747fan
A300/A310 Flap Settings On Takeoff
Wed Oct 10, 2007 3:11 pm
As a regular spotter at SDF, I see UPS A300's depart all the time and have noticed that they often takeoff with their flaps up (although their leading-edge slats appear to be down, and a section of inboard flaps right behind the engines are down). I've also noticed the same thing in photos/videos with the Fokker 100. Does anyone know why they can takeoff with the flaps up? Is it due to the efficient A300 wing? Also, I've noticed that A300's also takeoff with their flaps down sometimes; for example, FX seems to always use flaps on takeoff, sometimes AA. But why do they only put the flaps down for takeoff occasionally?
David L
RE: A300/A310 Flap Settings On Takeoff
Wed Oct 10, 2007 3:44 pm
Some information here:
RE: Flapless Take- Offs (by IDISA Mar 9 2006 in Tech Ops)
Thu Oct 11, 2007 1:32 am
Quoting 747fan (Thread starter):
Efficient wing as you say.
Depends on take-off weight and runway length. Higher weights require more flap. However a longer runway allows higher take-off speed, allowing less flap. In the latter case, climb speed is also higher.
747fan
Thu Oct 11, 2007 1:41 am
Quoting Starlionblue (Reply 2):
I've noticed that A300's with the flaps down during takeoff tend to have a more sluggish climbout than when they use only the "flaperons" and slats. Those things really appear to climb like rockets when they takeoff "flapless." I wonder if this has to do with the higher takeoff speed?
BWilliams
Thu Oct 11, 2007 1:16 pm
Quoting 747fan (Reply 3):
Flaps increase lift, but also increase drag. So, while flaps give you more lift at a lower speed letting you get off the runway faster, a flapless T/O has you flying at both a higher speed and a lower-drag configuration, so you climb faster after you manage to get off.
Regards, Brad Williams
Users browsing this forum: Majestic-12 [Bot], Yahoo [Bot] and 12 guests
