altitude = more yaw = Vmc increases)
5. Flaps in takeoff position (No change in Vmc - standardization item)
6. Cowl flaps in takeoff position (Same as above)
7. Airplane trimmed for takeoff (Same as above)
8. Gear up (Gear down adds keel effect = aircraft harder to displace sideways = Vmc decreases...gear up = Vmc incr)
9. Max sea level gross weight (More weight = more inertia = harder to displace = Vmc decrease)
10. Most unfavorable CG (usually aft) (Shorter arm to tail "crowbar" = Vmc decrease)
11. Airplane airborne and ground effect negligible (Standardization item)
12. Up to 5 degrees of bank toward good engine. (Vmc decreases in theory 3kts per degree of bank...Vmc decreases)
Life is better when you surf.
KELPkid
Wed Sep 12, 2007 9:29 am
Quoting IFIXCF6 (Reply 5):
Mike
More info needed on the why part...  Wink
Quoting FutureUALpilot (Reply 6):
That would be neither...it is correct that the Senaca (Seneca II, III or IV that is  Wink ) has no critical engine. However, the twin in question has not one, but two critical engines.
Yes it did...but once again, what was unique about the P-38 that made it have two critical engines ?  Smile
The torque of the good engine also plays a role in the tendency of the aircraft to roll...
IFIXCF6
Wed Sep 12, 2007 9:46 am
OK, I'll bite. The P-38 has 2 vertical fins and 2 rudders directly behind each engine. I'm not a pilot, and don't normally think of these types of things. Am I right?
Mike
KELPkid
Wed Sep 12, 2007 9:47 am
Quoting IFIXCF6 (Reply 8):
Mike
Nope, that's not it...it's something way more fundemental than that  Smile
Fly2HMO
Wed Sep 12, 2007 10:15 am
Quoting KELPkid (Reply 9):
Well they both rotate outward from the fuselage as opposed to inward (i.e. PA-44). So both engines have a very long moment arm.
Or did I go too deep?
[Edited 2007-09-12 03:16:45]
KELPkid
Wed Sep 12, 2007 10:29 am
Quoting FLY2HMO (Reply 10):
DINGDINGDING!!!! We have a winner, folks  yes
Even more interesting is that in the P-38, both engines (the left and the right) are actually driven the same direction, but the engine with the left hand rotating prop uses gears to turn the propeller the other way. I understand this is possible because the Allison V-1710 was actually originally intended to be an airship engine, and was designed from the outset to accomidate a gearbox so the engines could be fully reversible in flight.
rwessel
Wed Sep 12, 2007 2:23 pm
Quoting KELPkid (Reply 11):
If I'm not mistaken, the reverse rotation version of the V-1710 was actually assembled with the crankshaft reversed. There did need to be gearing changes for the supercharger, and the starter had to be installed differently.
fr33fr0mlif3
Wed Sep 12, 2007 2:49 pm
I will make a new post since this one has strayed away from helping me.
fr33fr0mlif3
Thu Sep 13, 2007 1:58 am
Can anyone help me with this?
futurecaptain
Thu Sep 13, 2007 2:01 am
Quoting Fr33fr0mlif3 (Reply 14):
See Reply 1, 4, and 6. And I will try to dig some forgotten knowledge out of my books for you tonight. If Slamclick makes it in here you should get all the knowledge and examples you need though.
fr33fr0mlif3
Thu Sep 13, 2007 5:03 am
Let me do another review.
P-Factor - Left engine is critical due to asymmetrical thrust. The left engine prop wash is closer to centerline of the aircraft, which has a greater moment, compared to the right engine producing thrust further away from the centerline of the aircraft. When left engine is loss, it most adversely affects the aircraft, thus left engine is critical.
Accelerated Slipstream - Still need help here.
Spiraling Slipstream - Left engine is deemed critical due to the fact you loose the air getting pushed against the rudder from the prop wash thus causing a great yaw. (Need more details)
Torque - For every reaction, there is an equal and opposite reaction. With both engine spinning clockwise from cockpit view, that means the torque is causing the aircraft to rotate counter-clockwise (to the left) If you loose the left engine, that me
AAR90
Thu Sep 13, 2007 3:21 pm
From my days teaching E-2 Hawkeye powerplants systems to new students (and the one thing they _always_ remembered): "you're flying a two-engine airplane; when one engine quits... THE WORKING ENGINE _IS_ THE CRITICAL ENGINE!"
Sorry... couldn't resist.  Wink
futurecaptain
Fri Sep 14, 2007 3:26 am
Quoting Fr33fr0mlif3 (Reply 16):
Read up. Google is your friend.
And I'm tired and don't want to type much.  Wink
http://www.pilotscafe.com/articles/multi-OEI.pdf
BoeingOnFinal
Fri Sep 14, 2007 3:37 am
Correction: The right hand engine produces the greatest moment.
Moment: Arm x Force
The arm is the length from the longitudinal centerline of the aircraft to the centre of thrust of the engine.
Since the aircraft is flying at an angle of attack, the down going propeller blade will have a greater angle of attack than the up going blade, thus moving the centre of thrust a little to the right of the crank shaft on right hand engines. Thus engine number two (right engine) will have a longer arm than engine number one (left engine), and a greater moment.
So, loosing the left engine will give the greatest adverse yaw, thus the left engine as previously mentioned will be the critical engine.
On some aircrafts the vertical stabilizer is set at an angle of incidence to counter produce the force created by the spiraling slipstream, usually configured to cancel out any rudder input at cruising speed. This is most significant on single engine aircrafts with the engine placed in front. I can't say for sure if this applies to twin engines, and how severe the slipstream affects the rudder angle of attack, but assuming it has some significance;
The force produced by increased angle of attack of the vertical stabilizer due to slipstream from the left engine will counter the adverse yaw created by the left engine when flying on that alone, leaving the left engine, together with the factor of lesser moment, the preferable engine to be left with during an engine failure.
If you loose the left engine, you will have a greater adverse yaw due to greater moment of the right engine and due to loss of slipstream over the vertical stabilizer. And if the vertical stabilizer is set at an angle of incidence, this will give a force which will worsen the adverse yaw even more.
Newtons 3rd law: Every action has an equal and opposite reaction. The right hand propeller will try to bank the aircraft to the left. That and due to the fact that the right wing will have more lift than the left due to the slipstream going over it, this will need to be countered.
Important aspects during engine failure:
1. Reduce adverse yaw immediately with rudder!
2. Check that failed engine props are feathered (non feathered props will increase drag dramatically, and will increase adverse yaw.
3. Do not reduce airspeed below Vmc!
You can bank the aircraft towards the live engine. This will allow for less rudder deflection. No more than 5 degrees of bank should be practiced.
norwegianpilot.blogspot.com
KELPkid
Fri Sep 14, 2007 3:58 am
Quoting BoeingOnFinal (Reply 19):
 checkmark  In fact, don't the manufacturers determine Vmc based on holding 5 degrees bank for certificaton? I seem to recall my commercial ground school instructor telling us that if you're not banking 5 deg., then the manufacturer's Vmc figures are invalid, and you're basically a test pilot at that point, and might find the aircraft's true Vmc in the configuration that you're flying it in  Wow!
Fly2HMO
Fri Sep 14, 2007 5:02 am
Quoting KELPkid (Reply 20):
Wow, I've been told that too, in the exact same wording. Interesting.  scratchchin
Users browsing this forum: BoeingGuy and 1 guest
