bio15
B737 Yoke Moving In Windy Ramp Conditions?
Tue Nov 20, 2007 4:14 am
I came across this picture:
Photo © Danny Fritsche - Airplanespotters
On the remarks section the photographer says that it was windy, and thus the yoke moved blurrying out in the picture. I don't know much about the 737 or other aircraft with a similar architecture. But my initial thought is that if the hydraulic system is depressurized this shouldn't happen. Maybe even with pressurized hydraulics it shouldn't happen either? I don't really know what type of linkage exists between the yoke and the ailerons or elevator. Could anyone please explain to me a bit how the control surfaces are actuated trhough the hydraulic system, to understand how the event in the picture can happen? Thanks in advance
Please excuse me if my phrasing is confusing
Alfredo
ArmitageShanks
RE: B737 Yoke Moving In Windy Ramp Conditions?
Tue Nov 20, 2007 5:24 am
What about the manual reversion system? That might have something to do with it...
YWG
Tue Nov 20, 2007 5:29 am
Quoting Bio15 (Thread starter):
The system doesn't just go to zero pressure once the system is turned off, but gradually loose this pressure. If the wind on the ground were doing this (this is not the case) then there would be a hell of a fight at cruise level with the massive winds aloft.
Contact Winnipeg center now on 134.4, good day.
tdscanuck
Tue Nov 20, 2007 5:31 am
The 737 has manual reversion, hence this is entirely possible.
The control cable goes from the yoke to a control horn on the actuator. The actuator is rigidly attached to the control surface and the actuator rod is attached to the aircraft structure. If the flight control moves, it moves the actuator, which moves the cable, which moves the yoke. With the hydraulics depressurized, this should be more pronounced because you don't need to push the fluid around as much.
Tom.
Tristarsteve
Tue Nov 20, 2007 5:57 am
You can fly a B737 with no hydraulics. It is checked on test flights.
With ni hyd pressure all three control runs are connected with steel cables between the cockpit and the control surfaces.
If it is windy, the first thing you do on entering the cockpit is put on a hyd pump to stop the controil column from hitting you in the chest!
AAR90
Tue Nov 20, 2007 6:39 am
Quoting Tdscanuck (Reply 3):
Not only possible, but quite normal. Does not require very much wind to get the yoke moving when all hydraulics are turned off.
Tue Nov 20, 2007 7:57 am
Very Normal in windy conditions & Hydraulics off.
Remember Manual reversion exists on the B737 Ailerons.
regds
MEL
OldAeroGuy
Tue Nov 20, 2007 4:20 pm
Quoting HAWK21M (Reply 6):
And the elevators.
wilco737
Tue Nov 20, 2007 5:21 pm
Quoting OldAeroGuy (Reply 7):
But not very comfortable... Tried that in real life (don't worry, was a maintenance flight and we had to do that) and I had to do it as well in the simulator. You need quite a lot of power to fly the airplane... But it is possible... But I am always happy when we have hydraulic Big grin
Oh, on regarding to the question: yes, the wind can move the elevator or ailerons and then the yoke moves...
WILCO737 (MD11F)
 airplane
OldAeroGuy
Tue Nov 20, 2007 8:45 pm
Quoting WILCO737 (Reply 8):
I presume you mean muscle power rather than engine.
Of course manual revision is not a frequently encountered mode since it requires a two hydraulic system failure to reach this state,
wilco737
Tue Nov 20, 2007 8:57 pm
Quoting OldAeroGuy (Reply 9):
Yeah, I meant muscle power Big grin hehe
I wouldnt even call it a mode! I would call it an emergency if that happens... its so difficult to handle ...
WILCO737 (MD11F)
 airplane
EMBQA
Tue Nov 20, 2007 9:36 pm
Boeing still uses on many of its models control cables from the yoke to the respective flight control hydraulic power units. Boeing likes this idea as they say it gives the crew a 'feel' for the airplane. Airbus has gone to the all Fly By Wire, where only a wire bundle connects the yoke to the respective flight control hydraulic unit. There is a little more to the system, but this is the basics. Anyway........ if the wind blows hard enough the flight control will move slightly moving the input actuator from the control unit. This control unit is directly connected to the control cables which run up to the yoke in the cockpit. The movement is very slight and can only really be seen in this long exposure photo.
[Edited 2007-11-20 13:39:02]
AAR90
Tue Nov 20, 2007 10:33 pm
Quoting EMBQA (Reply 11):
...the flight control will move slightly... ...The movement is very slight and can only really be seen in this long exposure photo.
It MIGHT be slight, but in the 737 it is usually FULL THROW. The reason one of the first things a pilot does upon entering the cockpit is to turn on one electric hydraulic pump to prevent injury from wind-blown control column movement! Even a "slight" wind can cause RAPID and FULL control column movement.
JAGflyer
Tue Nov 20, 2007 10:53 pm
Quoting AAR90 (Reply 12):
Hans Moleman presents pilot getting hit by control column!
Support the beer and soda can industry, your recycle old airplanes!
OldAeroGuy
Wed Nov 21, 2007 4:34 am
You're not describing the manual reversion system used on the 737 (or DC9/MD80 et. al. for that matter). For manual reversion, there is a direct mechanical link between the control column/yoke and the elevators/ailerons. If the control surfaces move, the control column/yoke will move in direct response and vice versa. This can take place with no hydraulic power involved. On the 707, the elevator was not hydraulically powered. It was flown manually full time with the help of servo tabs.
Quoting WILCO737 (Reply 10):
On the other hand, I've seen a 120 lb female pilot fly the 737 in manual reversion without undue difficulty.
wilco737
Wed Nov 21, 2007 5:43 am
Quoting OldAeroGuy (Reply 14):
yeah, it is difficult to handle, but there are tricks to make it easier Big grin But I still prefer the flying with hydraulic Big grin
WILCO737 (MD11F)
 airplane
OldAeroGuy
Wed Nov 21, 2007 6:39 am
Quoting WILCO737 (Reply 15):
As does everyone who flies the 737.
Wed Nov 21, 2007 7:39 pm
Quoting OldAeroGuy (Reply 16):
Mx would prefer the cable as there would be no Skydrol  Smile
regds
MEL
bio15
Thu Nov 22, 2007 1:53 am
Hi everyone, I appreciate the responses.
First I would like to say that I am ignorant in the systems on such aircraft, but I understand some terminologies and have a good idea of the engineering behind systems and mechanisms.
To be honest, I have no idea of what manual reversion is  Smile. From what I get of the responses, it's a way of having direct mechanical control over the control surfaces in case of a hydraulic failure, right? I get a vague and general idea, but an image is worth a thousand words, does anyone happen to have any diagrams? I find those very interesting and clear.
Alfredo
AAR90
Thu Nov 22, 2007 3:28 am
Quoting Bio15 (Reply 18):
Try reading this
Thu Nov 22, 2007 3:22 pm
Thats true.
regds
MEL
bio15
Thu Nov 22, 2007 7:48 pm
Quoting AAR90 (Reply 19):
Try reading this
Thanks! It also contains interesting information on control feel design by Boeing.
Quoting HAWK21M (Reply 20):
Thats true.
regds
MEL
Something similar in the article posted by AAR90:
"In the event that both independent hydraulic systems “A” and “B” become unavailable the ailerons, elevator controls automatically revert to a simple mechanical reversion backup system. The control cables move the ailerons and elevator flight control surfaces directly, requiring higher pilot input control forces to move them."
When in the mechanical reversion mode, the control cables move the control surfaces directly. Are these the same cables that drive the hydraulic PCUs? Or are they separate cables that "come into action" by some sort of mechanism under hydraulic failure?
I'm thinking that if there's only one cable per control surface, it should be some kind of bifid cable, one end attached to the control surface and the other attached to the PCU. So in case of PCU inability, only one cable end becomes unusable and the other cable end is still directly attached? Is my imagination going too wild?  Smile
Alfredo
tdscanuck
Thu Nov 22, 2007 10:58 pm
Quoting Bio15 (Reply 21):
As far as I know, they're the same cable. The PCU is fixed to the control surface, not the aircraft. So, even if the PCU goes dead, the cable is still pulling directly on the PCU, which pulls on the control surface. Each control surface also has two cables going to it (A & B channel).
Tom.
PGNCS
Fri Nov 23, 2007 12:22 am
She must have been extremely strong for her size to not experience "undue difficulty," because I am a fit 220 lb male and I think it is extremely taxing and difficult to fly anywhere near precisely. The DC-9/MD-80 system, though, is never a problem for anyone I have seen with or without hydraulics.
Fri Nov 23, 2007 6:47 pm
They are the same cables that operate the PCUs,when Hydraulics are not functioning,an extra mvmt mechanically moves the Links to operate the Cables & the Contol surfaces.
regds
MEL
