bombayhog
Bird Strikes - Need Technical Info For Story
Tue Sep 25, 2007 4:10 am
Am wondering if any pilots or aircraft maintenance people would be interested in being interviewed for a story I'm working on about bird strikes (I'm a journalism graduate student, and the story is for class but could end up being published.) I'm mostly just looking for firsthand accounts of what goes on in a bird strike and what its effect on the plane is precisely. I apologize in advance if this isn't the right forum to post this in, but I thought it might be the best choice given its technical orientation. Any help anyone can give me, even if it's just a one-line quote, would be much appreciated! You can contact me via my profile. Thanks!
Gabriel Leigh
Ralgha
RE: Bird Strikes - Need Technical Info For Story
Tue Sep 25, 2007 4:43 am
It depends on what part of the airplane it hits. Usually nothing adverse happens and you just have to have maintenance do a "bird strike" inspection at your destination.
If you're flying a turboprop and it hits one of the props, it could splatter all over the windows, thus giving the passengers something more interesting to gaze at instead of clouds.
If the bird is big enough, and/or it hits the right spot, it could do some serious damage. Possibilities include, but are not limited to:
* prop/engine damage leading to a shutdown or flameout.
* wing damage leading to control problems.
* window damage causing difficulty in seeing outside or a loss in pressurization
* nose damage causing problems with the air data sensors.
In more extreme cases it could go through a window and plant a kiss on a pilot's face, or otherwise wreak havoc inside the flight deck, injure or kill a crew member, require the other crew member to take over flying the aircraft, etc.
kstatepilot
Tue Sep 25, 2007 5:24 am
Only one I've been on flying the CJ, we just felt a little bump. During the post flight I noticed there was a rather large dent in the vertical stab. Aircraft was down for quite a while getting it fixed.
KELPkid
Tue Sep 25, 2007 6:02 am
In a Cessna 172, it sounds like a really loud "bang" when you hit a bird, I'd put the volume between a handgun being fired and a shotgun blast...  Wink The one bird I've hit hit us on the left wing just outboard of where the strut and wing come together. I'd imagine in a bigger plane, unless it hit near the cockpit area, the flight crew probably wouldn't hear anything.
The only damage was feathers stuck in an inspection panel out there on the wing, and lots of blood on the bottom of the wing. All I can say is Cessna must use really thick gauge aluminum on the leading edge, as that didn't even get dented  Smile We were on a practice instrument approach, so we weren't flying too terribly fast... (90 knots or so).
2H4
Tue Sep 25, 2007 7:09 am
I hit something once at night. I was in a 172, cruising at 6000 or 8000 feet, when a loud jolt reverberated through the airframe. It sounded and felt as though someone hit the fuselage or wing with a baseball bat.
What I remember most about the event was the uncertainty immediately afterward. Largely because it was dark outside, I wasn't sure:
  • Where the airplane was hit
  • Whether there was any damage to the airplane
  • If there was damage, how serious it was
Throughout the rest of the flight, everything appeared normal. After landing at my destination, I inspected the wing and found faint evidence of the strike on the leading edge....mainly a dull, smeared mark.
Like I said, I mainly remember the uncertainty following the strike. I didn't particularly enjoy not knowing what condition the airplane was in.
2H4
Intentionally Left Blank
N231YE
Tue Sep 25, 2007 8:45 am
I have never been in a bird strike (knock on wood)...but I have had to remove the aftermath of a BE1900 striking a flock (50+) of feathered bullets, er...European Starlings.
It should be noted that this past Friday (9/21), my University's PA-44 was slightly damaged after hitting a Crane (the ones with wings...not the ones used on buildings  wink  ) on landing. It was fixed.
rwessel
Tue Sep 25, 2007 10:33 am
A few links with information on the subject:
BIRD STRIKE COMMITTEE USA
"Bird and other wildlife strikes to aircraft annually cause over $600 million in damage to U.S. civil and military aviation. Furthermore, these strikes put the lives of aircraft crew members and their passengers at risk: over 195 people have been killed worldwide as a result of wildlife strikes since 1988."
http://www.birdstrike.org/
FAA Airport Wildlife Hazard Mitigation Home Page
Bird Strike (by Fly707 Jan 27 2007 in Tech Ops)
The following is on one of the links off the FAA web site, but is especially informative:
WILDLIFE STRIKES TO CIVIL AIRCRAFT IN THE UNITED STATES, 1990–2005
http://wildlife.pr.erau.edu/BASH90-05.pdf
A total of 64,734 bird strikes reported in the USA in that period. Resulting in at least 6380 aircraft with minor or substantial damage, and 16 aircraft destroyed. The report also discusses 1429 incidents involving "terrestrial mammals" and another 79 involving reptiles. One wonders how many of the reptile incidents involved a single flight with Samuel L. Jackson on board?  Silly
BWilliams
Tue Sep 25, 2007 12:20 pm
Quoting Ralgha (Reply 1):
This is probably the biggest concern at low altitude, even more then damage to the body of the aircraft -- damage on takeoff could result in a crash if the remaining engine(s) can't supply the thrust to climb, and on landing takes away from the thrust necessary to perform a go around in case it's needed.
If you want to know what actually happens to the engine: a bird getting injested by a jet engine would destroy the compressor and necessitate replacement of the whole engine. It's really no more dangerous then a generic engine failure, since the emergency procedure in case of engine-out is the same, pretty much. Just a tad more interesting -- more fireworks, so to speak.  Wink
This video shows a 757 sucking a bird into it's engine at MAN right at rotation:
http://youtube.com/watch?v=9KhZwsYtNDE
Regards, Brad Williams
tdscanuck
Tue Sep 25, 2007 4:03 pm
Quoting BWilliams (Reply 7):
There's a big if here...*if* it goes though the core. If it goes through the fan only, you can be fine. If it goes through the core you borescope the core and look for damage...could be fine, could be trashed.
Tom.
Tue Sep 25, 2007 4:34 pm
Captain Click once posted about hitting a bird with the windshield. Apparently it sounded like a gunshot all the way to the back of the plane.
Tue Sep 25, 2007 7:35 pm
It depends on the location,impact of the strike & the type of bird.Weather its a strike on the Airframe or Ingestion thru the Powerplant.
Mx has Bird strike Inspection schedules which point of checks to be carried out on an Aircraft post bird strike.
We had a Bird strike on a B752 radome a few months ago.Chances that such a strike would be deflected of the side of the radome,but unfortunately for the bird & aircraft struck & dented the Radome right at its nose.The radome had to be replaced.
Difficult part was it was raining heavily & the Aircraft was on the Bay,not in the Hangar  Smile
The Bird sample collection & handing over to concern authorities is also a part of the Job,so that investigations are done relating to the type of bird & the reason it was present at the Airport premises.
regds
MEL
MD11Engineer
Tue Sep 25, 2007 8:54 pm
The biggest I ever experienced was an eagle owl (Buho buho, in German Uhu) getting caught smack on the radome of a 737 at just below V1. Since we have a long runway, the pilot decided to abort the take off. For such a big bird (eagle owls are the biggest species of owls worldwide), from the outside there was surprisingly little damage, some paint cracked and the upper lightning diverter strip was partly torn off. Almost no blood as well. Only when I had the radome opened, I found that in several places the impact had cracked the composite structure out off limits in several places, requiring repair in a shop, so the plane was grounded until a new radome could be shipped to us.
The owl was picked up from the runway by a follow me driver. It had a wing span of about 1.60 meters (5.5 feet), if it would be sitting, it would have been about 60-70 centimeters tall (almost 2 feet). It still had a dead hedgehog in it's claws and looked, from the outside, undamaged, but I suspect that it suffered massive internal trauma. If it would have been still alive at this moment, I would have called a veterinarian, since it was a beautiful bird and eagle owls are also quite rare.
http://upload.wikimedia.org/wikipedia/commons/thumb/d/d2/Uhu-muc.jpg/706px-Uhu-muc.jpg
We suspect that the owl had just caught the hedgehog on or just beside the runway and was distracted by it. It suddenly noticed the plane barreling down on it, got startled and tried to take off. Now eagle owls are very quiet flyers, but not very fast. Additionally it was still carrying the weight of the hedgehog. It probably also took off in the wrong direction, straight into the plane's path.
Jan
Tue Sep 25, 2007 9:49 pm
Quoting MD11Engineer (Reply 11):
"Not so much a bird strike as an engine suck"... Or in other words it's not the poor bird's fault...
For the full text and quite hilarious text surrounding the above quote: http://www.auntiemomo.com/cakeordeath/glorioustranscript.html#flight
WrenchBender
Wed Sep 26, 2007 11:27 am
Here's a video of what happened to a BA Hawk Trainer vs Bird at CFB Moose Jaw (NATO flight tarining)
http://www.kossan.se/roliga/fagelvsflygplan/fagel_vs_flygplan.htm
WrenchBender
Silly Pilot, Tricks are for kids.......
Dougloid
Thu Sep 27, 2007 9:11 am
Not so. It depends on the bird, both size and species. The little ones get atomized but the refuse mucks up the airflow inside your engine and can lead to a significant EGT rise. I have worked on a number of TPE331s that have taken bird hits. It does require a total disassembly to clean up the muck which doesn't begin to smell bad until it gets wet.
One actually bent a blade in the first stage compressor which was quite a job as it's forged titanium. We sent the impeller back to Garrett and they cut off the damaged area, welded on new material, and reprofiled it. The only way you could tell it was damaged at any time was the metal was a little darker-but it was the same serial number.
If the bird is big and hefty enough, of course, it'll cause a lot of mess and damage. Also if the bird has a heavy bone structure like a seagull, that head is as solid as granite.
I worked at an airport which has a permanent ATIS notice for migratory waterfowl. There is a pharmaceutical plant south of the airport and they used a big pond as a heat exchanger for their antibiotic processes. The pond never froze, hunters were barred and the ducks and geese liked it fine. One customer hit a couple Canada geese one time, What a frickin mess-feet, beaks and eyeballs wrapped around the MLG struts.
Fri Oct 05, 2007 4:15 pm
Quoting Dougloid (Reply 14):
What was the message like.
regds
MEL
kbfispotter
Fri Oct 05, 2007 5:20 pm
We clean up on average a bird strike a day at QX. Two days ago we had one on a Q400 that shattered a wing leading edge panel, and left a hole big enough for my hand to fit through. This bird hit with enough force to shred the rubber deice boot on the panel. Then last night I cleaned up another one, no damage, just blood everywhere, streaked along the nose just aft of the radome, and also along the bottom on one of the engine nacelles. Most times we will be called out for a bird strike and just find a small point of blood, and nothing else. Sometimes there will be no evidence what so ever. But every once in a while, we have ones that require new leading edge panels, radomes, prop blades or whole props, or even an engine change.
Kris
Proud to be an A&P!!!
Dougloid
Sun Oct 07, 2007 3:19 pm
Quoting HAWK21M (Reply 15):
regds
MEL
It's at AZO and it says something like "Be cautious of migratory waterfowl taking off and landing across the south end of the runway."
71Zulu
Sun Oct 07, 2007 3:55 pm
These are from the FL strike at PHL last week.
Clickable links only please!
Mon Oct 08, 2007 12:33 am
Quoting Dougloid (Reply 17):
Ok.Thanks.
Quoting 71Zulu (Reply 18):
What bird.How serious was the Damage.
regds
MEL
Buzz
Mon Oct 08, 2007 10:26 am
Hi Bombayhog, Buzz here. The only bird strike of note for me was a couple years ago when a 737-300 ran into a few on final approach... in the dark of course.
Most of the time it's just a red smear on the airplane. There were 3 or 4 red smears. But a couple went into #1 engine. Nothing down the core... the first was easy to see where it hit.
The 2nd was harder to trace. It went into the bleed air pre-cooler inlet ( I wigged a borescope between the fan blades) So there's a layer of bird-burger smeared into the fins of the heat exchanger. It's hard enough to get the pre-cooler valve out, then put a mirror in the duct to examine the mess. A normal human hand / arm can't get in there.
There was some drizzle that morning, so both engine bleed air systems had to work for anti-ice protection. The airplane was delayed until the weather improved... then one flight down to SFO for a pre-cooler change.
But most of the time the birdstrikes we get aren't very exciting.
g'day
miamiair
Mon Oct 08, 2007 11:44 am
Here's a cpouple of pictures of a 767 canoe fairing:
http://i30.photobucket.com/albums/c325/miamiair/8268E.jpg
http://i30.photobucket.com/albums/c325/miamiair/8268D.jpg
http://i30.photobucket.com/albums/c325/miamiair/8268C.jpg
http://i30.photobucket.com/albums/c325/miamiair/8268B.jpg
http://i30.photobucket.com/albums/c325/miamiair/8268A.jpg
roseflyer
Mon Oct 08, 2007 5:56 pm
There's a pretty famous incident where a bird hit the nosewheel steering system of a 737 on takeoff. The bird strike didn't appear to cause any problems, so the crew continued on. When the KLM 737 landed in Barcelona, the plane veered off the runway since the bird damaged the steering cables and caused the nose gear to be stuck in place at about a 10 degree angle. The pilots were not able to use differential braking and the rudder to keep the plane on the runway. The nose ended up in a ditch and the fuselage was a writeoff. One stupid bird cost the airline millions of dollars.
Fri Oct 12, 2007 8:35 am
Quoting Buzz (Reply 20):
Thats the Advantage of High Bypass as compared to a Low bypass turbofan like JT8D. Smile The chances of core damage is more rarer.
Quoting RoseFlyer (Reply 22):
Why did the Centering cams not hold the NLG straight.The steering control will be lost after slowing down when momentum reduces.Whats confusing is what caused the 10 deg tilt.
regds
MEL
Users browsing this forum: PhantomPhan and 1 guest
