B777Neuss
What Is Special With The Red Squares?
Sat Sep 15, 2007 3:02 am
So my next question,
on some aircraft I have seen red squares on top of the fuselage with the words "cut here in emergency". Is there something special under the skin, e.g. are there less stringers (what I don´t believe) or no air conditioning tubes? And whose decision is it to mark these areas?, not every airline has this squares.
KELPkid
RE: What Is Special With The Red Squares?
Sat Sep 15, 2007 3:24 am
It's a marking for ARFF (Airport Rescue & Fire Fighting) crews to know where to cut in case it is necessary to rescue individuals trapped inside the airframe. And yes, indeed, there are usually less stringers in the areas marked  Smile
EMBQA
Sat Sep 15, 2007 3:27 am
You answered your own question. It's just the easiest area to cut in case of an emergency. As for why...? I only see it on some airlines from Europe and not in the US. Maybe something to do with regulations.
rwessel
Sat Sep 15, 2007 11:28 am
On some aircraft the "cut here" lines avoid potentially dangerous items inside the aircraft. For example, aircraft with ejection seats will typically have a number of pyrotechnic devices scattered around the cockpit to do things like sever lines, blow/shatter the canopy, etc. (in addition to the seat rocket, of course). Also, things like high pressure oxygen lines are best avoided, and some aircraft have fuel lines and other nasties in that general vicinity.
Viscount724
Sat Sep 15, 2007 12:19 pm
But why do those "cut here in emergency" markings exist only on aircraft of certain airlines, even when operating the identical type? Many carriers do not have such markings on their aircraft. US or Canadian carriers don't have them to the best of my recollection and the same is true for many European carriers
I am guessing that it may be a regulatory requirement of certain governments only.
Sat Sep 15, 2007 6:38 pm
Quoting Viscount724 (Reply 4):
Any Examples.
Out here its mandatory.
regds
MEL
B777Neuss
Sun Sep 16, 2007 5:43 am
For example LH.
Photo © Oliver Brunke
Quoting HAWK21M (Reply 5):
Viscount724
Sun Sep 16, 2007 5:46 am
Any Examples.
Try and find an A.net photo of a US or Canadian-registered aircraft with the "cut here in emergency" markings. And I am almost certain that KL/LH/LX aircraft do not have them, which seems to be confirmed by a quick photo search. I think that carriers with those markings are in the minority.
I have a feeling that the requirement may date back to some historic British requirement and was adopted mainly by certain carriers that had close links to the UK or copied their regulations. Kuwait Airways, for example, has those markings on their aircraft and Kuwait was a British protectorate until 1961.
OPNLguy
Sun Sep 16, 2007 10:06 am
Quoting Rwessel (Reply 3):
Most aircraft built since the early 1980s don't have plumbed oxygen systems like the earlier aircraft did--the newer ones use chemical oxygen generators in the PSUs overhead of the seats.
I can't think of single aircraft that had fuel lines running above a passenger compartment. Check that, the Shorts 330/360 turboprops have a damn tank up there. (Never did make much sense to me--putting fuel above passengers where it could potentially leak on passengers below...)
Don't know what to attribute the different marking rules to.. I've see diagrams for the ARFF folks that tell them where the critical stuff, so they know where to look/cut, even if the markings aren't there...
2H4
Sun Sep 16, 2007 10:11 am
Quoting OPNLguy (Reply 8):
I've often wondered about Cessna's logic in placing ashtrays mere inches from fuel lines in the 172/182/etc...
2H4
Intentionally Left Blank
Sun Sep 16, 2007 1:24 pm
Quoting Viscount724 (Reply 7):
What does the F.A.R. say
regds
MEL
KELPkid
Sun Sep 16, 2007 2:16 pm
Quoting 2H4 (Reply 9):
2H4
What kind of idiot smokes in a Cessna, anyways? Good way to run up your avionics and vacuum powered gyro repair bill, not to mention destroy the interior  yuck
KELPkid
Sun Sep 16, 2007 11:51 pm
I would imagine that all high wing types are in the same boat-Dash 8's, ATR's, Doriner 327/328, BAE 146, etc.  Wink
2H4
Mon Sep 17, 2007 10:09 am
Quoting KELPkid (Reply 11):
Everyone does....even kids!
Signed,
The 1960s and 1970s.
longhauler
Mon Sep 17, 2007 10:53 pm
What therefore, is the pseudo outline in the forward left side if Air Canada's Embrarers:
Photo © Michael Durning
Photo © Mark Kryst - YXUphoto
And the rear right side:
Photo © Keith Wahamaki
It doesn't technically say "cut here" on these aircraft, but it does appear to be so.
Viscount724
Wed Sep 19, 2007 11:48 am
Quoting LongHauler (Reply 14):
That's interesting. Wonder why it's only on the Embraers? Haven't noticed anything similar on larger AC types.
