jasp25
ATC Talk: What Does "with India" Mean?
Tue Sep 25, 2007 1:15 pm
Pilots sometimes append "with india" when they talk to the ATC. What does it mean?
-Jasp
-peace and chicken grease!
kcrwflyer
RE: ATC Talk: What Does "with India" Mean?
Tue Sep 25, 2007 1:20 pm
Thats the pilots telling the ATC the most recent ATIS they've heard. You'll hear " with india, juliet, kilo, zulu, bravo etc..
chris133
Tue Sep 25, 2007 1:21 pm
"With India" means that you have the current WX (metars) and airport Notams updates. The letter will change with each new revision or update so that you know if you have the most current. The next one after india would be information juliet.
The ATIS received, local WX conditions at the airport received by the pilots by listening to ATIS radio frequency or ACARS.
siromega
Tue Sep 25, 2007 1:22 pm
"with ____" (some letter of the phonetic alphabet) is a way for the pilot to indicate to ATC the most recent ATIS (automatic terminal information service) they've received. ATIS contains weather information usually, as well as any other important information.
IPFreely
Tue Sep 25, 2007 1:23 pm
Most major airports broadcast an Automated Terminal Information System (ATIS) which is a pre-recorded message that provides current weather conditions and active runway information. Pilots listen to this because it saves time and workload of having controllers repeat the same information over and over to each aircraft. The ATIS broadcast is obviously updated fairly frequently so that it stays current, and it's identified by the alphabet. If the first ATIS of the day is "a", or "alpha", when it's updated it will be "b" or "bravo", then "charlie", "delta", etc., until it rolls over back to alpha. When a pilot contacts ATC and says his callsign "with India", he's telling the controller that he's listened to the "India" ATIS broadcast, so the controller knows he's been advised of weather and any special conditions. If the controller responds "Juliette is current", it means the ATIS message has been updated since the pilot listened to it, and he should listen to the updated broadcast.
[Edited 2007-09-25 06:24:25]
KELPkid
Tue Sep 25, 2007 1:24 pm
With (insert a letter from the ICAO phonetic alphabet here) means that the aircraft checking in has received that version of the ATIS (Automated Terminal Information System) broadcast. This is to prevent approach and/or the tower from repeating tons of redundant (but important for flight safety) information to every aircraft that checks in on frequency...If, for example, an aircraft checks in with ATIS information India, and the tower has just updaed the ATIS recording to information Juliet, then the controller that the flight checks in with would be required to give that flight the information in the Juliet ATIS recording.
Normally, ATIS recordings are updated every hour, unless there are significant changes (fronts blowing through, rapidly changing weather, rapid barometric pressure changes, etc.).
Edit: D'oh! J comes after I (not K).
[Edited 2007-09-25 06:27:25]
jasp25
Tue Sep 25, 2007 1:30 pm
Ahh so basically it's just like an identifying code that "india" is the ATIS advisory the pilot listened and the ATC can advise the crew if that is the latest ATIS advisory.
Wow, you guys beat Google! I was trying to google it up too but I know I can always get help here on A.Net when it comes to aviation stuff.
Thanks for the quick responses guys!
-Jasp
Mir
It means that they have the ATIS for the airport that they're landing at. ATIS broadcasts are changed hourly (except in the case of rapidly changing weather), and each is assigned a letter of the phonetic alphabet. If a pilot calls up and gives the correct letter, ATC knows that the pilot has the most up-to-date information. If the pilot gives an out-of-date letter, ATC can tell them to get the more recent information. The letter cycles every hour, so after India would come Juliet, and then Kilo, and so on.
-Mir
n710ps
Tue Sep 25, 2007 1:32 pm
An example would be "LaGuardia ground, bluestreak **** at spot 24 ready to taxi and we have india". This is the controllers que that the pilot has the up to date conditions of the field pertenant to safe operation of the airplane. Alot of times when the information changes and you ahve already been issued a clearnce the controller will call and say to aircraft on frequenct tht new information is juliet which is the pilots que to go back over and check ATIS once more for furthur update.
There is plenty of room for Gods animals, right next to the mashed potatoes!
KELPkid
Tue Sep 25, 2007 1:45 pm
Quoting N710PS (Reply 9):
Which usually sounds something like "Attention all aircraft, information Juliet is now current..."
asuflyer05
Tue Sep 25, 2007 2:01 pm
My oh my you guys are quick.
Quoting KcrwFlyer (Reply 1):
KcrwFlyer From United States, joined May 2004, 1693 posts, RR: 4
Reply 1, posted Mon Sep 24 2007 23:20:54 your local time (35 minutes 32 secs ago) and read 162 times:
Quoting Chris133 (Reply 2):
Chris133 From United States, joined Oct 2005, 218 posts, RR: 0
Reply 2, posted Mon Sep 24 2007 23:21:12 your local time (35 minutes 14 secs ago) and read 162 times:
Quoting Zeke (Reply 3):
Zeke From Hong Kong SAR, PRC, joined Dec 2006, 1709 posts, RR: 24
Reply 3, posted Mon Sep 24 2007 23:21:48 your local time (34 minutes 38 secs ago) and read 162 times:
Quoting SirOmega (Reply 4):
SirOmega From United States, joined Sep 2005, 529 posts, RR: 0
Reply 4, posted Mon Sep 24 2007 23:22:46 your local time (33 minutes 40 secs ago) and read 152 times:
Quoting IPFreely (Reply 5):
IPFreely From United States, joined Dec 2006, 161 posts, RR: 0
Reply 5, posted Mon Sep 24 2007 23:23:53 your local time (32 minutes 33 secs ago) and read 152 times:
Quoting KELPkid (Reply 6):
KELPkid From United States, joined Nov 2005, 1993 posts, RR: 3
Reply 6, posted Mon Sep 24 2007 23:24:26 your local time (32 minutes ago) and read 140 times:
KELPkid
Tue Sep 25, 2007 2:10 pm
Quoting Asuflyer05 (Reply 11):
Hey, it was smack dab in the middle of prime time here on the West Coast and no teams I care about were on Monday Night Football  Wink
ktachiya
Tue Sep 25, 2007 3:02 pm
I know your question was with the current information but India is also a designated taxi route (Indicated by the letter I).
Just for your quick information, I'll just list it right here:
Alpha, Bravo, Charlie, Delta, Echo, Foxtrot, Golf, Hotel, India, Juliet, Kilo, Lima, Mike, November, Oscar, Papa, Quebec, Romeo, Sierra, Tango, Uniform, Victor, Whiskey, X-ray, Yankee, and Zulu.
Among these, Whiskey is my favorite.
The strange thing is, I have never heard information Whiskey before but I am sure it exists.
These codes are used in the military too I think (according to my friend in the Canadian military).
Flown on: DC-10-30, B747-200B, B747-300, B747-300SR, B747-400, B747-400D, B767-300, B777-200, B777-200ER, B777-300
cbphoto
Tue Sep 25, 2007 3:11 pm
Quoting Ktachiya (Reply 13):
Hear it all the time!! We even sometimes like to joke around with tower, and let them know we have the "booze news"
ETOPS: Engines Turning or Passengers Swimming
Kukkudrill
Tue Sep 25, 2007 3:50 pm
I have. It's great hearing "On first contact with XXXX tower, apron or approach, notify receipt of Whiskey."  Big grin
Make the most of the available light ... a lesson of photography that applies to life
cloudyapple
Tue Sep 25, 2007 4:47 pm
These are not specific to ATIS or Taxiways. These are standard phonetic alphabets on the radio. Using these instead of spelling the actual alphabets removes any confusions between B & D or anything that may sound similar on radio. This makes the transmissions clearer and reduces the need for repeating instructions.
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
BigJimFX
Tue Sep 25, 2007 5:08 pm
My favorite taxi route is here at DFW... we have a "pilots weekend" Golf Whiskey Golf. Also we have 17R KEG; Kilo, Echo Golf. Good Times!
I'd like to thank me for flying Me Airways...
comorin
Wed Sep 26, 2007 2:05 am
Was it always Zulu? I thought it used to be Zebra....Old folks please help...
doug_or
Wed Sep 26, 2007 2:31 am
Quoting Comorin (Reply 18):
there have been a number of phonetic alaphabets over the years, although everyone seems to be mostly stardardized now. Wikipedia doen't seem to have too much, but it looks like it was part of the RAF WWII phonetic alphabet:
http://en.wikipedia.org/wiki/RAF_phonetic_alphabet
When in doubt, one B pump off
9VSIO
Wed Sep 26, 2007 8:34 am
I'm surprised no one has brought that that old joke about "do you have hotel"....
Me: (Lining up on final) I shall now select an aiming point. || Instructor: Well, I hope it's the runway...
KELPkid
Wed Sep 26, 2007 8:35 am
Quoting 9VSIO (Reply 20):
Please do elaborate Big grin
comorin
Wed Sep 26, 2007 9:14 am
Quoting Doug_Or (Reply 19):
19, posted Tue Sep 25 2007 13:31:23 your local time (6 hours 39 minutes 55 secs ago) and read 340 times:
Thanks for clarifying that! I probably remember it from my 'Biggles' books...  old
71Zulu
Wed Sep 26, 2007 10:12 am
If you want to hear the live ATIS broadcast at Boston Logan, put this URL into your Winamp audio player
http://alt.liveatc.net/kbos_atis
Clickable links only please!
iaddca
Wed Sep 26, 2007 12:47 pm
Quoting Jasp25 (Reply 7):
don't encourage them too much, or this friday night they'll probably have some kind of ATIS alphabet spelling bee
iaddca
Wed Sep 26, 2007 12:51 pm
Quoting Jasp25 (Thread starter):
it means we're not answering in an hour, because we'll be "with juliet"
Acey
Wed Sep 26, 2007 12:52 pm
...not sure if it is still in action, but if one came at the correct time they could check in with Boston approach by saying, "at DRUNK with Whiskey"...
If a man hasn't discovered something that he will die for, he isn't fit to live. -- Martin Luther King, Jr.
citrus1
Wed Sep 26, 2007 1:37 pm
I just can't believe, it took 26 replies to tell you it means I  Smile
atct
Thu Sep 27, 2007 12:41 am
Anywho regarding ATIS's.
They come up every hour, unless we have what is called a "SPECI" (or Special Weather). This is when conditions have changed enough to warrant a new ATIS. Also if we have a new taxiway closure, runway closure, ILS/NAVAID failure, OTS, etc. etc. etc. we'll "Cut a new ATIS". At big airports, our ATIS's run 24/7 and never shut down/start-up again like at smaller facilities when they close at night etc.
I might have missed it, but it is also an FAA requirement for all IFR aircraft to have the current ATIS, not just "The numbers" and for all VFR aircraft to at the minimum have what we call the numbers (runway, wind, altimeter), when flying into an airport with the ATIS. Most people arent sticklers for that one, but I always make sure you say "I'll get bravo" or "I have bravo" when you said "info Alpha" or "I have the numbers".
ATCT
Trikes are for kids!
j.mo
Thu Sep 27, 2007 1:02 am
We get a few pilots who like to shortcut the whole "listening" part of getting the ATIS. They listen long enough to hear which letter is current, but not long enough to catch "Clearance Delivery is closed, combined with ground control on 121.xx..."
So what we hear is; "XXX flight 340 requesting clearance with Charlie." On the clearance freq.
One night we had everything combined on the tower frequency, which was on ATIS KILO. About 9:00pm a Tomahawk student pilot starts calling for VFR departure instructions on the ground frequency, with information KILO. I ignore him. He calls again and states he has KILO. I ignore him. Half a minute goes by.Now the instructor gets on with an attitude. "SO AND SO GROUND, RADIO CHECK, ANYONE THERE?" So I punch up the frequency and say "Tomahawk 123, did you say you had KILO?" Instructor replies; "Affirmative, KILO." I say; "On information KILO it states everything is combined with the tower on 118.xx." About a minute later the student checks in again on tower frequency with KILO. Haha. Good times.
JM
GimliGlider
Thu Sep 27, 2007 7:29 am
I've heard it plenty of times. One instance was on St. Patrick's day, really early in the morning:
Tower: Attention all aircraft, ATIS information whisk....viskey [start Irish accent] is now current, the altimiter's tree zero one fife.
Unknown person on frequency: Haha!
Tower: Aye, its St Patty's day!
Perhaps he did it to make fun of the 'tree' and 'fife' pronunciations that we're supposed to be using, funny nevertheless.
Quoting Kukkudrill (Reply 15):
Hehe. Here, ATIS usually tells people to "advise on initial contact you have information ____", unfortunately.  Wink
"You could attach that to your house and still go 0-60 in 5 seconds..."
2H4
Thu Sep 27, 2007 7:41 am
I once heard ATIS Papa....only the controller pronounced it "puh-PAH".
Sure enough, each and every aircraft calling ground or tower reported having that information:
Cessna 3258Y is 10 to the north, inbound for landing with puh-PAH
Cardinal 45 Bravo is at the terminal ramp, ready to taxi to the active with puh-PAH
Extra 4 Mike Golf, 8 east, inbound puh-PAH
...and so on. It was pretty ridiculous.  biggrin
2H4
Intentionally Left Blank
Mir
Thu Sep 27, 2007 8:12 am
Quoting 2H4 (Reply 31):
According to the 7110.65, the accent should be on the second syllable, even though very few actually say it that way.
-Mir
KELPkid
Thu Sep 27, 2007 8:50 am
2H4
I got corrected once by the ABQ approach controller for referring to the aircraft I was flying (N2809Q) as "zero niner kwebec", instead of the proper ICAO pronunciation of "zero niner kebec" (note in the second one, the lack of the "w" sound)  Yeah sure
N231YE
Thu Sep 27, 2007 9:16 am
Speaking of ATIS...have any of you guys ever caught ATC "goofing off" in the backround (while the messgae was being taped)?  wink
CosmicCruiser
Thu Sep 27, 2007 9:31 am
Going into JFK once the ATIS had a happy birthday greeting to one of the controllers. Of course every jet that checked on wished a happy birthday to XXXX!
pilotaydin
Thu Sep 27, 2007 9:48 am
according to JAA, we aren't supposed to phrase anything "with...."
it's information X,y,z onboard, and they dont like it when you say with so and so
The only time there is too much fuel onboard, is when you're on fire!
aauzou
Thu Sep 27, 2007 9:51 am
Iv was tought the correct terminology in Australia anyways is received Romeo, but i always here people especially helicopter pilots using with
Fly2HMO
Thu Sep 27, 2007 12:32 pm
Every time I get information Whiskey I like to say "I've got the booze news". The controllers get a kick out of it Big grin
n710ps
Thu Sep 27, 2007 1:05 pm
Out spotting once at JFK with a few of our fellow Anet spotters I called ATIS on my cell and at the end it had some sort of statement like Pluto, planet or not, you decide. This was shortly after they announced it was no longer considered one. On the scanner a few including a B6 flight checked in with ground and remarked at the end "and we say it is a planet." Pretty funny.
9VSIO
Thu Sep 27, 2007 2:08 pm
Quoting KELPkid (Reply 21):
Here goes:
Its over las vegas, information Hotel is current, and Mooney 33W is unfamiliar and talking to approach
Approach: 33W, confirm you have hotel
33W: Ummmm, we flying into McCarren International. Umm, we don't have a hotel room yet.
Approach was laughing too hard to respond. The next few calls went like this:
Approach: United 5, descend to FL220.
United 5: United 5 down to FL220, we don't have a hotel room either.
Thu Sep 27, 2007 2:12 pm
Quoting KELPkid (Reply 33):
Heh. Well, the proper French pronunciation is indeed with a silent "u". Thus "Kébek".
A
71Zulu
Fri Sep 28, 2007 1:16 am
Don't know how true they are, but saw something like this posted somewhere
Pilot: Tower, Cessna 172 10 east for landing
Tower: Cessna 172, do you have HOTEL?
Pilot: Don't need HOTEL, I live in an apartment
Pilot: Tower, Cherokee 180 south of the field for landing
Tower: Cherokee 180, do you have UNIFORM?
Pilot: No, I am in a t-shirt and jeans
APFPilot1985
Fri Sep 28, 2007 1:33 am
Quoting Starlionblue (Reply 41):
The AIM also says that five is supposed to be FIFE, three is TREE, nine is NINER, and one is WUN
Stand Up and Be Counted Visit Site Related to Voice your opinion
EridanMan
Fri Sep 28, 2007 2:10 am
At burning man every year, they put out an unofficial notam to all aviators which discuss traffic protocol and pattern altitudes. Every year the notam has a code which we are asked to repeat to let the Unicom guys know that we've actually read the information and know what we're doing.
This year, the code was "PANTS OFF".
"Black Rock City Traffic, Red White Cherokee Inbound over Empire, 5500 for landing pattern with pants off"
SBBRTech
Fri Sep 28, 2007 4:26 am
Quoting 9VSIO (Reply 40):
Here goes:
LOL,....
now seriously, how come a pilot gets a comercial license without mastering such terms?
"I'm beginning to get the hang of this flying business" - C3PO
KELPkid
Fri Sep 28, 2007 5:30 am
ere goes:
 rotfl  Thanks for sharing that one!
APFPilot1985
Fri Sep 28, 2007 12:54 pm
Quoting J.mo (Reply 29):
At APF we have had the runways closed a few times recently for painting during the day for a couple of hours. Well about a month ago during one of those stints we had an old guy climb into his mooney fire up and call ground.
Mooney: Naples Ground mooney 1234 with you at the authority ramp taxi with KILO for a VFR departure to the south
Ground: Mooney calling naples you said you have the atis?
Mooney: Yes KILO
Ground: Well then sir you would know the runways are closed so could you please say intentions
Not another word from the mooney. The guy shut down walked inside avoiding eye contact with everyone.
atct
Sat Sep 29, 2007 6:00 am
Sounds like an operational deviation waiting to happen if ya ask me.
Quoting N231YE (Reply 34):
Never  Smile
ATCT
N231YE
Sat Sep 29, 2007 9:31 am
Quoting ATCT (Reply 48):
Never
Never say never!
Speaking of which, my University is having a University pilots versus TOL ATC football game (we use them a lot). I'm kinda scared, because us pilots are in a lose-lose situation.
If we lose, then we lose, and if we win, I can see the harassment they'll provide us when we use them, "hey, its one of them...vector them so far north that they see endless caribou, snow, and lots of people playing hockey"  wink
Users browsing this forum: ATA L1011, PITingres, Yahoo [Bot] and 1 guest
