RussianJet
Select Parking Brake Instead Of Flaps?
Thu Sep 13, 2007 8:28 pm
Just read this about a tyre burst incident at LBA in January.
http://news.bbc.co.uk/1/hi/england/west_yorkshire/6992741.stm
Is it easy to make that mistake?
Has this happened before?
✈ Every strike of the hammer is a blow against the enemy. ✈
pilotaydin
RE: Select Parking Brake Instead Of Flaps?
Thu Sep 13, 2007 8:33 pm
hahah all levers and handles on the bus are small and similar  Wink compared to a boeing, so yeah technically you could do that, BUT, im not sure if you have to press the brakes in to set the brake on the bus. You do on the Boeing...
the article says it all, it's got nothing to do with the airplane...it says the pilot was distracted from a previous incident...case and point, flying is 100% psychology...
The only time there is too much fuel onboard, is when you're on fire!
helvknight
Thu Sep 13, 2007 8:37 pm
Quoting RussianJet (Thread starter):
According to the story there have been 5 incidents worldwide on the A320 series.
Given the number of A320 flights that's not a lot.
I refuse to join any club that would have me as a member - Groucho Marx
bennett123
Thu Sep 13, 2007 8:51 pm
http://aviation-safety.net/database/record.php?id=19930914-2
My understanding from this crash was that there was a sensor on the undercarriage strut to detect whether the plane was on the ground, linked to the Thrust Reversers. Could it not activate a caption/horn if brakes locked with no ground pressure.
Equally, is there no visual indication of flap position. My assumption is that the flap levers would have to be accessible, (and visible) to both pilots.
DeltaGuy
Thu Sep 13, 2007 8:54 pm
I'm confused, the article mentions "tyres"...what are those?  Wink
DeltaGuy
RussianJet
Thu Sep 13, 2007 9:24 pm
Quoting DeltaGuy (Reply 4):
DeltaGuy
I can sympathise, my friend. I suffer from a similar confusion whenever people start writing about 'airplanes'. What the hell are they?  Big grin
Goldenshield
Thu Sep 13, 2007 9:43 pm
Quoting RussianJet (Reply 5):
Why, to let people know what specific type of airCRAFT they are talking about, my dear Watson.
EFHK
Fri Sep 14, 2007 2:39 am
Finnair had a similar incident with an EMB-170, I think two tires burst.
One of the best places in the world: McDonald's in T2 at FRA.
SEPilot
Fri Sep 14, 2007 3:17 am
The report on the LH crash cited says that the regular brakes have sensors to prevent them from being activated until the plane is firmly on the ground, but the parking brake must bypass all of them in order for the present incident to happen.
Quoting Helvknight (Reply 2):
I would disagree; the cost of a complete set of tires is not insignificant, especially if the wheels are damaged as well, as they probably would be. Five incidents is definitely too many. It shouldn't be difficult to add a sensor into the parking brake circuit to prevent it from being applied unless the plane is at least on the ground.
VC-10
Fri Sep 14, 2007 5:07 am
Quoting Pilotaydin (Reply 1):
all levers and handles on the bus are small and similar compared to a boeing, so yeah technically you could do that, BUT, I'm not sure if you have to press the brakes in to set the brake on the bus.
To apply the park brake on a 'Bus you twist the handle at the back of the pedestal. To lower the flaps you lift the flap lever located at the fwd RHS of the pedestal and pull it back. I fail to see how the two can be confused.
The Park Brake is the emergency brake which if set in the air will remain off until the ground spoilers have deployed
RussianJet
Fri Sep 14, 2007 8:05 am
Quoting SEPilot (Reply 8):
I agree. Admittedly as a proportion of all flights it is low, but in the world of civil aviation five similar incidents such as those is definitely five too many. Which other aircraft have had this happen other than the E170 mentioned above?
Jetlagged
Fri Sep 14, 2007 8:15 am
There is touchdown protection on the parking brake, so the brakes aren't applied until touchdown. However it also bypasses the anti-skid system (as is usual), so when they are applied the effect is dramatic.
Boeings are different, in that you have to apply the toe brakes, then set the parking brake with a separate lever. The lever itself does not apply the brakes. Airbus is not alone in having a combined parking/emergency brake though, but the Airbus parking brake is ridiculously easy to set at any time. Clearly not idiot pilot proof.
I agree with VC10, there is no explicable reason for the confusion, the two controls look different, feel different and move differently.
Apparently:
Investigators believe the pilot was distracted because he had experienced a bad landing at Leeds Bradford before.
Remind me not to fly BMI to such "scary" airports.
airfoilsguy
Fri Sep 14, 2007 8:29 am
I think the whole article is screwed up. The article states that the pilot ment to select full flaps but instead set the parking break. If this was so wouldn't it be obvious to the pilot that the flaps were not set? Think about it, you are landing a plane that you assume has full flaps deployed, what is going to happen? As you approach touch down speed you will notice that your sink rate is increasing due to improper flap selection. Doesn't make sense to me.
It's not a near miss it's a near hit!!
David L
Fri Sep 14, 2007 9:00 am
Quoting Jetlagged (Reply 11):
I agree with VC10
I'm jumping on that bandwagon. The parking brake is the small black handle right at the back of the pedestal. It's turned through 90o to operate:
Parking brake on...
Photo © Borut Smrdelj
Parking brake off...
Photo © Adam Wright
The flap lever is just to the right of the lower ECAM display, in about the same place as you'll find it in most other airliners.
calpilot
Fri Sep 14, 2007 9:37 am
Quoting David L (Reply 13):
Excuse me?
David L
Fri Sep 14, 2007 10:02 am
Quoting CALPilot (Reply 14):
Excuse me?
Oh bollocks! I was reading another thread about the wheel on the gear handle and still had that lever in mind when I dug out the photos. Sorry about that.  wideeyed
Um... anyway, as VC-10 says, the parking brake is further back and operated differently.  embarrassed
onetogo
Fri Sep 14, 2007 12:42 pm
Republic did in an E170. Hopefully Embraer released some sort of software upgrade to inhibit something like that from happening again.
pics: http://www.dauntless-soft.com/PRODUCTS/Freebies/USAirParkingBrake/
RussianJet
Fri Sep 14, 2007 6:01 pm
Quoting Goldenshield (Reply 6):
Ah, you mean the difference between helicopters and AEROPLANES?  Smile
musapapaya
Fri Sep 14, 2007 6:49 pm
Quoting Onetogo (Reply 16):
Good job, thats a very short landing roll!
Lufthansa Group of Airlines
RussianJet
Fri Sep 14, 2007 7:32 pm
Quoting Musapapaya (Reply 18):
I wonder if that's what the company said to the flight crew?  Smile
Users browsing this forum: 7BOEING7, N353SK, Starlionblue and 1 guest
