LASoctoberB6
A320 Flap Settings
Wed Oct 03, 2007 12:32 pm
after the pilot chooses (in the manual it says 1+F) which means that slats would be deployed with 1st setting of flaps. do the ailerons also tilt downwards a little when 1+F or more is selected?
[NOT IN SERVICE] {WEStJet}
pilotboi
RE: A320 Flap Settings
Thu Oct 04, 2007 7:19 pm
Quoting LASOctoberB6 (Thread starter):
Not sure exactly what you mean. Ailerons should never BOTH 'tilt downward'. When one is down, the other should be up. This is what makes the airplane bank. Did you mean to say "do the FLAPS also tilt downwards" ?
n710ps
Thu Oct 04, 2007 7:30 pm
Not true, aileron droop is a very common feature to many many airplanes at certain flap settings. I know for sure the airbus family is one of those aircraft groups that it is a feature of.
There is plenty of room for Gods animals, right next to the mashed potatoes!
tom775257
Thu Oct 04, 2007 9:01 pm
On the A320, when flap is extended, the ailerons droop 5 degrees downwards.
LTU932
Thu Oct 04, 2007 9:33 pm
Quoting Pilotboi (Reply 1):
In the traditional sense, that's correct, but nowadays, ailerons have become multifunctional. Aileron droop at certain flap settings are pretty common (hence why they may also becalled flaperons). Look at the 767 and 777 for example, as their inboard ailerons droop in a certain degree dependant on a particular flap setting. On the A340-500/-600, ailerons can even work as lift dumpers assisting the ground spoilers, since they extend upwards with the ground spoilers when the aircraft touches down and rolls out.
An aileron isn't just an aileron anymore on many aircraft.
SilverComet
Fri Oct 05, 2007 12:54 am
Never say never. Stick around here long enough and you'll soon realise you still have a lot to learn.
Quoting A320 FCOM 1.27.10 'Flight Controls - Architecture':
The ailerons extend 5° down when the flaps are extended (aileron droop).
Straight from the horse's mouth.
n710ps
Fri Oct 05, 2007 1:17 am
I have pics someplace that will show the narrow body Airbus and A-330 in various configs from my ceaseless non reving on days off and commuteing.
pilotboi
Fri Oct 05, 2007 1:19 am
Quoting LTU932 (Reply 4):
Well you learn something new every day. Is this an official term - flaperons? You europeans come up with the craziest things.  Silly
Mir
Fri Oct 05, 2007 3:27 am
Quoting Pilotboi (Reply 7):
It's not just Europeans, Boeing has flaperons on the 777 as well.
-Mir
Fri Oct 05, 2007 3:35 am
It is indeed a real word. However IIRC it is used by Boeing. Airbus uses "drooping ailerons". Or is it the other way around?
Another fun multiunction surface term is elevon (elevator+aileron). As seen on many modern fighters such as the F/A-18 where the elevators also provide additional roll control.
LASoctoberB6
Fri Oct 05, 2007 4:14 am
i thought i was seeing things, but thanks for the answers.
Quoting SilverComet (Reply 5):
you calling me a horse?  Smile
pilotboi
Fri Oct 05, 2007 4:48 am
Quoting Mir (Reply 8):
Well I'll be darn. The whole world has gone mad!  Silly
Now that one I have heard of.  Smile
Jetlagged
Fri Oct 05, 2007 10:19 am
You could argue whether it is a real word or not. It is used by Boeing however, so that must give it some authority. Irregardless isn't a real word, but people still use it regardless.  Wink
Elevon is a much older word and usually refers to the controls on a delta. The differential all moving tail on the F-18, Tornado, Jaguar, etc. is more often called a taileron (equally as ugly as flaperon), rather than elevon.
The reason I don't like the term flaperon is that it implies they are primarily flaps, when in fact the opposite is the case. In comparison elevons function as elevators and ailerons in all phases of flight.
Fri Oct 05, 2007 11:50 am
Even more fun is making them up:
- Ruddgearvator - A combined rudder, landing gear and elevator.
- Flapevator - A combined flap and elevator. Delta wings only I guess.
- Propatder - A combined propeller, slat and rudder.
pilotboi
Fri Oct 05, 2007 1:51 pm
Quoting Jetlagged (Reply 12):
So let's call it an ailerap.  rotfl
LTU932
Fri Oct 05, 2007 6:05 pm
Don't forget the word "spoileron".  Wink
SEPilot
Fri Oct 05, 2007 11:45 pm
Quoting Starlionblue (Reply 13):
Can you give me an engineering drawing of that one?  rotfl
Viscount724
Sat Oct 06, 2007 2:50 am
I believe the shrunken L1011-500 long range model (only 50 built) was one of the first, if not the very first, commercial aircraft with what Lockheed called "active ailerons" which both moved in the same direction to reduce loads on the wing (the -500's wingspan was about 10 ft. greater than earlier L1011 models).
See page 15 (page 13 of the PDF file) of the following Lockheed brochure (the "Extended Wing/Active Controls" section and related diagram).
http://www.tristar500.net/features/Technical_Profile.pdf
LTU932
Sat Oct 06, 2007 6:22 am
Quoting Viscount724 (Reply 17):
Interesting. I didn't know of the Extended Wings/Active Controls feature on the 500. Previously I only knew of the 500's Direct Lift Control, which was also a state of the art feature.
The L-1011 was truely ahead of its time with those features. Too bad its commercial success (or lack thereof) didn't do it justice.
Ward86IND
Wed Oct 10, 2007 6:19 am
I believe that when flaps 1 is selected under 210 kias, it is 1+F, over 210 kais, slats only.
Live your dream.
SilverComet
Wed Oct 10, 2007 7:06 am
Quoting Ward86IND (Reply 19):
It depends. What you say applies only when you select the flaps lever from 2 to 1. When selecting from 0 to 1 the same logic applies but the threshold speed is 100kt.
Furthermore when in config 1+F, as speed increases beyond 210kt, the flap automatically retracts and you end up in config 1. This is to avoid exceeding VFE 1+F (= 215kt).
LASoctoberB6
Thu Oct 11, 2007 6:07 am
right. and do the slats retract automatically and the pilots are supposed to "pack-in" the flaps?
Ward86IND
Mon Oct 15, 2007 12:39 am
I think that as the plane accelerates through the F speed after a 1+F takeoff, and flaps up is selected, the flaps and slats retract simultaneously, assuming this speed is less than 210 kais. Maybe we could get SilverComet to confirm.
Live your dream.
Jetlagged
Mon Oct 15, 2007 1:14 am
Quoting Ward86IND (Reply 22):
For a 1+F takeoff, the S speed will be displayed, not the F speed. If flaps up is selected with speed less than 215 kts, slats and flaps will retract at the same time.
SilverComet
Tue Oct 16, 2007 1:07 pm
Correct, except
Quoting Jetlagged (Reply 23):
 checkmark
You probably meant 210kt.
Quoting SilverComet (Reply 20):
Anything above 210kt (and flap lever in the '1' position) and you only have slats. Flaps have already been automatically retracted.
From the FCOM:
Big version: Width: 1392 Height: 646 File size: 59kb
Jetlagged
Tue Oct 16, 2007 7:05 pm
Quoting SilverComet (Reply 24):
I probably did  Wink
Users browsing this forum: EIASO, Iemand91, zeeth and 2 guests
