LASoctoberB6
Virgin America Doesn't Have Traditional Gear Sound
Mon Oct 29, 2007 4:39 am
On my flight to SFO a couple weeks ago, I was expecting to hear that traditional ding when the landing gear is in motion. All other airlines I've been on and the ones I watch on YouTube always have the ding. A320s all over the world seem to have it, but not Virgin America. And yes if you're wondering, all of the recent threads from me are mainly about the A320 because I'm currently obsessed with them..
[NOT IN SERVICE] {WEStJet}
kearney
RE: Virgin America Doesn't Have Traditional Gear Sound
Mon Oct 29, 2007 4:44 am
I wonder if the "ding" is automated with the gear toggle... I love that sound, If it was up to me 320's would go "ding" more often.
jetmech
Mon Oct 29, 2007 5:57 am
Quoting LASOctoberB6 (Thread starter):
You mean you can hear a "ding" in the cabin as the gear transits  Confused
Regards, JetMech
MD11Engineer
Mon Oct 29, 2007 6:22 am
The "traditional" sound of landing gear deploying is "Bang rumble rumble". No chime anywhere in the system.
Jan
Mon Oct 29, 2007 7:45 am
The chime is for the flight attendants to know they can move about. And that's waaaay later than gear up. Typically it is at 10k feet or higher. Gear up is normally commanded when positive rate of climb is observed.
Tristarsteve
Mon Oct 29, 2007 1:05 pm
The chime you hear with gear up or down is associated with the no-smoking signs. With the switch in automatic the signs go out with LG retraction, and a single chime. Same on extension when the signs go back on. Nowadays everyone leaves the no smoking sign in ON so the signs stay on, but the chime still sounds.
I suspect that on the new build aircraft, Airbus has finally rewired the system so the ding doesn't sound any more.
The crew still use the no smoking sign switch on the A320. On the ground when all the pax are off, you turn it to off and the emergency exit lights go out.
DeltaGuy
Mon Oct 29, 2007 2:34 pm
On older aircraft, even as recent as MD-88's and 732's, it was wired for the no smoking light to extinguish at gear up, and the fasten seatbelt to extinguish at flaps 0. Now as stated above, "on" is the setting used nowadays.
DeltaGuy
Buyantukhaa
Mon Oct 29, 2007 5:32 pm
Quoting JetMech (Reply 2):
Yes, and again when it comes down.
I scratch my head, therefore I am.
jetmech
Mon Oct 29, 2007 10:21 pm
Quoting BuyantUkhaa (Reply 7):
Did not know that!
Quoting Tristarsteve (Reply 5):
Makes sense.
Regards, JetMech
LASoctoberB6
Tue Oct 30, 2007 12:08 am
When did they change that?
N622VA was made last year and I think jetBlue's A320s
I did notice that in August on jetBlue's newer A320s (the ding even sounded different) that the emer. exit lights on the overwing exits lit up when the gear was lowered and vice versa.
Quoting Kearney (Reply 1):
If it were up to me, that ding would be dingin' every 10 minutes. (that's how much I love it  Smile )
Quoting MD11Engineer (Reply 3):
And along with the "Bang rumble rumble" there is usually a ding.
luv2cattlecall
Tue Nov 06, 2007 3:56 pm
I noticed that the Virgin America planes I've been on (I'm assuming they're all going to be the same, but not sure since some have been around for quite some time while they waited for approval), there's no "No Smoking" sign, instead it's one of those "Please turn off all electronic devices" ones. That could be why the no smoking light selector ding is a no-go.
CoolGuy
Mon Nov 12, 2007 3:58 pm
Why is there a 'bang' sound as opposed to just the rumbling?
9VSIO
Mon Nov 12, 2007 5:27 pm
Quoting CoolGuy (Reply 11):
It's the sound of the midget being woken up and smacking his head against the bulkhead before cranking the gear down  Big grin
I always thought it was due to the doors being unlocked and the actuators snapping into place.
Me: (Lining up on final) I shall now select an aiming point. || Instructor: Well, I hope it's the runway...
Mir
Mon Nov 12, 2007 9:26 pm
Quoting Luv2cattlecall (Reply 10):
US's A319/320/321s have those signs as well, and have for a while.
Quoting 9VSIO (Reply 12):
 rotfl
-Mir
LASoctoberB6
Mon Nov 12, 2007 11:01 pm
I've also noticed that outside of the plane, the strobe lights do not flash like almost all other Airbus planes. Anybody?
Tue Nov 13, 2007 12:17 am
Quoting LASOctoberB6 (Reply 14):
That's a regulatory requirement. I doubt the FAA gave Virgin America a dispensation.  Wink
Ceph
Tue Nov 13, 2007 2:57 am
Care to elaborate? Do you mean that the strobes don't flash twice(double hit)?
luv2cattlecall
Thu Nov 15, 2007 6:34 pm
Quoting Starlionblue (Reply 15):
Hey, they got around the whole "Branson can't be associated with you" thing didn't they  duck
UnknownUser
Thu Nov 15, 2007 7:12 pm
Unless there is something different about commercial carrier operations, Part 91 in VFR/IFR day or night requirements does not specify 'strobe lights', but rather an approved red or white aviation anti-collision light. (If I recall correctly.)
Die Skybus!!! You need to die for the good of the industry!
LASoctoberB6
Fri Nov 16, 2007 3:19 am
Quoting Ceph (Reply 16):
The right strobe only flashes once and the left flashes twice. The strobe near the APU isn't synchronized with the L&R strobes.
Ceph
Fri Nov 16, 2007 12:10 pm
Quoting LASOctoberB6 (Reply 19):
I see... I have noticed that some times the strobes are not in sync... But airbus wing-tip strobes are supposed to be double hits... Perhaps the right one has some sort of problem with an electrical component...
Strathpeffer
Mon Nov 19, 2007 9:11 am
Talking of the strobes, I have noticed that several of BA's A320 family aircraft now lack the 'double hit' wingtip strobes - instead they just blink once. Why the change?
PJ
Another Technical Problem?
Mon Nov 19, 2007 9:50 am
That depends on the mod status and CIDS/CAM programming of the of the aircraft.
With the NO SMOKING selector for VAM MSN 2773, the NO SMOKING and EXIT light cycle when the gear cycles, and you get the low chime (which is CIDS/CAM programmable). For VAM MSN 2616-2740 2778, only the EXIT lights cycle, the NO SMOKING stays on all the time, the low chime is also CIDS/CAM programmable.
The change with the NO SMOKING configuration came in with mod 33254 "Placards and Marking - Cabin - Configure the cabin for Non Smoker Flight".
Any airline can program the chime not to ding by programming CIDS/CAM in any A320 series aircraft.
JETBLUEATASW
Sun Nov 02, 2008 6:01 pm
LASOctoberB6 i know how u feel. I love red is my favorite color, then i love the airbus A320 family including A318/A319/A320/A321. I havent had an experience on the A318 yet. my experiences with the A319 is because i work for US airways as a ramp agent, and they are great for non revving a us airways shuttle flight from LGA-DCA and back in same day. our A319s are configured to 112 seating, (100 Coach, 12 first class). First ride on A320 was "blue Monday" on Jetblue august 2005. A321 first experience with it was flying on N189UW from LGA to Charlotte, NC (CLT) for one week of fleet service ramp training. US flight 985 seasonal service from LGA-CLT with continuing service to MBJ(montego bay jamaica). I even want to get 5,000 hours, ATP and the requirements even the A320 type rating if it will make them want to hire me later. Altho for now i can only dream because i have 21.7 hours in a Cessna 172 and havent even soloed yet.......
"DO ME A FAVOR WOULD YA, THE NEXT TIME U LAND A PLANE ON MY STRIP, BONE UP ON YOUR MORSE CODE"-Tom Berenger
FlyDeltaJets
Mon Nov 03, 2008 5:54 am
Quoting Strathpeffer (Reply 21):
Probably the timers in the new bulbs are not in sync
The only valid opinions are those based in facts
Users browsing this forum: Balerit, rlwynn, Tristarsteve and 2 guests
