Rain Repellant - Aircraft
Sun Sep 16, 2007 1:33 pm
Apart from the Hydrophobic coating introduced.Is there any suitable non Ozone damaging repellant in use on todays Aircraft.
regds
MEL
N231YE
RE: Rain Repellant - Aircraft
Mon Sep 17, 2007 12:26 am
My only answer, sort of a "RainX" for airplanes: RVR Rain Repellant
Mon Sep 17, 2007 7:17 pm
Quoting N231YE (Reply 1):
Isn't that a type of Hydrophobic coating.
regds
MEL
N231YE
Mon Sep 17, 2007 7:21 pm
I see what you are saying...I do believe that is a hydrophobic coating.
Mon Sep 17, 2007 7:25 pm
Quoting N231YE (Reply 3):
What about Airbus Aircraft.Do they use Rain Repellant.
regds
MEL
B6JFKH81
Fri Sep 21, 2007 1:45 am
Quoting HAWK21M (Reply 4):
I know that our A320's do use it. The MFR P/N is 402Q80-1 (as per the last shipment) and we have bought it through a variety of companies. I know it is in our IPC (AIPC 30-45-42-01).
UAL Bagsmasher
Fri Sep 21, 2007 12:07 pm
I remember on our BAE 146's, we actually applied good ole fashioned Rain X to the windscreens. It was called out for right in the paperwork. I got a laugh out of that Smile
MD11Engineer
Fri Sep 21, 2007 4:50 pm
Quoting B6JFKH81 (Reply 5):
When I was working for Shannon Aerospace Ltd. we installed a new permanent rain repellent coating on the windshields during D-checks. I don't remember the brand name, but it involved thouroughly cleaning the (removed) window, masking the edges, distributing the chemicals with a squeegee and baking them in with a heat blanket.
The spray on system was at the same time inoped.
Jan
Fri Sep 21, 2007 6:57 pm
Quoting MD11Engineer (Reply 7):
Sounds like a type of Hydrophobic coating.How long did it last before needing reapplication.
regds
MEL
MD11Engineer
Fri Sep 21, 2007 10:33 pm
Quoting HAWK21M (Reply 8):
regds
MEL
I don't know. I just remember that we did on LH A320 and A321 during D-checks.
Jan
tdscanuck
Sat Sep 22, 2007 11:04 am
A guy that I worked with got some and applied it to his car windshield...lasted for years, apparently. Obviously not the same wear as on an aircraft but the stuff is clearly a lot tougher than Rain-X type coatings.
Tom.
Sat Sep 22, 2007 7:52 pm
Quoting Tdscanuck (Reply 10):
With lack of Airflow velocity of comparism to that on an Aircraft,its understandable.
Hydrophobic coatings normally last a few years depending on the sectors & hours flown.
regds
MEL
Users browsing this forum: Calder, mpj and 2 guests
