Mike89406
Question About Aircraft At Cruising Alttitude
Wed Sep 26, 2007 11:27 am
Looking at this picture below its evident the aircraft is flying somewhere over the arctic I've always wondered how cold the temperature is flying over the arctic region at say FL 400 which I presume is a good estimate of where the pictured aircraft is flying.
I guess this could be a loaded question I know that flying anywhere else over the US or EU for example it would be say -40 to maybe -60 F at cruising on average.
My point of the question is flying over the arctic would the temperature be much different than anywhere else based on surface temperature at the same cruising altitude as pictured? I presume it would be much colder flying over the North Pole but then again I'm not a weather expert.
http://www.airliners.net/open.file?i...4%2FRE&Wm=0&WdsYXMg=Pbagvaragny%20
Nveyvarf&QtODMg=Va%20Syvtug&ERDLTkt=Vagreangvbany%20Nvefcnpr&ktODMp=Znl%201%2C%202005&BP=0&WNEb25u=Zvpunry%20Znagbhqvf&xsIERvdWdsY=A77006&MgTUQtODMgKE=RJE-UXT.%20PB%20Syvtug%2099.%20Guvf%20syvtug%20gbbx%20hf%20qverpgyl%20bire%20gur%20trbtencuvpny%20abegu%20cbyr.%20Ba%20guvf%20cvpgher%20lbh%20pna%20frr%20gur%20ynfg%20ovg%20bs%20ynaq%20orsber%20jr%20ernpu%20gur%20cnpx-vpr.%20Gur%20ivrj%20jnf%20fghaavat%20jvgu%20fabj%20naq%20vpr%20nf%20sne%20nf%20bar%20pbhyq%20frr%20naq%20n%20qrrc%20oyhr%20fxl.&YXMgTUQtODMgKERD=218893&NEb25uZWxs=2005-05-17&ODJ9dvCE=&O89Dcjdg=29476%2F183&static=yes&width=1024&height=724&sok=JURER%20%20%28nvepensg_trarevp%20YVXR%20%27Obrvat%20777%25%27%29%20NAQ%20%28nveyvar%20YVXR%20%27Pbagvaragny%20Nveyvarf%25%27%29%20%20BEQRE%20OL%20cubgb_vq%20QRFP&photo_nr=2&prev_id=0945545&next_id=0532410&tbl=WINDOW_VIEW
Having asked the question above I presume the leading edge of the wing is heat treated 7076T aluminum or high strength aluminum alloy with the extremely cold temperatures up there coupled with the wind chill of the airspeed over the leading edge how does the aluminum stand up to say bird strikes or objects? Aluminum is a malleable metal until mixed with other alloys but the cold temps would make the skin of the aircraft or leading edge very brittle.
Being an Airframes Mechanic were not too inadated with scientific theory just metallurgy and hydraulic flight control systems but I always admit I have been intrigued by how the aircraft stands up to the elements.
Regards, Mike
[Edited 2007-09-26 04:36:05]
doug_or
RE: Question About Aircraft At Cruising Alttitude
Wed Sep 26, 2007 12:22 pm
Wind chill does not affect anything that does not produce heat. The friction and compression of air caused by the aircraft speed will actuly increase the temperature.
wind chill
http://en.wikipedia.org/wiki/Wind_chill
To answer your original question read:
http://en.wikipedia.org/wiki/Atmospheric_circulation
Basicaly, there are three circulation cells (equator-30 [hadley cell  warm ], 30-60 [Ferrel cell,  moderate ], and 60-pole [Polar cell  cold ])
When in doubt, one B pump off
boeingfixer
Wed Sep 26, 2007 1:46 pm
Quoting Mike89406 (Thread starter):
As Doug_Or stated above, windchill does not effect aircraft. Ram rise, which is the effect of the aircraft flying through the air, actually increases the temperature of the airframe. At M0.82, the ram rise is approximately 32 degrees C. An example is If your SAT at M0.82 cruise is -60C, your TAT will be only -28C. As for bird strikes, you don't have to worry about them at cruising altitudes and temperatures of -50C. The temperature effects the fuel more than anything on long range polar flights and is a concern if the fuel gets too close to its freezing point (-40C for Jet-A and -47C for Jet-A1).
John
Cheers, John YYC
tdscanuck
Wed Sep 26, 2007 1:54 pm
There is a significant temperature swing. Aircraft using Jet-A have to watch their fuel freeze point when doing polar routes because Jet A can cloud up during a polar flight if you're at the high end of the spec.
There aren't really any birds or FOD up at cruise altitude; that's only a climb/descent concern. Not sure what happens if you're operating out of a far arctic base though.
Tom.
Scooter01
Wed Sep 26, 2007 2:08 pm
Depends on what time of the year.....  sun
Scooter01
rwessel
Wed Sep 26, 2007 2:15 pm
Quoting Boeingfixer (Reply 2):
Well, it's not a big concern, but the highest recorded bird strike was with a Griffon Vulture over the Ivory Coast at some 37,000ft.  eyepopping
Hope the bird was using oxygen!
Mike89406
Wed Sep 26, 2007 2:18 pm
Quoting Doug_Or (Reply 1):
Ok so it heats up a little, interesting
Quoting Tdscanuck (Reply 3):
Yeah I wouldn't expect any birds or foreign objects that high was just wondering about the effect on the structure I should have used a better depiction.
[Edited 2007-09-26 07:21:13]
SEPilot
Wed Sep 26, 2007 7:59 pm
Actually, I would suspect the biggest concern might be the possibility that extreme cold might make the aluminum brittle and lead to cracks when encountering turbulence, instead of flexing. Obviously it does not get cold enough for that to happen, as we haven't had any planes breaking up during polar flight.
CosmicCruiser
Wed Sep 26, 2007 8:49 pm
I don't remember the temp being all that much colder on the last polar flight I made than any other flight. As far as fuel temp goes the closest I've gotten to being concerned was CDG-SFS in the winter. That was 12 hrs at cruise and we did have "cold fuel recirculation".
tdscanuck
Thu Sep 27, 2007 2:29 am
Quoting SEPilot (Reply 7):
Aviation aluminum alloys have very high yield points (relative to ultimate strength) and they're never supposed to go above yield during normal flight. Within the elastic range, you don't really have to worry about brittleness.
Tom.
SEPilot
Thu Sep 27, 2007 3:27 am
Quoting Tdscanuck (Reply 9):
This is true; I have heard, however, of steel parts in extreme cold breaking under comparatively light blows. It is anecdotal, and might be exaggerated.
LaminarFlow
Thu Sep 27, 2007 6:45 am
Theoretically, an aeroplane cruising at 40,000' over the North Pole could be in equally warm or warmer air than an aeroplane flying at the same altitude over the equator due to the decreased altitude of the stratosphere, throughout which the air temperature actually begins to increase with altitude as the air is heated by the absorption of UV rays by small amounts of ozone. The stratosphere can generally exist as low as 26,000' over the poles, and as high as 60,000' over the equator.
tdscanuck
Thu Sep 27, 2007 1:07 pm
Quoting SEPilot (Reply 10):
It does happen with certain alloys. Fracture toughness can be temperature dependant so, under impact, a blow that would normally cause a dent may cause a crack. Still have to go above yield for that to kick in though. Impact stress is also hardness dependent so it's worse with steel than aluminum (for the same impacting object).
Tom.
Thu Sep 27, 2007 2:24 pm
Here is an interesting article about considerations on Polar routes: http://www.boeing.com/commercial/aer...magazine/aero_16/polar_story.html. Right from the horse's mouth if you will.
Quoting CosmicCruiser (Reply 8):
JFK-HKG - 16½ hours flying time, and it grazes the pole. That's a lot of time in the cold. But I'm sure those clever dispatchers and pilots knew what they were doing. We got there in one piece in any case. Far more worrying was "handling" our 23 month old and our 5 month throughout the flight. Not quite the flight from hell but we were pretty tired when we got there.  Sad
Quoting Tdscanuck (Reply 12):
In other words, don't hit any birds at cruise. Big grin
ElpinDAB
Thu Sep 27, 2007 2:35 pm
Quoting LaminarFlow (Reply 11):
Very true. The air temperature above the planetary boundary layer (which is the part of the atmosphere directly affected by the Earth's surface, ranging from the surface to between about 1,000ft to 10,000ft) is not significantly affected by day and night heating or changes in latitude. So, often you'll see similar temperatures at 40,000 ft from the equator all the way to the pole. This is because the Earth's atmosphere is mostly heated from below, from radiation that has been absorbed by the Earth's surface and then heats the surrounding air in the planetary boundary layer. The remainder of the atmosphere at a given altitude remains at a fairly constant temperature, and even more so the higher you go. So, down around 25,000ft or so, you'll see a little more difference in temperature with changes in latitude.
To illustrate, here are three current atmospheric soundings for the same day. (altitude on the vertical axis, temp at the bottom on the horizontal axis, temperature line on the right, dewpoint on the left.)
1) Manaus, Brazil, near the equator: http://weather.uwyo.edu/cgi-bin/soun...TH=09&FROM=2700&TO=2700&STNM=82332
Temp at 12,000m (about 40,000ft): -50C
2) Denver, CO, USA, middle latitudes:
http://weather.uwyo.edu/cgi-bin/soun...TH=09&FROM=2700&TO=2700&STNM=72469
3) Barrow, AK, USA, north of arctic circle:
http://weather.uwyo.edu/cgi-bin/soun...TH=09&FROM=2700&TO=2700&STNM=70026
All are at about -50C at 40,000ft even though the surface temperatures vary greatly between the locations. On the Barrow, AK sounding, you can also plainly see the temperature inversion that occurs at the top of the troposphere, the tropopause, because of the presence of ozone that absorbs solar radiation. Interesting, this temperature inversion also prevents thunderstorms from growing to enormous heights.
Analog
Thu Sep 27, 2007 4:18 pm
I don't think that's true. Take a puddle of water. It does not produce heat, but wind [chill] definitely affects the rate at which its temperature changes.
rwessel
Thu Sep 27, 2007 5:43 pm
Quoting Analog (Reply 15):
The original statement is correct, but entirely clear.
If there's no local airflow, you have a stable boundary layer of air attached to any object, and all heat loss is convective through that layer. What wind does is blow the warmed boundary layer away and replaces it with fresh cold air. This can significantly increase the rate at which heat is sucked out of the object. So you will freeze faster as your ability to produce body heat is overwhelmed, a puddle of water will freeze faster, or an object will cool down faster.
But that only apply to an object with a temperature above the (actual) air temp. So if the air temp is -20C, a warm block of aluminum will cool to -20C more quickly than with a good breeze blowing than in calm conditions, but in both cases they'll stabilize at exactly -20C. If there is a heat source inside the aluminum block, then the no-wind stable temp will be higher than in the wind.
Analog
Thu Sep 27, 2007 9:45 pm
Quoting Rwessel (Reply 16):
But you go on to give an example that shows it is incorrect. Wind chill does affect non-heat producing objects. Perhaps not in the steady-state, but that's not really important.
If wind chill does not affect objects at the same temperature as the air, why do people sweat when the outside air is below 37 degrees? Because the wind still chills your body (evaporation). You can make ice in a hot desert using wind chill.
boeingfixer
Thu Sep 27, 2007 10:21 pm
Quoting Analog (Reply 17):
The confusion is in the terminology. Wind Chill was devised to be a measurement of how the human body feels the air temperature based on wind speed in freezing temperatures. It wasn't meant to be a term to describe the rate of temperature change due to wind speed. That is called Temperature Transference. This Temperature Transference can be used to calculate the rate of temperature change to bring an object from one temperature to the temperature of the surrounding air. Obviously if the air is moving or circulating the temp. will change faster. The OP had assumed that wind chill would make the aircraft skin colder than the outside temp. This is not physically possible.
Make ice in the desert by just blowing wind? Not likely unless there is some pretty hefty energy transfer going on. A 30 knot wind at 50C is still 50C. It may cool you off by evaporating sweat quicker but you're never going to make ice cubes without massive energy extraction and volume expansion.
John
Cheers, John YYC
Analog
Fri Sep 28, 2007 10:48 am
Quoting Boeingfixer (Reply 18):
You can cool things below ambient temperature using evaporation. Many air conditioning units (evaporative coolers) work like that.
In retrospect I think the trick of making ice in the desert works by radiation (insulated container, open to space at night).
boeingfixer
Fri Sep 28, 2007 1:48 pm
Quoting Analog (Reply 19):
Wind chill and Evaporaion cooling are two completely different things and have no correlation to each other. Lets not confuse this post more than it already is.
 Confused
John
Cheers, John YYC
Analog
Fri Sep 28, 2007 2:25 pm
Quoting Boeingfixer (Reply 20):
Please explain. Wind chill is partly due to evaporative cooling. They are highly correlated (in so much as causation is correlation).
http://www.straightdope.com/mailbag/mwindchi.html
http://www.newton.dep.anl.gov/askasci/phy99/phy99116.htm
boeingfixer
Fri Sep 28, 2007 9:35 pm
Quoting Analog (Reply 21):
Two very simple explanations there. I will however concede on that point but it is a much more complex issue than your links express and simple evaporation plays a partial role along with other factors.
BTW, you still can't freeze water in the desert just by wind chill  Wow!
Now I'll let this thread get back on track  Yeah sure
John
Cheers, John YYC
Analog
Sat Sep 29, 2007 2:25 am
Quoting Boeingfixer (Reply 22):
Antarctica is a desert.  Wink
I tried searching for the answer to this question... no luck so far. If the air is 1deg C, can one freeze water using wind? In retrospect I think that you are right about that (No).
chksix
Sat Sep 29, 2007 7:17 am
Air that flows through an expanding nozzle at high speed will cool enough to cause the bound moisture to form ice chrystals. It can happen in smoke diving air pressure regulators despite them being used in very hot zones if the main valve isn't opened fully for example.
The conveyor belt plane will fly
boeingfixer
Sat Sep 29, 2007 8:31 am
Quoting Chksix (Reply 24):
That's pretty much what I said in reply 18:
Volume expansion is exactly what you get from compressed air being released at high speed.
John
Cheers, John YYC
