744lover
WN 737 Cockpit
Fri Nov 23, 2007 3:38 pm
Hi there,
I wonder why WN removed the VNAV button from their 737 cockpits.
Photo © Justin Idle
Photo © Dan Brownlee
Shouldn't this feature reduce pilot's workload? Let's say in a CIVET approach into LAX where altitude restrictions are a pain in the a... It would help a lot
Any hint?
Best regards!
GHN
[Edited 2007-11-23 07:58:43]
modesto2
RE: WN 737 Cockpit
Fri Nov 23, 2007 4:27 pm
WN doesn't have autothrottle installed in its fleet - therefore, VNAV is inop.
LASoctoberB6
RE: WN 737 Cockpit
Fri Nov 23, 2007 5:06 pm
Quoting Modesto2 (Reply 1):
Why?
[NOT IN SERVICE] {WEStJet}
744lover
RE: WN 737 Cockpit
Fri Nov 23, 2007 6:41 pm
You can see on the first and second photos that the A/T engage switch is there, therefore it should have A/T operational.
flynavy
RE: WN 737 Cockpit
Sat Nov 24, 2007 7:07 am
There are no auto-throttle engage switches on the trust levers.
As for the reasoning, it's most likely for commonality between their 733/735 and 737NG fleets to optimize pilot familiarity. I would imagine their classic 737s are without VNAV as well.
This is a Delta 737-832 with VNAV/Auto-Throttle installed:
[Edited 2007-11-23 23:24:13]
Change is: one airline, six continents!
737tdi
RE: WN 737 Cockpit
Sat Nov 24, 2007 1:08 pm
O.K.: Here goes. Modesto 2, WN does have autothrottle installed. It's just deactivated. It would take me no time to have it working. Same as the VNAV.
Flynavy: What you have highlighted are actually referred to as TOGA switches, they control quite abit more than throttles. This is the exact configuration of WN's throttles.
As for the answer to why it is not used. WN does not use autopilot to land which is the main purpose of autothrottle, this being said, why have it there if you don't use it for it's intended purpose it's more expense in equipment and downtime when it breaks. As for the policy of not using the autopilot for landing that's up to someone with a paygrade much higher than mine, they have kept us profitable for many, many years so I defer to their wisdom. Not much help but there it is.
737tdi
IAHFLYR
RE: WN 737 Cockpit
Sat Nov 24, 2007 2:09 pm
Quoting 737tdi (Reply 5):
And then the crews and ops spec need to be signed off on the use of it, which I've heard in the rumor mill is coming!
SPREE34
RE: WN 737 Cockpit
Sat Nov 24, 2007 5:48 pm
Quoting IAHFLYR (Reply 6):
As is usually the case with Southwest, slow, methodical, effective, profitable change. Not a bad way to do business. I'm no MBA, but it seems to have worked well for about 35 years.
I don't understand everything I don't know about this.
737tdi
RE: WN 737 Cockpit
Sat Nov 24, 2007 6:36 pm
I really don't think so but I don't have any clue. I have no idea what is going on the flight ops side of things, until they come downn with the EA or CCO to change a system. I think we will stay the same.
737tdi
pilotpip
RE: WN 737 Cockpit
Tue Nov 27, 2007 2:52 am
They don't use A/T to reduce training costs much like the PFD's having a traditional instrument setup. At one time they were still operating steam guaged aircraft in addition to the NGs and this allowed the crews to operate both models.
DMI
IAHFLYR
RE: WN 737 Cockpit
Tue Nov 27, 2007 12:33 pm
Quoting Pilotpip (Reply 9):
So I wonder how much more CO training costs are then as the B73X crews fly all the round dial 300's, 500's, and the NG's?
744lover
RE: WN 737 Cockpit
Tue Nov 27, 2007 12:41 pm
Hi Pilotpip,
I think that the training required to operate the A/T and VNAV would be minimal, so to speak. Think of the advantages of reduced pilot workload. Another point is that the future will have based on VNAV approaches, like GNS and RNAV. WN should train their pilots for that!
Best Regards!
GHN
Jetlagged
RE: WN 737 Cockpit
Tue Nov 27, 2007 5:09 pm
The extra training for A/T use is minimal if anything at all. The only extra cost to allow common Classic and NG pilot rating is differences training to cover the different scan technique. All 737's have the same type rating.
Southwest seem to have a culture which prefers to avoid automation. Until recently they didn't approve the use autobrake either. It's as if they want to fly using the same techniques they used on their original 737-200s.
RE: WN 737 Cockpit
Tue Nov 27, 2007 5:15 pm
Quoting Jetlagged (Reply 12):
why would they want to do that.Technology when available should be utilised.
i'm only thinking did they experience too many malfunctions in these systems to warrant this.
regds
MEL
Jetlagged
RE: WN 737 Cockpit
Tue Nov 27, 2007 5:29 pm
Quoting HAWK21M (Reply 13):
I think it was to keep flight procedures the same as they had been before on the 737-200, but I'm open to correction on this. I don't think it was a reliability issue.
barney captain
RE: WN 737 Cockpit
Tue Nov 27, 2007 6:41 pm
The statements made so far pretty much sum it up - in a nutshell, it comes down to controlling costs. I do know that these things are constantly being reevaluated and imo, will come in to play sooner rather than later. Flight Ops is in the process of implementing RNP with the help of a company started by some really smart guys from AS (Naverus - http://www.naverus.com/Home.htm) which I believe will require VNAV and AT's.
[Edited 2007-11-27 11:14:49]
Southeast Of Disorder
IAHFLYR
RE: WN 737 Cockpit
Tue Nov 27, 2007 7:06 pm
Quoting Barney Captain (Reply 15):
Oh way smart guys.....NAVERUS is the only known hope to take on the 800 lb gorilla (FAA) and their methodical implementation process. Great reading on their website.
barney captain
RE: WN 737 Cockpit
Tue Nov 27, 2007 7:56 pm
Yea, this stuff seems like it will be VERY cool - I understand you guys are using it to some degree in IAH. Apparently we will be able to do circling precision approaches down to CAT 1 mins in places like MDW on runway 22L that currently have no precision approach. Sweet. I imagine VNAV is required, but do you know if the AT's are?
BTW, heres a better link to their site http://www.naverus.com/
IAHFLYR
RE: WN 737 Cockpit
Wed Nov 28, 2007 1:24 am
Quoting Barney Captain (Reply 17):
Yep,RNP's should show up in around 7 months in the form of some specials initially.
Jetlagged
RE: WN 737 Cockpit
Wed Nov 28, 2007 1:33 am
Since Boeing already designed RNP capability into the 737NG, why do Southwest need to employ a consulting firm to implement RNP procedures now?
JAGflyer
RE: WN 737 Cockpit
Wed Nov 28, 2007 2:44 am
Isn't A/T needed to maintain speed? I doubt a pilot would want to keep adjusting the throttles while in cruise on a 4 hour flight.
If you flew today, thank a Flight Dispatcher!
barney captain
RE: WN 737 Cockpit
Wed Nov 28, 2007 7:24 am
Quoting JAGflyer (Reply 20):
Or 6 1/2 from PHL to OAK, but that's the way we do it.
ShyFlyer
RE: WN 737 Cockpit
Thu Nov 29, 2007 6:37 am
Quoting Jetlagged (Reply 19):
Just because the aircraft is certified to do something, doesn't automatically mean the airline has been certified to do it.
I think that's the way it works.
Alias1024
RE: WN 737 Cockpit
Thu Nov 29, 2007 8:13 am
Quoting IAHFLYR (Reply 10):
CO also has the round dial representation on their NGs.
IAHFLYR
RE: WN 737 Cockpit
Thu Nov 29, 2007 12:56 pm
Quoting Alias1024 (Reply 23):
Where?
Quoting ShyFlyer (Reply 22):
I know to fly an RNAV (RNP) approach the operator must be certified just the same as with a RNAV (GPS) approach.
Jetlagged
RE: WN 737 Cockpit
Thu Nov 29, 2007 2:24 pm
Of course, but it still sounds like there's some unnecessary "wheel designing" going on. However, from personal experience I can understand that, with the FAA to be satisfied, nothing is certain.  Wink
744lover
RE: WN 737 Cockpit
Thu Nov 29, 2007 3:03 pm
It seems like someone who prefers to use TELEX, when we have internet and real-time systems, just because they used it in the past and don't want to give training to their employees.
I would bet also that WN does not use ACARS to upload Flight Plans, Wind data etc. (time savings) because it would cost them $$$ to send data...
Best regards!
GHN
RE: WN 737 Cockpit
Thu Nov 29, 2007 3:38 pm
Quoting 744lover (Reply 26):
Its upto the company to decide how to balance Costs with technology that would make things easier.
regds
MEL
ShyFlyer
RE: WN 737 Cockpit
Thu Nov 29, 2007 6:00 pm
Quoting IAHFLYR (Reply 24):
Where?
700:
Photo © Juan Pablo Marini
Photo © Danny Fritsche - Airplanespotters
800:
Photo © Dan Rabolt
900:
Photo © Jarek Dabrowski [epwa_spotters]
I always thought Continental used the PFD/ND set up.
Jetlagged
RE: WN 737 Cockpit
Thu Nov 29, 2007 6:11 pm
Is the EFIS or PFD/ND presentation style on the 737NG pilot selectable? It seems strange that one airline should have different presentations on some aircraft. Maybe Continental saw the Southwest display style and decided they preferred it and so changed their display options (the PFD/ND photo is the oldest).
IAHFLYR
RE: WN 737 Cockpit
Thu Nov 29, 2007 6:49 pm
Quoting ShyFlyer (Reply 28):
Very nice
ShyFlyer
RE: WN 737 Cockpit
Fri Nov 30, 2007 6:15 pm
Quoting Jetlagged (Reply 29):
Selectable by the pilot, no. I recall reading in a thread here some time back that the display style can be changed from one to the other rather simply by maintenance staff.
tdscanuck
RE: WN 737 Cockpit
Sat Dec 01, 2007 2:15 am
Quoting ShyFlyer (Reply 31):
I'm almost positive it's a program pin on the DEU (Display Electronics Unit). So a simple wiring change would flip the displays.
Tom.
Transpac787
RE: WN 737 Cockpit
Sat Dec 01, 2007 3:05 am
In the 737-924 picture, the captain side is PFD/ND, while the FO side is the old 6-pack display.
Jetlagged
RE: WN 737 Cockpit
Sat Dec 01, 2007 1:47 pm
Quoting Transpac787 (Reply 33):
Well spotted! It's a pre-delivery shot, so maybe they had it specially set up to show the two display options.
Max Q
RE: WN 737 Cockpit
Mon Dec 03, 2007 6:17 am
'The main purpose of autothrottles is for autoland'
Rubbish, it is a small part of the equation, we use autothrottles throughout the flight from take-off to autoland (if we wish or it is needed)
They are a major workload reducer and fuel saver.
This policy of SWA'S to dumb down the aircraft is a strange example of their aversion to technological progress.
I have no doubt that most SWA pilots would adjust quite easily to using the aircraft's capability to the fullest extent.
QantasHeavy
RE: WN 737 Cockpit
Sun Dec 23, 2007 2:10 am
I would have thought the auto throttle would produce much better fuel economy, like cruise control in a car. And therefore pay for itself for any training certification issues.
I am not a pilot but I am an MBA, and if there's one thing business schools drills into you it is that Southwest is a very well managed company and everything they do is deliberate and (mostly) has been very well thought-out and successful... so while I don't understand why they don't use LNAV, etc (didn't you guys just get LNAV not too long ago at SW?) but when you look at operational performance it is hard to find faults in the SW strategy... so I will sit back in my armchair and trust that good'ole Herb knew what he was doing.
I have a pretty sophistcated 737NG set up on my PC (for some of us that's as close as we'll get to the front office) and the VNAV is such a hassle to configure in the FMC I just don't use it anyway (though would love to learn how to program the VNAV portion as I always get an FMC message telling me this or that is not set so no VNAV).
barney captain
RE: WN 737 Cockpit
Mon Dec 24, 2007 6:25 pm
Quoting QantasHeavy (Reply 36):
Seems like its been 10 or so years since LNAV went live.
Our work towards getting RNP up and running AFAIK will require VNAV but I'm still not clear if AT's will be part of the package as well.
I agree, and that's something the powers that be are continually looking at.
SPREE34
RE: WN 737 Cockpit
Mon Dec 24, 2007 7:20 pm
RNP capability
RNP procedures
Two different things. Sort of like OWNING a car doesn't mean you can DRIVE a car.
FAA is also way behind the airlines in technical savvy.
barney captain
RE: WN 737 Cockpit
Mon Dec 24, 2007 7:39 pm
Quoting SPREE34 (Reply 38):
RNP capability
RNP procedures
Exactly. From what Flight Ops is telling us, this will be the single biggest undertaking in their history. Apparently it goes way beyond aircraft/aircrew certification and training. It involves designing custom tailored approaches to places like MDW.
Users browsing this forum: Alias1024 and 2 guests
