Rusty Bolts On SAS Dash-8 Q400 Landing Gear
Mon Oct 15, 2007 7:45 pm
Apparently SK has now had quite a few incidents with the Dash-8 Q400s, including two where the landing gear collapsed on landing due to rusty bolts.
Of course, the tabloid media is now all over this, and as soon as there is the slightest whiff of something going on with a plane the coverage is beyond tedious. "Routine" precautionary landings are written up with the attention worthy of smoking holes in the ground. Apparently, SAS is now suing Bombardier for SEK 482 million (around $70 million). Furthermore the Danish cabin crew association is demanding SK replace the type.
For those who understand Swedish, here's a link: http://www.aftonbladet.se/nyheter/article1020566.ab
Is this a "big deal" or is the tabloid just exaggerating? What's with the rusty bolts?
KELPkid
RE: Rusty Bolts On SAS Dash-8 Q400 Landing Gear
Mon Oct 15, 2007 7:51 pm
From what I've gathered (discussion over in Civ-Av), part of it is environmental: Apparently, SAS parks their Q400's overnight at an airport in Denmark where their parking ramp is right next to a seawall and the aircraft are exposed to heavy salt spray because of that  Sad I could see where that would shorten the life of any metal parts...not just ferrous (iron) based metals either.
Mon Oct 15, 2007 11:45 pm
Thx KELPkid. Sounds like classic PEBKAC then.  Wink
tdscanuck
Tue Oct 16, 2007 2:14 am
Quoting KELPkid (Reply 1):
Another factor that hits European operators is the use of formate-based deicing fluids. SAS works in an environment where deicing is a lot more common that, say, Horizon Air and European airports usually use formate fluids (rare in the US) which are nastier to the metal bits but more environmentally friendly.
Tom.
KELPkid
Tue Oct 16, 2007 3:33 am
Quoting Starlionblue (Reply 2):
Hehe, I wasn't familiar with the term, so I googled it. Of course the Wikipedia article was on top. I thought you'd appreciate this direct quote from it: "In Sweden the term is 'skit bakom tangenterna', literally 'crap behind the keyboard'."
But thanks, a new term for my vocabulary at work when dealing with irate (but clueless) IT customers Big grin The profession that pays for my aviation addiction  Smile
BreninTW
Tue Oct 16, 2007 8:52 am
Quoting KELPkid (Reply 4):
But thanks, a new term for my vocabulary at work when dealing with irate (but clueless) IT customers The profession that pays for my aviation addiction
Ah, so you also get lot's of "ID-ten-T" problems to deal with  Smile
Tue Oct 16, 2007 9:25 am
Isn't there an Scheduled Inspection check on these bolts if the problem is so common.
regds
MEL
Norlander
Tue Oct 16, 2007 12:19 pm
Quoting Starlionblue (Thread starter):
From the various civ-av threads on this subject it seems that it's not only SK has problems with the Q400. The place that they park their aircraft next to the Øresund isn't that exposed either. It's a narrow straight with landmasses next to it and "high-winds" are seldom encountered there, so there is a lot of current in the straight, but not much wind. Which doesn't give much spray from the salt water. Furthermore the water in the Øresund has a lower salinity then oceanic water.
Hence it's a good possibility that there is some other reason for this problem with the Q400s
Longtime Lurker
BAE146QT
Tue Oct 16, 2007 12:51 pm
Quoting Norlander:
I left a brand-new Cannondale bike parked in an underground garage at my grandmother's condo on the Galt Ocean Drive (Ft. Lauderdale) while I was on holiday a few years back.
Even though it wasn't in direct spray, the atmosphere was salty enough that within days there was very visible corrosion on any exposed (meaning unlacquered) aluminium parts, as well as the (brand new and lubricated) chain, brake cables, ferrules and bolt heads.
Notwithstanding the lower slainity, and the maint that the Q400s would be getting, they'd be far more exposed than that and I wouldn't be surprised to find that it played a factor.
Todos mis dominós son totalmente pegajosos
DYflyer
Tue Oct 16, 2007 1:44 pm
Quoting Norlander (Reply 7):
Also, the parking at CPH would not explaine the rust on SK Sweden´s and Wideroe´s plane.
Life is like a book. If you don't travel, you only read one page.
Tue Oct 16, 2007 3:34 pm
It is a classic: http://www.felix-schwarz.name/files/...Linux_ist_nicht_Windows/pebkac.gif  Wink
prebennorholm
Tue Oct 16, 2007 8:04 pm
You can just forget about the salty Oeresund water as the root cause for those accidents. We are in the middle of the "west wind belt", and Oeresund is directly east of CPH. Strong winds are always westerly. There may be a storm from east every 10 or 20 years. Oeresund has only about 20% of normal ocean salt contents.
There are hundreds of airports in the world which are more prone to salt spray than CPH. Some of them are also visited by SK Q400s, for instance Aalborg (where the first accident happened), another is Stavanger, Norway.
All sorts of planes are parked at CPH, not just Q400. Some of them are 5-6-7 times older than the oldest Q400s, still they don't fall apart from corrosion.
Deicing is a frequent activity all over northern Europe during a substantial part of the year. But then again, all plane types receive deicing treatment.
It is a plane quality / maintenance issue. Nobody ever doubted that SK maintained the Q400s according to the book. That wasn't enough.
Of course corrosion is a consequence of the ambient environment, and of course planes are more prone to corrosion in Scandinavia than in Australia. But for almost a hundred years planes have been produced and maintained in a way so they can fly in Scandinavia without falling apart. And sure the Q400 and/or its maintenance procedures will be changed in a way so it won't be the exception.
BTW, the bad press the Q400 has got here didn't start with the two accidents. It began immediately after introduction of the plane seven years ago, and it kept on. Regularity was at such a low level that it really differentiated itself from all other plane types. Then the first accident happened, and SAS told us that this was a totally ununderstandable issue which could never happen again. And then it was repeated 57 hours later.
And it doesn't stop there. Last week on Tuesday, Wednesday and Thursday, after only part of the fleet had entered service with replaced landing gear parts, the SK Q400 had three issues. One aborted take-off with an engine problem. One returned because the gear wouldn't retract. And one diverted because a nose wheel door wouldn't close. Those issues were not safety related, but still, as much too often before, pax weren't brought from A to B within the timeframe they expected.
When cabin crews urge SAS to replace those planes asap, then it is probably because they are afraid of losing their job. The situation is so that SAS loses tons of business to the competitors as long as they haven't proved two consecutive years of reliable Q400 service. Hopefully such two years can start tomorrow.
WrenchBender
Tue Oct 16, 2007 9:29 pm
Just being present in a 'Salt Laden Environment' is enough to start corrosion. That can mean as much as 10 miles inland from the ocean. Humidity and temp also have a huge affect on the causation of corrosion, other areas of concern that have occured in the past on landing gear is the disinfectant used by some countries to prevent the spread of Hoof and Mouth.
Quoting Prebennorholm (Reply 11):
2 out of 3 of those issues sure sound like bad maintenance. Work done on landing gear and immediately after you have a retraction failure and a nose gear door out of rig. Is some one in the company trying to make a statement the ugliest way possible?
Just a thought........
WrenchBender
Silly Pilot, Tricks are for kids.......
avt007
Tue Oct 16, 2007 9:48 pm
The "rusty bolt" in question was in fact the rod end of the gear actuator pulling right out of the actuator assembly. How the threads got so corroded is a bit of a mystery.
prebennorholm
Tue Oct 16, 2007 11:20 pm
Quoting WrenchBender (Reply 12):
Dear WrenchBender, to me it easily sounds like even 3 out of 3. Even if I don't know why they had to shut down an engine during take-off run - could be a manufacturing fault.
And it's a mystery how come SK can fly the most diverse fleet in the world with very fine dispatch rates on all types of planes, except one, and then have such severe problems with that one.
I don't think I can figure out what you mean. Which company? I just quoted facts about three issues as they were reported by various news agencies, newspapers, radio, TV, internet etc.
If your "the company" is SK, then they say as little as possible. They issued a few press releases mostly dealing with what flight cancelations to expect, and on which phone numbers or internet sites to obtain detailed information about cancelations. Only right after the grounding did they also tell us that defective parts had been found on 25 out of 27 planes, and that no plane would fly again until those parts had been exchanged. Which would take some time due to spares availability. But the last plane took to the air yesterday or the day before yesterday, so SK has nothing more to tell us.
If you want to hear "the ugliest", then you have to ask any Danish kid to tell you a selection of "Dash-8 jokes". They can't be printed here.
Wed Oct 17, 2007 12:58 pm
Quoting Prebennorholm (Reply 14):
Why not? Just star the swearwords.  Wink
prebennorholm
Wed Oct 17, 2007 8:16 pm
Quoting Starlionblue (Reply 15):
No, it won't work.
Actually, a month ago I quoted one in the GA forum, one of the nicer ones which I had heard on the Danish radio program DR-1 (similar to BBC One). Just as an example to demonstrate the mental Q400 situation in this country. It was de-leted by the mod as being *¤%#*ly unfit for a place like a-net. In which I agree.
Scan your kid's SMS inbox instead. Or rather, don't do that!
Wed Oct 17, 2007 8:24 pm
Quoting Avt007 (Reply 13):
Someone has not followed procedures.
regds
MEL
Thu Oct 18, 2007 12:07 pm
Quoting Prebennorholm (Reply 16):
Seeing as my older kid just turned two, I think not.  Wink
Anyway if you have them written down pm me. But don't go to any effort. I'm not THAT interested.
Sun Oct 28, 2007 3:14 pm
Apparently SK will take the Dash-8 out of service after yet another incident where the landing gear did not deploy. http://www.aftonbladet.se/nyheter/article1115988.ab
Furthermore, the Dash-8 Q400 is now grounded by the Scandinavian authorities regardless of operator.
[Edited 2007-10-28 08:15:39]
Buyantukhaa
Sun Oct 28, 2007 3:55 pm
When reading this I thought this was impossible, as both the North Sea and the Baltic sea are salty (albeit less so in the latter case). But it seems that you're right... interesting.
http://home.swipnet.se/~w-48087/fagl...aterialmapp/vadarmapp/oresund.html
I scratch my head, therefore I am.
copter808
Sun Oct 28, 2007 4:50 pm
Quoting BAe146QT (Reply 8):
Just a note...did you know that Art Galt (of the Galt Ocean Mile family) owned an airport in Illinois? Quite a guy for those of us who knew him. Looked like a farmer, dressed like a farmer, but was very smart--and rich! One REALLY super guy though!
BAE146QT
Sun Oct 28, 2007 10:50 pm
Quoting Copter808 (Reply 21):
To be honest, I never even knew the origin of the name. Thank you for taking the time to post - I will spend some effort Googling this!
[Edited 2007-10-28 15:50:52]
MissedApproach
Tue Oct 30, 2007 10:04 pm
Porter Airlines was quoted in one of the 'papers today as being very happy with their Q400 fleet. They further say they believe the problem lies within SK .
Many other airlines have temporarily grounded their Q400's until detailed inspections can be made. More here:
http://www.canada.com/nationalpost/f...677-45b5-96e9-38e91dfd9cb2&k=13923
Can you hear me now?
474218
Tue Oct 30, 2007 10:25 pm
Sounds like they need to seal the rod end better.
WrenchBender
Tue Dec 11, 2007 2:12 am
It seems that SAS maint aren't looking to good after the prelim report from the ;last incident.
From the article.....
Denmark’s Accident Investigation Board reported that the landing gear accident of SAS Dash 8 - Q400 LN-RDI at 27.10.2007 in Copenhagen was caused by a piece of rubber O-Ring trapped in the landing gear, preventing it from extending accurately.
This cause is not related to the two previous accidents which occurred in September 2007. According to the preliminary investigation report, this accident might have happened because of a fault by maintenance personnel and not because of a possible design fault of Bombardier’s Q400.
http://blog.flightstory.net/375/prel...ort-sas-dhc8-q400-ln-rdi-accident/
WrenchBender
Users browsing this forum: E2, Starlionblue and 2 guests
