747Dreamlifter
Thrust Reverser Problems With GE90's?
Fri Nov 30, 2007 9:41 pm
Registration 9V-SWL is the newest triple-7 received by SQ on 26 Oct 2007. Looking at the picture posted on 16 Nov, I noticed that the reverser cowling on right GE90 is of a different color indicating a possible replacement. Is there a problem with the thrust reverser units on this high output engine.???
Just wondering since this aircraft is only a month old. Thanks.
Photo © Royal S King
Photo © Jerry pang
flipdewaf
RE: Thrust Reverser Problems With GE90's?
Fri Nov 30, 2007 9:53 pm
Components are more likely to fail at the start and the end of their service life (the bathtub model) so its not too shocking, could always be a case of ramp rash.
Fred
tdscanuck
Sat Dec 01, 2007 2:13 am
Quoting 747Dreamlifter (Thread starter):
Not any more so than any other aircraft I'm aware of. T/R's are finicky on a good day. Ramp rash is always an option for T/R's (they get hit a lot). It's also possible that they robbed a T/R off this aircraft when it was still in post-delivery check to serve an AOG line aircraft.
Spare T/R's are also really expensive, so they may have swapped the "mint" T/R from the delivery aircraft with an older one in spares so that their spare would be a low hours unit. This type of swap is fairly common with engines and tires as well.
Tom.
fr8mech
Sat Dec 01, 2007 3:15 am
I don't know anything about the GE90, but I do know reversers. A reverser half or translating sleeve change is usually a result of damage from some external source. Rarely do the structural components fail to the point where the half must be replaced.
Sat Dec 01, 2007 7:45 am
It looks like the C duct was replaced.
Could be mechanically related or Damage sustained on line.
regds
MEL
BR715-A1-30
Tue Dec 04, 2007 5:40 am
Or like some other cases, it could have just been a case of "correct color not available"
Puhdiddle
Users browsing this forum: AC853, aeromoe and 18 guests
